Re: 1969 Barracuda M code
[Re: viperakron]
#1149288
09/24/12 07:23 PM
09/24/12 07:23 PM
Posts: 43,555 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
A question on your car, it looks to have been changed to large bolt pattern, does it have 73-up style discs?
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1149290
09/24/12 07:35 PM
09/24/12 07:35 PM
Posts: 21,513 N.E. OHIO, USA
A12
N.E. OHIO, USA
What's the difference between a B-body 22" radiator #2949053 (383/440) and an A-body (A13) 22" radiator 2949065? And if anyone has a 2949065 radiator or even the top tank or PM me please. Thanks
[Re: A12]
#1149291
09/24/12 08:53 PM
09/24/12 08:53 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
I compared rad specs in the service manual. It shows the 065 having a 10" trans cooler and the 053 having a 12" cooler.
[Re: A12]
#1149292
09/24/12 09:00 PM
09/24/12 09:00 PM
Posts: 327 Northern BC
Canucklehead
Northern BC
Mine had a 2898045 68 B-body rad in it when I got it and the mounting holes were spaced further apart, they had drilled some extra holes on the passenger side rad support to mount it.
[Re: A12]
#1149293
09/25/12 11:01 AM
09/25/12 11:01 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
The 065 radiator is a 3 row core . I never compared the top hose location between the 2
[Re: JohnRR]
#1149294
09/25/12 11:40 AM
09/25/12 11:40 AM
Rhinodart
Rhinotruck
Rhinotruck
Top hose location is the same, bottom hose is not. The 065 is at the very end of the tank and has a larger opening.
A-Body's RULE!
[Re: A12]
#1149296
09/27/12 09:25 PM
09/27/12 09:25 PM
Posts: 8,273 fredericksburg,va
cudaman1969
fredericksburg,va
And if anyone has a 2949065 radiator or even the top tank or PM me please. Thanks [/quote
Good luck finding one.they go for a grand and up any condition
[Re: cudaman1969]
#1149297
09/27/12 09:56 PM
09/27/12 09:56 PM
A12
N.E. OHIO, USA
This is exactly why I'm so confused as to why these M-Code A-bodies don't get the price they surely (don't call me Shirley ) are worth. It's easier to find an A12 air filter base than a left exhaust manifold or a correct radiator and you can find 26" reproduction 054 and 055 radiator that were far less common than a 22" radiator in a B-body road runner that they made over 84,000 of them in 1969 with at least half of them or more with a 22" radiator.... okay I feel a little better after that
Bob, come on MAKE A REPO 22" RADIATOR FOR PETE'S (no make that for) MIKE'S SAKE!! I know I'm not the first one to ask you for a 22" rad, surely (I said don't call me Shirley ) I won't be the last either.
MikeR
[Re: OneOfMany]
#1149299
09/28/12 12:14 PM
09/28/12 12:14 PM
Posts: 118 Winnipeg
OneOfMany
Winnipeg
[Re: A12]
#1149302
09/28/12 03:37 PM
09/28/12 03:37 PM
JohnRR
U.S.S.A.
thanks, any difference on the top tank other than the part number?
[Re: JohnRR]
#1149303
09/28/12 04:23 PM
09/28/12 04:23 PM
A12
N.E. OHIO, USA
BESIDE the part number and THE HOSE LOCATION? (big font, little font, use Chrysler blah, blah, blah )
[Re: A12]
#1149304
09/28/12 05:59 PM
09/28/12 05:59 PM
JohnRR
U.S.S.A.
I forget that you suffer from A.D.S. , thinking maybe someone can make a tag for you to solder over the wrong number if you can scare up the right bottom tank ?
I thought that the round top 22" was repopped ?
[Re: JohnRR]
#1149305
09/28/12 06:18 PM
09/28/12 06:18 PM
A12
N.E. OHIO, USA
Not by Bob at Glen-Ray...Bob and I talked about that a few times and I'm sure that I'm not the only one that has talked to Bob about a 22" round top radiator, am I Bob I think there are way more different 22" rt radiators that makes it tough to single out the ones with good enough demand to make it worthwhile to repo one versus another?
[Re: A12]
#1149306
09/28/12 07:04 PM
09/28/12 07:04 PM
Rhinodart
Rhinotruck
Rhinotruck
Bob does indeed repop the 383 radiator for 1968 2898033, I got him the originals so he could make the tanks. I have one of his radiators sitting right here in front of me, $1,195 each! He has the top tank for the other kinds too, I believe he can build a 2949065 because it is the same tank as the 340 radiators. http://www.hemiradiators.com/products.asp?cat=1
A-Body's RULE!
