Re: Body jig like ...the one AMD uses.. [Re: moparmojo] #2142188
08/27/16 11:30 PM
08/27/16 11:30 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Originally Posted By moparmojo
Originally Posted By 5wndwcpe
Here is how I mount the car to the jig. The bolts go into the factory holes and mount and un-mount quickly and cleanly.
Now your set up looks pretty smart. Can you share more pics for us so we can see the pic up points underneath and the overall jig. Nice work.
Thanks. I'll have to scare up some pics, unfortunately there are none on this computer.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Body jig like ...the one AMD uses.. [Re: magnumcharger] #2144074
08/30/16 07:31 PM
08/30/16 07:31 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I had asked Jeff at 521 restoration about his Jig and he was more than willing to share his information. He had a write up on his website as well.
Here is a link: http://www.521restorations.com/index.pl?page=framejig
Matt
Re: Body jig like ...the one AMD uses.. [Re: magnumcharger] #2145851
09/02/16 01:02 AM
09/02/16 01:02 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Here are a few shots of the build. I built the framework on saw horses (not the ones pictured)leveled to the ninth degree but of course, the pieces would move around a bit after welding so I didn't add the uprights until the lower box was complete.
Using the frame chart, the first and last uprights were set to the datum line and the others were added to meet this line.
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: Body jig like ...the one AMD uses.. [Re: 5wndwcpe] #2158038
09/20/16 12:02 PM
09/20/16 12:02 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
That is a really slick set up and it looks like it can be disassembled. Curious how you choose your pick up points. Did you solely go off of measurements from the book or the actual car to determine it will be perfectly square and level.
Re: Body jig like ...the one AMD uses.. [Re: magnumcharger] #2158566
09/21/16 03:16 AM
09/21/16 03:16 AM
RT03 Offline
RT03  Offline
Those are some pretty nice frame jigs you folks have made. The shop doing the work on my GTX made a jig to hold my car so it's not tying up one of the frame racks at the shop for months on end. It's not as elaborate as some of these jigs, but it's more than adequate.
It's squared and leveled with the floor with adjustable feet and clamped at the rocker pinch welds. The uprights locate the front and rear frame rails and the rear tail light panel. He's using a Chief laser measuring system which maps out all the measuring points on the frame. I printed out the page in the shop manual that had the frame specs for him, but I'll have to ask him if the Chief aligner had the specs in the software as well.
Re: Body jig like ...the one AMD uses.. [Re: moparmojo] #2159154
09/22/16 12:03 AM
09/22/16 12:03 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
I went off of the frame specs as provided by Ma Mopar. I knew I was going to cut the floor, trunk and quarters off and didn't want the car to boogie around and as the car was welded crooked from the factory (imagine that) I thought it best to start where it was supposed to be.
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
