Page 2 of 4 1 2 3 4
Re: Hydraulic throwout bearing kits [Re: DaytonaTurbo] #1150337
01/05/12 04:57 AM
01/05/12 04:57 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I think the tilton hyd bearing was like 250$
Re: Hydraulic throwout bearing kits [Re: sshemi] #1150338
01/05/12 06:47 AM
01/05/12 06:47 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
on a small block car it would be so easy to use a hyd system off a 88 and newer D/W pickup// Readily availability at any parts house...
I am truckless..
Re: Hydraulic throwout bearing kits [Re: 340SHORTY] #1150339
01/05/12 10:14 AM
01/05/12 10:14 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I think a master/slave cylinder system is all that is needed. I have been discussing this with Jamie Passon to produce a quality, no fuss no muss system using this configuration.
Cost, ease of installation-true bolt on/in [do i need to elaborate??], use of "off the shelf" parts are factors being discussed.
There is some very creative work shown here, why don't you guys give Jamie a call and talk about it.
Re: Hydraulic throwout bearing kits [Re: ThermoQuad] #1150340
01/05/12 10:37 AM
01/05/12 10:37 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
anybody looked at trying to adapt a Dakota master/slave set-up? go get the whole thing for cheap out of a junk yard. it's a pusher slave where it pushes from the transmission towards the engine, to actuate the clutch fork which pivots on a ball stud on the far side of the clutch.
or you could possibly flip it around so that it pushes from the engine, back towards the transmission, if the fork is mounted on a ball on the "starter" side of the bell housing.
on my big block Dakota with a TKO trans and Lakewood bell though, I originally used a tilton Hyd. bearing, which was a POS, leaked all over the place and their fitings were a JOKE! I went and got REAL banjo fittings to make it work, but then the thing was too big to fit through the bore in the bell for the transmission bearing retainer, forcing me to assemble the unit with the trans bolted to the bell, and off of the engine. pain in the butt!
that bearing ultimately had another failure where the actual bearing and faceplate popped off the hyd. piston.
went with a Powertrain Technologies Inc. Hyd. TO bearing. MUCH better design, came with shims to stack up under the bearing to space it off the transmission, and it just "floated" there between the trans and clutch. it used a long shoulder bolt to prevent it from spinning.
both units were about $250-300, which is why, in hind sight, I wish I had tried to adapt the stock master/slave set-up to work.
**Photobucket sucks**
Re: Hydraulic throwout bearing kits [Re: 74RALLYE] #1150341
01/05/12 10:45 AM
01/05/12 10:45 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
What I learned (which after months of headaches and cursing through the learning curve)which is the way I would do it again.
Late 80's Nissan Pathfinder hydraulic master cylinder.
McLeod hydraulic T.O. bearing modified with an additional spacer between the T.O bearing and the transmission bearing retainer, and the T.O. bearing drilled and tapped for two set screws to keep it from sliding down the transmission input shaft, a problem McLeod fails to address.
Re: Hydraulic throwout bearing kits [Re: Commando1] #1150342
01/05/12 11:47 AM
01/05/12 11:47 AM
Texas
vynn3 Offline
vynn3  Offline
Texas
I also found this kit from Brewer's that uses an external slave:
http://www.brewersperformance.com/proddetail.asp?prod=HYD
vm
Re: Hydraulic throwout bearing kits [Re: vynn3] #1150343
01/05/12 02:52 PM
01/05/12 02:52 PM
A certified culture free zone.
74RALLYE Offline OP
74RALLYE  Offline OP
Great info!
I had not considered a system with the slave cyl. is on the outside of the bell housing.
Is there a hyd. throwout bearing that does not require drilling through the fire wall to mount a master cyl??
Re: Hydraulic throwout bearing kits [Re: 70Cuda383] #1150344
01/05/12 03:12 PM
01/05/12 03:12 PM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
The problem is space, on a conventional SB Mopar, the starter boss on the bell housing extends outward to a point that the slave cylinder is sticking out a considerable distance thus making the approach angle to the pivot arm (TB arm) somewhat steep. Also, because it is sticking out from the trans, exhaust is an issue. This is why I am waiting on my headers to mock it back up. That said, I am now pretty confident that the best way to do this is with a puller slave cylinder. You have to make a bracket (Like Chucks and Brewers have) to attach the anchor point of the slave to. This mounts to the trans side cover bolts. this allows the cylinder to get out of the way of the exhaust and tucks it nicely into the area right behind the pivot arm and trans. Chucks and Brewers have nice kits that do all of this, if you don’t want to make anything, I would recommend just buying their kit (approx $400). However, if you want to and are able to make brackets and such, you can do the exact same thing for half the price. Chucks takes a different approach to mounting the MC, they mount theirs to the clutch pedal directly, and thus the MC is under the dash. This isn’t a problem as you can remote the reservoir; however I would prefer to have it in the engine compartment where I can see/work on it (personal preference). The biggest manufacturing issue here is the bracket that bolts to the trans as an anchor point for the slave.
01 Viper GTS ACR
10 Challenger RT PCP 6spd
70 Challenger 440 6 pac
73 Cuda 416 Road Racer
70 Hemi Roadrunner
01 Ram 4x4 / 98 Ram 3500
91 Stealth RT
05 Durango Hemi
09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: Hydraulic throwout bearing kits [Re: 70chall440] #1150345
01/05/12 09:31 PM
01/05/12 09:31 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
What would be nice is a bellhousing with slave cylinder mount. Keisler and Brewers have new bellhousings cast. I wouldn't think it would be too hard design a bell with a slave mount.
