Re: What's different 70-71 vs 72-74 Wiper motors
[Re: magiccuda]
#1142757
12/23/11 10:28 PM
12/23/11 10:28 PM
Posts: 12,493 Western Colorado High Desert
moparmarks
For what model? 2-sp or 3? 70/2E and 71/2B til 9-71 had veriable speed then 3-sp after that. Bet RA 72 is not correct either. Stating in 73 all -3speeds had a plastic cover
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: NachoRT74]
#1142763
12/24/11 02:35 PM
12/24/11 02:35 PM
moparmarks
Hi Nacho The motor in the upper pic has the plastic cover over the wire connections, thats the 73-up style. Lower one has resin thats the 72-down sytle. Heres the early 72B/E 534 V-spd.
[Re: BDW]
#1142764
12/24/11 02:39 PM
12/24/11 02:39 PM
moparmarks
I'm just looking for the cheapie 2-speed for a 70.
They all have the same hoods, so the lower park position doesn't make sense. I'd guess the wiring harness is different.
Hoping someone has gone through this already.
You need a 929 2-sp which fits 70/1E, 71B 69/71C
[Re: 73rrak]
#1142770
12/24/11 05:02 PM
12/24/11 05:02 PM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
I was thinking on that as a posibility HOWEVER, Once I got a NOS repairing kit and on instruction sheet never said something about the year, and included a big list of wiper motor PNs including earliers. The kit included the threated shaft.
I would say really the clip its at CRANK side of main linkage and not to the motor shaft side
[Re: DANA60]
#1142772
12/26/11 02:12 AM
12/26/11 02:12 AM
moparmarks
The 71 and the 72 are not a straight interchange. The crank to wiper lingakge are a little different and if you use a 72 motor on a 71 (or vice versa) it won't bolt up to the crank arm. The 71 is the last year for the red epoxy on the front wire, the 72 is left bare (I think they put a plastic cover after that). The direct cowl boltup is the same, and the wire harness is the same. Two speed switches will not work on a var/3 speed, or vice versa.
Mo Mopar was horrible on the interchange between years in the 70's. I'm sure it had to do with sub contractor suppliers.
Even a different crank between the two 72B/E V-spd #534 and the 3-spd #624. Also both these 72 motors had resin or red epoxy. Again 73 was the first year for the plastic cover. 70-2 linkage has brass bushings and the big round clips. 73-up had push in nylon bushings. Very little will interchange or work between 72-down and 73-up.
[Re: DANA60]
#1142773
12/30/11 11:58 AM
12/30/11 11:58 AM
NachoRT74
Valencia, España
PN application: Part#/Stamp# Year-Yr Body Speed Remarks 2525629 1964-66 A VARIABLE 2525270 1964-65 B SINGLE 2580915 1967 B VARIABLE 2584975 1965 C VARIABLE 2586988 1966-67 C 2/3 SPEED 2587697 1968 B 3-SPEED LATE 2770090 1968 C 2-SPEED 2770090 1969-71 A 2-SPEED 2770090 1969-70 B 2-SPEED 2770147 1966-67 AB VARIABLE WHITE SW PLATE PARTS 2808767 1967 AB VARIABLE LATE ALUM/BLACK PARTS 2808767 1968 B 3-SPEED EARLY ALUM/BLACK PARTS 2808801 1966 B VARIABLE WHITE SW PLATE PARTS 2808801 1967 AB VARIABLE WHITE SW PLATE PARTS 2822252 1968 AB 2-SPEED 2822962 1967-68 AB VARIABLE LATE ALUM/BLACK 2822963 1966-67 AB VARIABLE EARLY WHITE SW PLATE 2822965 1967 B VARIABLE 2889982 1968 B 3-SPEED LATE PARTS 2926919 1969-71 C 3-SPEED PCDY 2926929 1969-71 C 2-SPEED 2926929 1970-71 E 2-SPEED 2926929 1971 B 2-SPEED 2983033 1969 B 3-SPEED EARLY 2983116 1969-71 A VARIABLE 2983116 1969 B 3-SPEED LATE 2983116 1970 B 3-SPEED 3004112 1968 C 2-SPEED 3004114 1968 A VARIABLE 3004114 1968 B 3-SPEED LATE 3431077 1970-71 E VARIABLE 3431077 1971 B VARIABLE 3431531 1972 A 2-SPEED UP TO 6/5/72 3431532 1972 A VAR-3SP 3431533 1972 BCE 2-SPEED UP TO 6/5/72 3431534 1972 BE VAR-3SP UP TO 9/1/71 3431535 1972 C VAR-3SP 3431605 1972 A 2-SPEED AFTER 6/5/72 3431605 1973 A 2-SPEED UP TO 2/1/73 3431606 1972 BCE 2-SPEED AFTER 6/5/72 3431606 1973 BCE 2-SPEED UP TO 2/1/73 3431624 1972 BE VARI-3SPD AFTER 9/1/71 BLACK CAP 3431665 1973 BE VARI-3SPD 3431666 1973 C VARI-3SPD 3431718 1973 BCE 2-SPEED AFTER 2/1/73 3431730 1973-74 A 2-SPEED AFTER 2/1/73 3431780 1974 C 3-SPEED 3431790 1974 BCE 2-SPEED 3431905 1974 A 3-SPEED 3431906 1974 BE 3-SPEED 3620877 1973 A VARI-3SPD ( I thought this file was missed around http://web.archive.org/web/20050117073829/http://www.wiperman.homestead.com/Motor_part_numbers.html )
