518 size vs 618 (47re)
#1154740
01/11/12 03:29 PM
01/11/12 03:29 PM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
Are these transmissions physcially the same size? I have a 47re laying around that I want to put in my challenger and I know the 518s fit.
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
Re: 518 size vs 618 (47re)
[Re: Jambbii]
#1154743
01/11/12 04:12 PM
01/11/12 04:12 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If you're looking at a 618 from a diesel you will need to change the governor weight. They're really heavy to keep shift points low for the diesel rpm.
[Re: Jambbii]
#1154744
01/11/12 04:12 PM
01/11/12 04:12 PM
Posts: 75,134 A Banana Republic near you.
JohnRR
yes they are the same EXCEPT the bellhousing is sized for a 13" or so converter. Because of that I am not sure if it's a little longer in the manicase.
What are you going to do about the electronics ?
Bellhousing is going to be an ultra bell. I am thinking full maual vb. I heard by using this I can get rid of most of the electronics and put the od/lockup on a switch. This will be going in a high hp street car.
Switch on OD and lockup along wit hthe full manual VB will do the trick , just be careful with the lockup clutch .
Do they make a high performance lockup convertor for gas engine these days?
[Re: JohnRR]
#1154745
01/11/12 04:23 PM
01/11/12 04:23 PM
Jambbii
Mesa , Az
Feets, yes it is from a diesel. Thanks for the tip. JohnRR I have played around plenty of times with a lockup switch mostly drag racing my 95. I know how dangerous they can be ![](/ubbthreads/images/graemlins/biggrin.gif) I think the converter is going to be my biggest struggle. I know plenty of good diesel guys making decent units but nothing for the smaller converters that are going to hold up to big power. It may be a custom one off unit.
[Re: Jambbii]
#1154746
01/11/12 05:29 PM
01/11/12 05:29 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
A 47re does not have a govenor diesel or gas. Just put the bell on it and swap VBs.
[Re: HotRodDave]
#1154747
01/11/12 05:55 PM
01/11/12 05:55 PM
Posts: 3,911 Oregon
hooziewhatsit
Is it an RE or an RH? The first is electronically controlled, and needs a special computer. The latter (RH) can be controlled with toggle/vacuum switches.
[Re: gtx6970]
#1154753
01/12/12 01:20 PM
01/12/12 01:20 PM
JohnRR
an trans ending with RE has no mechanical governor.
I'm not a racer so I can't answer if installing a full manual valve body on an RE series trans will work or not
Yes it will Bill, there was a guy in Half moon bay ... RIP Noel ... with a 98 or 99 24V Cummins Ram that had a full manual VB in it ....
Otherwise all the OP would need to do is change the OD section , but with a manual VB there is no need for the gov or it's circuit.
[Re: JohnRR]
#1154754
01/12/12 03:49 PM
01/12/12 03:49 PM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
Question on the full manual VB
The only 518 full manual VB that I found is a Grinner with trans brake. This is a overdrive but non lock up 89-93
Is there a full manual VB with out trans brake?
For 518 over drive non lock up?
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#1154755
01/12/12 07:24 PM
01/12/12 07:24 PM
JohnRR
Diesel Transsmission Technology in British Columbia built the Manual VB i spoke of above , I can't remember if it had a transbrake in it or not. It might have because the Cummins needs to build boost at the line and that would sure make things easier.
[Re: Evil Spirit]
#1154757
01/12/12 08:14 PM
01/12/12 08:14 PM
JohnRR
Easier on everything except the reverse band and the forward clutch! I don't know if I want to sit on top of a trans being fed 1300FT/LBS of torque from a Cummins seeing 60+ LBS/Boost, being held in both low and reverse. I'm not saying they don't make a Trans/Brake for diesel 618's - I'm just looking at the "mechanicals" of using one. Sorta like "Yeah, I CAN load 600 grains of black powder into my muzzle loader, but should I?
That's why I said ... I can't remember if ... , Bill built the manual VB because he knew the driver would have killed the trans with an auto shifting VB.
[Re: savoy64]
#1154758
01/12/12 11:36 PM
01/12/12 11:36 PM
Posts: 541 chatham, Ilinois
fox
super street
super street
chatham, Ilinois
the diesel units are full of turbo400 internals and there is all kind of aftermarket stuff available---check with larry at chrisman torque converters he has pioneered a torqueflite converter with the same stuff inside----years ago he bought a $900 race converter from a big national chain then cut it open to find it full of machined down nissan stuff--that propelled him into using off the shelf american parts----check his website out----other guys here have mentioned using his stuff--and i think his are moderately priced too----bob
Now that is funny! Who and why put chevy parts in a better trans? This trans can easily be built so no NA gas motor will hurt it. If the trans can be built and hold a diesel with 1500 Ft. lbs. it is over kill for a gas motor. The T-400 is a good trans too.
