interior paint codes #1147654
12/31/11 06:51 PM
12/31/11 06:51 PM
Fairfield Maine
hemi4speed Offline OP
Fairfield Maine
I will be respraying my B7 Dark blue interior. Fender tag is M6C B7.. I'm looking to spray it with a gun, looking for the PPG,Dupont,Sherwin Williams paint code #'s for the interior paint?
Re: interior paint codes [Re: hemi4speed] #1147655
12/31/11 09:58 PM
12/31/11 09:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
'69 DuPont #s, same for Dodge/Plymouth :
9643LH Baltic ("medium") Blue
9642L Sierra ("light") Blue
Both the above are "low gloss - A-pillars, console, garnish mldgs" and "need more flattening compound 2ozs/pint"
4983L Baltic ("medium") Blue Metallic
4982L Thunder ("bright") Blue Metallic
Those 2 are "gloss colors - inner doors, B-pillar, roof rails"
Re: interior paint codes [Re: topside] #1147656
01/01/12 01:25 AM
01/01/12 01:25 AM
Fairfield Maine
Fairfield Maine
Re: interior paint codes [Re: hemi4speed] #1147657
01/06/12 07:35 PM
01/06/12 07:35 PM
Fairfield Maine
Fairfield Maine
No luck! the local Motor supply, that sell Dupont gave them these Paint numbers, they tell me they cant get it? Called totallyauto, they dont have any in stock, and recommended to try another avenue.
Any help would be great.
Re: interior paint codes [Re: hemi4speed] #1147658
01/06/12 09:15 PM
01/06/12 09:15 PM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
I'll check my paint books for PPG numbers. I'm not sure whether or not the DuPont numbers listed are the right colors, but one thing I would recommend is getting them mixed in acrylic enamel rather than lacquer. The "L" on the end of the number means lacquer. Lacquer is getting harder to find. Check for availability of the same colors with an "A" on the end (4982A), that would be Centari acrylic enamel. Enamel would be much better for the upper door paint which should be glossy. Enamel can also be flattened for use on the trim pieces if needed.
Re: interior paint codes [Re: BLACKHEMIRR] #1147659
01/07/12 01:19 PM
01/07/12 01:19 PM
So. Illinois
bronze69 Offline
bronze69  Offline
So. Illinois
This is where I got mine for my 69 Roadrunner tan interior and it was dead on.
Previous post
Here is another good resource to find PPG codes, and even order paint.
Auto Color Library
Re: interior paint codes [Re: bronze69] #1147660
01/07/12 03:05 PM
01/07/12 03:05 PM
Fairfield Maine
Fairfield Maine
Thanks, I Sent Mike a PM.
