Re: 440 SOURCE SLEATH HEADS? #1148793
01/02/12 06:06 PM
01/02/12 06:06 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
Are the SLEATH heads the new models ? ..... how do they differ from the STEALTHS ?
You of all people busting on someone's typo is RICH!
Akin to Richard Simmons pointing out someone's ghey lifestyle.
HAY ..... DON'T bust 64Pest's lifestyles choices
Re: 440 SOURCE SLEATH HEADS? [Re: 05dakota] #1148794
01/02/12 06:11 PM
01/02/12 06:11 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
trying to get a nice 9.5 to 1
Ok , but WHAT pistons are in your 66 since you don't have stock heads on it to begin with ???
Re: 440 SOURCE SLEATH HEADS? [Re: JohnRR] #1148795
01/02/12 06:16 PM
01/02/12 06:16 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
its a 69 440.
Re: 440 SOURCE SLEATH HEADS? [Re: 05dakota] #1148796
01/02/12 06:22 PM
01/02/12 06:22 PM
JohnRR Offline
JohnRR  Offline
its a 69 440.
Stock or rebuilt ? this is taking longer than it should ted ...
Re: 440 SOURCE SLEATH HEADS? [Re: JohnRR] #1148797
01/02/12 06:29 PM
01/02/12 06:29 PM
JohnRR Offline
JohnRR  Offline
Ted if the engine is still factory stock your compression is about 9.3 , stealths at 80cc (if they are 80cc??) and a .041 head gasket , typical felpro 8915 , you'll be 9.7 , with no quench and alum head you should be ok ...
Re: 440 SOURCE SLEATH HEADS? [Re: JohnRR] #1148798
01/02/12 07:25 PM
01/02/12 07:25 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
sorry john, all i know is with the piston combo my builder is using he wants an 88-90cc head.
Re: 440 SOURCE SLEATH HEADS? [Re: 05dakota] #1148799
01/02/12 07:44 PM
01/02/12 07:44 PM
JohnRR Offline
JohnRR  Offline
So this is a NEW build ? The ONLY 88cc head is the ebrock OPEN chamber, if they even still make them, and you don't want an open chamber unless you use a step head piston.
Re: 440 SOURCE SLEATH HEADS? [Re: JohnRR] #1148800
01/02/12 09:31 PM
01/02/12 09:31 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Relieve the chambers/unshroud intake valve to gain some chamber volume.
Can't really see the small variation from what John mentioned being a deal breaker for running pump swill. Heck, don't advance the cam as far if it's on the ragged edge, which doesn't appear to be the case.