Re: Hydraulic throwout bearing kits [Re: RTSE4ME] #1150346
01/05/12 10:08 PM
01/05/12 10:08 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The later Dodge trucks have the external slave on the bell..
you could mount a after market pedal and MC under the dash so no holes needed in the firewall..
I am truckless..
Re: Hydraulic throwout bearing kits [Re: 74RALLYE] #1150347
01/05/12 11:04 PM
01/05/12 11:04 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
One thing that I have heard over and over is how much internal slave cylinders suck. I've got a jeep with the stick shift and the huge rage on those forums is to convert to an external style slave to get away from the issues that come with the hassle of replacing an internal slave cylinder when it starts to leak. Plus the external is cheaper and easy for a diy type guy to do.
Great info!
I have seen pics of some where the MC is mounted under the dash, however you still need to run the hose through the firewall somewhere. I prefer to just mount the MC to the firewall so the brake fluid all stays outside the cab. Clutch MC is so small anyway it's barely noticeable.
Re: Hydraulic throwout bearing kits [Re: RTSE4ME] #1150348
01/06/12 11:21 AM
01/06/12 11:21 AM
Commando1 Offline
Commando1  Offline
Make your bracket for a stock bell housing. Easy enough...
Re: Hydraulic throwout bearing kits [Re: Commando1] #1150349
01/06/12 03:01 PM
01/06/12 03:01 PM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
that is eactly what I was going to do, however the started is in the way, it might because of the type of slave cyl. I am using but I could not get the angle to work. I have decided to go with a puller style. If you google this topic (slave cylinder, hyd clutch, etc) you will see that Mustang guys have been using this type of setup for years. The one thing that I ascertained from reading all of thier posts was that angle is important. If you install the cylinder so that during activation, the rod is being stressed to one side or the other, it will cause the cylinder to leak prematurely. With Mopars, since the pivot arm moves at an angle, I think it is important to install the slave to pull or push the arm in straight line. I could be wrong, but it makes sense in my head.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Hydraulic throwout bearing kits [Re: 70chall440] #1150350
01/06/12 03:51 PM
01/06/12 03:51 PM
sweden
sshemi Offline
sshemi  Offline
sweden
to me it doesnt make sence to build something that still takes up space (slave cyl) its not like the clutch will be super easy to pedal just because you go hydraulic.
The friction lost in a stock setup is minimal, and the geometry when properly adjusted is actally thought through by mopar.
Without having limited space and/or super heavy springs in the pressure plate a hyd clutch TO ME is a waste of time.
Newtons law "what you earn in force you loose in distance" applies to hyd too.
Aldough i have been thinking about some hyd/pneumatic booster.
But to me i only have limited space so its not gonna happen in a near future
Re: Hydraulic throwout bearing kits [Re: sshemi] #1150351
01/06/12 04:41 PM
01/06/12 04:41 PM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
Obviously you can use what you want, however there is a reason that every manufacturer has gone to HYD. When this is coupled with a diaphram PP, I beleive it will make for a much more pleasurable drivng experience. I recently drove a 69 Hemi RR with factory linkage and was reminded of just how stiff all of that is. Sure, you could buy more modern components and ease the amount of leg effort required, however with a HYD system, you also get more header/exhaust space which is a good thing. Again, I am not trying to convince anyone to do anything, merely discussing how to do it.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Hydraulic throwout bearing kits [Re: 70chall440] #1150352
01/06/12 04:51 PM
01/06/12 04:51 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I did one of the mcleod systems last year.
440 sixpack , Lakewood scattershield, TTI headers and it was a major painintheazz to adjust.
even once it was adjusted I personally didn't care for it.
Cars owner last time I talked to him was thinking about taking it back out to re-install the stock stuff. as one of things he didn't care for he felt the hydraulic system would react fast enough to speed shift the car
Re: Hydraulic throwout bearing kits [Re: gtx6970] #1150353
01/07/12 02:25 AM
01/07/12 02:25 AM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
Oh I am sure there will always be those you like this or that and those that dont. I am not saying one is necessarily better than the other, however talking to some of the custom guys at SEMA, all of those that I talked to were running HYD. I have a HYD in my Viper and 10 Challenger and they work great. I have had a fair number of old school mopars with the stock linkage and while they functioned as intended, with this car I wanted to try something different. This is one of the reasons I chose to go with the slave Cyl. option, if I decide I want to go stock, I can do so w/o removing the trans. The other issue I have/had witht the HYD TB is adjustment and leakage, for both, you have to remove the trans.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Hydraulic throwout bearing kits [Re: sshemi] #1150354
01/07/12 04:09 AM
01/07/12 04:09 AM
Manitoba, Canada
Manitoba, Canada
Don't discount it if you haven't tried it. There's a reason NO modern performance car runs a mechanical clutch linkage. The ONLY reason any manufacturer would put a linkage or cable actuated clutch in a car these days is it's cheaper to produce than a hydraulic clutch.
Re: Hydraulic throwout bearing kits [Re: 70chall440] #1150355
01/07/12 05:37 AM
01/07/12 05:37 AM
sweden
sshemi Offline
sshemi  Offline
sweden
What do you mean by adj a hyd bearing?
If you install it correct you should never need to adj again
Re: Hydraulic throwout bearing kits [Re: sshemi] #1150356
01/07/12 09:52 AM
01/07/12 09:52 AM
New Jersey
Claw57 Offline
Claw57  Offline
New Jersey
Hydraulic can also be an alternative for those doing a conversion whose car doesn't have the factory z-bar frame bracket.
Because I like it that way.
Page 2 of 4 1 2 3 4
