Page 6 of 47 1 2 4 5 6 7 8 46 47
Re: 1969 Barracuda M code [Re: Airgrabber] #1148987
03/01/12 01:07 PM
03/01/12 01:07 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 1969 Barracuda M code [Re: BloFish] #1148988
03/01/12 05:15 PM
03/01/12 05:15 PM
Wheatfield, NY
Cuda340 Online work
Cuda340  Online Work
Wheatfield, NY
What are the casting numbers of the exhaust manifolds?
Re: 1969 Barracuda M code [Re: Cuda340] #1148989
03/01/12 05:36 PM
03/01/12 05:36 PM
USA
big-block-dave Offline
USA
Well the right side is the same as any '67-'69 383 A-body 2863900. The left side for 440 is 3462017. The M-codes used a spacer on the right side between the exhaust manifold and the head pipe which brought both sides down to where the 383 exhaust would be in height. Therefore the standard 383 head pipes were used on the 440 M-codes.
I have some spacers made, but hopefully will be having more made.
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: 1969 Barracuda M code [Re: big-block-dave] #1148990
03/02/12 12:47 AM
03/02/12 12:47 AM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Count me in on a spacer! I have NOS 383 pipes, so all I need now is a 017...
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 Barracuda M code [Re: big-block-dave] #1148991
03/02/12 07:35 PM
03/02/12 07:35 PM
Kentucky USA
RR6BBL1969 Offline
RR6BBL1969  Offline
Kentucky USA
I would be interested in one of those spacers for my car too if you have any extra. I don't know the exact dimensions but I wouldn't think there would be much to them. What, 3/4" thick and the oval pattern with two 1/2" holes? Anyway, let us know if you make any extras. Much appreciated.
Re: 1969 Barracuda M code [Re: RR6BBL1969] #1148992
03/02/12 11:49 PM
03/02/12 11:49 PM
cali
68mannix Offline
68mannix  Offline
cali
i would be interested in a spacer also.
Re: 1969 Barracuda M code [Re: Hemi Jeff] #1148993
03/03/12 12:31 AM
03/03/12 12:31 AM
Roseburg, Oregon
Tom Swope Online content
Tom Swope  Online Content
Roseburg, Oregon
We have the spacer kits in stock if anybody is in need of one.
http://www.accurateltd.com/A-Body-Spacer-Plate-Kit_p_341.html
P.S. A spacer kit can also be used on the left side for a 440 application if a 383 (002 ,729 casting) manifold is used. This might flip somebody out that is "anal" but guess what? We sell a lot of these kits for that reason and we are in business to supply what people want. And if you don't like the included bolts-use something else.
Side note: 67-68 big block a-body cars used a two piece head pipe that was welded together. These were 2.25" halfway back then 2" to the mufflers.
One piece head pipes are available with the ugly dents for 1969 as an option but you will need to specify this when ordering.
Moparts members members receive a 10% discount on all products.
Re: 1969 Barracuda M code [Re: Tom Swope] #1148994
03/03/12 12:45 PM
03/03/12 12:45 PM
Kentucky USA
RR6BBL1969 Offline
RR6BBL1969  Offline
Kentucky USA
Great! Any club discounts?? Thanks
Re: 1969 Barracuda M code [Re: big-block-dave] #1148995
03/05/12 01:21 PM
03/05/12 01:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Dave, Mike again, Have you heard what size battery is used and color caps? My build sheet said the smaller one (24) but i think they changed it to the big one (27) with the 440?
Re: 1969 Barracuda M code [Re: Rhinodart] #1148996
03/05/12 01:43 PM
03/05/12 01:43 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Jim,
If your any where near my house when going back home to Rockford let me know and I'll show you the M code 69 coupe and the 2 67 formula S fastbacks I have a 383 4 spd and the other is 273 spd missing the engine.
logan426 Martin Wimberly Odin,IL cell 618-322-7587
Re: 1969 Barracuda M code [Re: cudaman1969] #1148997
03/05/12 02:10 PM
03/05/12 02:10 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I can't say for sure with the A-bodies, but I doubt they would have put the 27 battery in them, since they left the yellow cap 24 in the A12 B-bodies.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 1969 Barracuda M code [Re: cudaman1969] #1148998
03/06/12 12:37 AM
03/06/12 12:37 AM
Arizona
Hemi Jeff Offline
Hemi Jeff  Offline
Arizona
Hi Guys,
The right battery is the group 24 Yellow Cap from the factory. I have not seen a group 27 Red Cap in any M-Code, A-bodies. I have the Yellow Cap in my car.
Re: 1969 Barracuda M code [Re: Hemi Jeff] #1148999
03/06/12 03:34 AM
03/06/12 03:34 AM
USA
USA
Group 24 yellow cap............green cap small block.
Re: 1969 Barracuda M code [Re: big-block-dave] #1149000
03/06/12 04:53 AM
03/06/12 04:53 AM
Rhinotruck
Rhinotruck
Only battery EVER in an A-Body is a Group 24, that is except for the forklift battery they put in the Super Stock cars...
A-Body's RULE!
Re: 1969 Barracuda M code [Re: big-block-dave] #1149001
03/06/12 08:55 PM
03/06/12 08:55 PM
currently on moparts.
Race&Resto Offline
Race&Resto  Offline
Big Block Dave, can you post some more photos of some of the 69 440 M-code Cuda's that you have from your files or from the registry if possible.
Re: 1969 Barracuda M code [Re: Race&Resto] #1149002
03/06/12 10:21 PM
03/06/12 10:21 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
especially some more pics of that green fast back!
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 1969 Barracuda M code [Re: Tom Swope] #1149003
03/06/12 11:11 PM
03/06/12 11:11 PM
USA
USA
Tom? WOW, i thought i was doing something SPECIAL for the M-code A-body guys with a small guy, private run of the spacer that MOST people don't even know existed. NOW you made them?? How many people out there really gotta have them? It's more an anal thing, because that's the way the cars came....(PS your bolts are wrong)
I guess my QUESTION is why would you go thru the trouble to make the spacer that you REALLY don't need on these cars, because a lot of cars have custom bent pipes anyways and few would ever be sold, but your BIG company made incorrect 2 piece head pipes????????????
Re: 1969 Barracuda M code [Re: big-block-dave] #1149004
03/07/12 12:36 AM
03/07/12 12:36 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
M-code Cuda
Re: 1969 Barracuda M code [Re: wldtm] #1149005
03/07/12 03:36 AM
03/07/12 03:36 AM
USA
USA
I don't have a lot of pictures of M-cudas. There were none with the registry when i took over. I have some from like '04 when m-cars were in building Y @ Carlisle(likely film pics). And some from MY/Carlisle's reunion in '09. I see the T5 car above, that was at Carlisle in '09, it has a 6-pak with triangular air cleaner....he got 1 of the trophies in our class, peoples choice, i think they liked the 6-pak, very nice car.
2nd quote...what green fastback are you talking about?
Below is 1 of only 5 white fastbacks in the registry. 1 of 4 with black interior, the other 1 has green interior.
Re: 1969 Barracuda M code [Re: big-block-dave] #1149006
03/07/12 03:41 AM
03/07/12 03:41 AM
USA
USA
My friends car that was at the reunion @ Carlisle '09. Sold and went to Western Canada........Probably to never be seen in the US again. That's terrible. Awesome original metal car!!
