Page 3 of 3 1 2 3
Re: Going Racing... Finally almost 4 years ago......... [Re: Chris'sBarracuda] #1147938
01/05/12 02:19 AM
01/05/12 02:19 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
That an LSM took. Lance is a cool guy that makes some kick butt stuff. Find them here, or at Summit actually
http://www.lsmproducts.com/
Oh yeah IMO that is not the best pan out there, just sayin
Re: Going Racing... Finally almost 4 years ago......... [Re: Al_Alguire] #1147939
01/05/12 03:32 AM
01/05/12 03:32 AM
Arizona
Chris'sBarracuda Offline OP
Arizona
Would a scraper or different windage tray help..
Or just a different pan..
Going to order one of those SC-320's from LSM..
Chris..
Re: Going Racing... Finally almost 4 years ago......... [Re: Chris'sBarracuda] #1147940
01/05/12 04:31 AM
01/05/12 04:31 AM
iowa
wesw Offline
wesw  Offline
iowa
if you need the tool for removing the springs on the head i have one that i made when i was running the B1MC heads that you can have if you want it. it has a short shaft for one cylinder at a time with old B1 stands to hold it and the tool to push down on the retainer. let me know if you want it. wes
598 ci predator
Re: Going Racing... Finally almost 4 years ago......... [Re: wesw] #1147941
01/05/12 04:43 AM
01/05/12 04:43 AM
Arizona
Arizona
PM sent..
Chris..
Re: Going Racing... Finally almost 4 years ago......... [Re: Chris'sBarracuda] #1147942
01/05/12 12:42 PM
01/05/12 12:42 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Chris all I am going to ad here is that there is HP to be found with the proper oil pan. Reducing windage, reducing oil in suspension are the reasons why. Also a better baffled pan will make sure there is oil there on decel..Just sayin
I am sure everyone has used that Milodon pan and never had a problem. Then again how many of them have tried something different. Let the flaming throwing begin
Re: Going Racing... Finally almost 4 years ago......... [Re: Al_Alguire] #1147943
01/05/12 01:08 PM
01/05/12 01:08 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We ran a home made pan for years, then went to a 8 qt charlie oil pan and when I would lift it would lose oil pressure, I switched to the mil. 10 qt and never had a problem after that. Not saying you could or don't but it seemed like it was not enough oil left in the pan on at the end of the run.
Re: Going Racing... Finally almost 4 years ago........ [Re: Chris'sBarracuda] #1147944
01/05/12 01:47 PM
01/05/12 01:47 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
What size drain backs are you using to the pan. I am using 8's in the front and 10's in the back.
76 Duster work in progress
Re: Going Racing... Finally almost 4 years ago......... [Re: Chris'sBarracuda] #1147945
01/05/12 02:41 PM
01/05/12 02:41 PM
ohio
Rich970 Offline
Rich970  Offline
ohio
can i ask how much vacuum you are running ?
Re: Going Racing... Finally almost 4 years ago......... [Re: Rich970] #1147946
01/05/12 08:43 PM
01/05/12 08:43 PM
Arizona
Arizona
Don't have a gauge on it yet, but it's an Aerospace..
And it's wide open.
Drain backs are #8 on all 4..
Chris..
Re: Going Racing... Finally almost 4 years ago......... [Re: Chris'sBarracuda] #1147947
01/08/12 09:25 AM
01/08/12 09:25 AM
Arizona
Arizona
Checked the bearings.. All good..
When looking in the pan, we found a couple of small metal pieces.
They were black.. And Magnetic..
Timing chain coming apart.. Less than 20 runs..
JP Performance 5606T.. Just letting everyone know..
I've used these before with no issues..
Still can't figure out why we sucked the pan dry..
Chris..
Page 3 of 3 1 2 3
