I got the channel fuzzies from a large OEM parts vendor and they were about $20 a side cheaper than mopar. Steve I have the parts numbers in the man cave if you need em. Yep. Expensive. That fuzzy that fits in the stainless back side piece... I think mine is A&M Softseal via Year One. They came with the car. BTW, the cats whiskers for inside and outside the glass I got from Fritz at FPAP. They make em and are top shelf IMHO.
Guys, I stopped by the local chrome place to check on prices for restoring the chrome. If I disassemble and they do all the strip and prep work, it's going to be $250-$280 per side and I reassemble. If they strip it and I polish them prior to chroming, It will be $120-$150 per side. So for a saturday's worth of sanding, I save half. Depending on how much Mike wants for his pieces I may go that way. I like new, but I have an engine to build...
Steve, Check out the link Scott posted above. It's great.
Lindy
