XX29; '69 Charger 500 project - 01/16/2012 #1155982
01/13/12 11:41 AM
01/13/12 11:41 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
As many already know, I now have another '69 Charger 500 (thanks Pete). I'm slowly, but surely making progress on getting her up and running. Got the motor going and verified the tranny works (from the standpoint of sitting up on jackstands). The next segment is the brake system.
Brake update.... Started tearing into it.. I just recieved me complete brake line kit from FineLines....... I'm in the process of removing the forward sections of the line system. The hard part will be the firewall line I'm sure. I had to cut the line at the valve, so it definitely will have to be replaced prior to restoration.. I'm going over to a friends tomorrow to use his air compressor so I can get the pistons out of the calipers and rebuild the assemblies. The booster and master cylinder seem fine... I'll attack the front to rear line and the Dana differential in the next day or two.... Slowly but surely....... The lines on the front were too far gone to trust not replacing it all...... I was able to find both side of the special brackets for the caliper's brake lines and caliper rebuild kits..
More progress to come.
Troy
Houston Mopar Connection Club
Re: XX29; '69 Charger 500 project. [Re: hemi68charger] #1155983
01/13/12 02:23 PM
01/13/12 02:23 PM
Minnesota
peabodyracing Offline
Minnesota
Nice car! You're spoiled. You think those are rusty brake lines? Can I send you some from a typical MN car to show you what rusty is?
Good luck with the project!
Lead, follow or get the hell out of the way
Re: XX29; '69 Charger 500 project. [Re: peabodyracing] #1155984
01/13/12 04:29 PM
01/13/12 04:29 PM
Houston, Tx
Houston, Tx
Guess so...
But, there were broken lines and all. The calipers had surface pitting developing on the piston bores, so it is just as well I did all this...
Troy
Re: XX29; '69 Charger 500 project. [Re: hemi68charger] #1155985
01/15/12 10:24 PM
01/15/12 10:24 PM
Houston, Tx
Houston, Tx
More stuff.... Putting the driver's side caliper back together and mounted in the car. Fit's pretty good. Glad I did this for the Bendix system is pretty easy.... New calipers seals, new hoses and as seen before, new lines... I removed the old front-2-rear line and the Dana lines as well. I'll tackle the passenger side here in the coming week along with installing the new Dana lines, wheel cylinders and hardware kit... Rest of the car doesn't look all that pretty, but, I'll get to that later.. I just wanna get the car going down the road...
Troy
Re: XX29; '69 Charger 500 project - 01/16/2012. [Re: hemi68charger] #1155986
01/15/12 10:25 PM
01/15/12 10:25 PM
Houston, Tx
Houston, Tx
2
Troy
Re: XX29; '69 Charger 500 project. [Re: hemi68charger] #1155987
01/15/12 10:25 PM
01/15/12 10:25 PM
Houston, Tx
Houston, Tx
3
Troy
Re: XX29; '69 Charger 500 project. [Re: hemi68charger] #1155988
01/15/12 10:25 PM
01/15/12 10:25 PM
Houston, Tx
Houston, Tx
Troy
Re: XX29; '69 Charger 500 project. [Re: hemi68charger] #1155989
01/16/12 11:32 PM
01/16/12 11:32 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
nice build it looks very solid i will be following it, what options does the 500 have?
Re: XX29; '69 Charger 500 project. [Re: upnover] #1155990
01/17/12 03:07 PM
01/17/12 03:07 PM
Houston, Tx
Houston, Tx
Option-wise:
A01: light package
A32: Super high performance axle axle package which includes
- 4.10 Dana
- 26" radiator high perf. w/shroud
- 7-blade fan
- front power disc brakes
- power steering
C16:console for auto
Troy
XX29; '69 Charger 500 project. update 03/13/12 [Re: hemi68charger] #1155991
03/13/12 11:08 AM
03/13/12 11:08 AM
Houston, Tx
Houston, Tx
Well, things are wrapping up on the hydraulic brake system. I've replaced all the lines, cleaned out the valving and replaced the master cylinder. I attached it to the power brake booster and freshened up the unit with a fresh coat black. I'm going to see about turning the drums and getting hardware.... After I get the brakes all bleed and good to go, new fuel lines are next.............
Here's I'm getting ready to paint the power bracke booster/master cylinder unit. It cleaned up rather nicely and then reman M/C.
Troy
XX29; '69 Charger 500 project. update 03/13/12 [Re: hemi68charger] #1155992
03/13/12 11:10 AM
03/13/12 11:10 AM
Houston, Tx
Houston, Tx
Almost done painting...
Troy
XX29; '69 Charger 500 project. update 03/13/12 [Re: hemi68charger] #1155993
03/13/12 11:10 AM
03/13/12 11:10 AM
Houston, Tx
Houston, Tx
Temporarily installed. Waiting to get the harness clip/bracket that attaches to the backing plate...
Troy
Re: XX29; '69 Charger 500 project. update 03/13/12 [Re: hemi68charger] #1155994
03/18/12 10:05 PM
03/18/12 10:05 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
Troy,nice looking car,can't go wrong with a32 axle pkg.Havent seen to many 500's what are the hoses from the firewall for?I thought they have fixed headlights!Scott.
Re: XX29; '69 Charger 500 project. update 03/13/12 [Re: 1970A13] #1155995
03/19/12 12:04 AM
03/19/12 12:04 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
The C500s were converted from R/Ts... Sometimes they cut the hoses off at the firewall, other times they wrapped them with electrical tape and hung them somewhere... True craftsmen those Creative Industries guys..
Re: XX29; '69 Charger 500 project. update 03/13/12 [Re: xs29j8] #1155996
03/19/12 12:11 AM
03/19/12 12:11 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Re: XX29; '69 Charger 500 project. update 03/13/12 [Re: xs29j8] #1155997
03/22/12 11:17 PM
03/22/12 11:17 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
That makes sense,thank's for enlighting me.Scott
Re: XX29; '69 Charger 500 project. update 03/13/12 [Re: 1970A13] #1155998
06/27/12 08:04 PM
06/27/12 08:04 PM
Houston, Tx
Houston, Tx
Update: Grille... I'm slowly getting the grille all squared away now. I have an NOS passenger side headlamp bucket and the attach brackets. What I was in need of was the inside vertical support brackets and driver's side headlamp bucket (which is IMPOSSIBLE) to find. I feel I'm extremely lucky to have found the NOS passenger side. Anywho, here's what I did/doing as of today...
Majority of what I have to start with...
Troy
Re: XX29; '69 Charger 500 project. update 03/13/12 [Re: hemi68charger] #1155999
06/27/12 08:06 PM
06/27/12 08:06 PM
Houston, Tx
Houston, Tx
Fitting the NOS bucket in.....
Troy
Re: XX29; '69 Charger 500 project. update 03/13/12 [Re: hemi68charger] #1156000
06/27/12 08:07 PM
06/27/12 08:07 PM
Houston, Tx
Houston, Tx
Grille fit with OEM brackets
Troy
Re: XX29; '69 Charger 500 project. update 03/13/12 [Re: hemi68charger] #1156001
06/27/12 08:09 PM
06/27/12 08:09 PM
Houston, Tx
Houston, Tx
Fitting the spacers in.... They were the same used on Coronets with length modifications.
Troy
