Suicide front end help, much apprrciated! #1154508
01/11/12 01:15 AM
01/11/12 01:15 AM
MO
W
Washburnin Offline OP
W
MO
I have 1935 dodge truck with factory suicide doors and want to put a
Suicide front end under it. Im using as an axle a 1950 chevy straight axle.
Has anyone done anything like this and maybe have some pictures and/or advice? Parts or plates needed, batwings? Ive never built a suicide front end so all info is helpful! Thank u!
Washburnin
Re: Suicide front end help, much apprrciated! [Re: Washburnin] #1154509
01/11/12 02:43 PM
01/11/12 02:43 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
here are a few pics of front ends that might help. Ron...
Re: Suicide front end help, much apprrciated! [Re: Washburnin] #1154510
01/11/12 03:16 PM
01/11/12 03:16 PM
dogdays Offline
dogdays  Offline
With so much talk of suicide I think it's time for an intervention...
R.
Re: Suicide front end help, much apprrciated! [Re: dogdays] #1154511
01/11/12 03:29 PM
01/11/12 03:29 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Why is it called suicide?
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Suicide front end help, much apprrciated! [Re: 36PLYM] #1154512
01/11/12 04:44 PM
01/11/12 04:44 PM
Mopar Ron Offline
Mopar Ron  Offline
I found this explanation
A suicide front end is a straight or dropped tube or I-beam axle mounted in front of a transverse spring.The shackles are mounted to the wishbone or a bracket on hairpins and a single perch on the front of the frame.The term was coined in the thirties when guys used this method to get their cars really low.With no crossmember over the spring and no frame above the axle if any link in the system would fail the frame would drop straight to the ground with deadly results.Running this setup was like playing Russian roulette with your car.Hence the term suicide...
Re: Suicide front end help, much apprrciated! [Re: Mopar Ron] #1154513
01/11/12 05:29 PM
01/11/12 05:29 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Ron those are some great pic's. Any or all of em yours?
I like the pin striped one a lot. That first one looks really scarry. Am I missing something or are there no springs and it is riding on just shocks? I dig the ply wood front runners for mock up. good idea.
I have mechanical Aptitude.
I can screw up anything.
Re: Suicide front end help, much apprrciated! [Re: bboogieart] #1154514
01/11/12 06:49 PM
01/11/12 06:49 PM
Nort Cackalacky
rrbrucea Offline
Member known as the "Artist"
rrbrucea  Offline
Nort Cackalacky
First one has leaf springs beneath the frame and axle...
Re: Suicide front end help, much apprrciated! [Re: bboogieart] #1154515
01/11/12 08:25 PM
01/11/12 08:25 PM
Mopar Ron Offline
Mopar Ron  Offline
no none of those are mine, I just saved the pics for Ideas for future projects
Re: Suicide front end help, much apprrciated! [Re: Washburnin] #1154516
01/12/12 12:22 AM
01/12/12 12:22 AM
MO
W
W
MO
Those pics are great and i got in touch with a guy by the last name Lahr's outa KY. Since i had a chevy front end no batwings would really work and this guy, Mr. Lahr's makes a whole bolt on suicide kit and pins all for a little over 300.00 if anyone has a chevy front end and wants to make it a suicide Get with me and ill gladly get the number. Also ill post pictures of it just for general references of what his kit looks like after assembly. Thanks for the pics posted again its very much appreciated!
Re: Suicide front end help, much apprrciated! [Re: Washburnin] #1154517
01/12/12 10:24 AM
01/12/12 10:24 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Yep, Ron Lahr. I bought the same setup a while back. Designed for parallel leaf spring axles to mount a transverse spring onto. Any make axle can be used.
Re: Suicide front end help, much apprrciated! [Re: Bull1tt] #1154518
01/12/12 04:14 PM
01/12/12 04:14 PM
MO
W
W
MO
Any pictures of it? Id love to see what the final product can and should look like for reference. When i spoke to mr. Lahr's on the phone he was totally the most helpful guy one could ask for and just over the phone was knowledgable enough to know and solve my problems. Thanks everyone for all the help!
Re: Suicide front end help, much apprrciated! [Re: rrbrucea] #1154519
01/12/12 08:51 PM
01/12/12 08:51 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I see em now, kinda hidden. Those must be a half spring each side.
Still looks scarry, probably the idea, huh?
Re: Suicide front end help, much apprrciated! [Re: Mopar Ron] #1154520
01/12/12 08:54 PM
01/12/12 08:54 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
no, none of those are mine, I just saved the pics for Ideas for future projects
right, makes sence.
Re: Suicide front end help, much apprrciated! [Re: bboogieart] #1154521
01/12/12 10:13 PM
01/12/12 10:13 PM
moparx Offline
moparx  Offline
that is called a "quarter elliptic" suspension. can be a good choice in some instances.
