Need help IDing Original 340 T/A Oil Pan #1142462
12/23/11 02:06 PM
12/23/11 02:06 PM
Long Island, NY
Jstern Offline OP
Jstern  Offline OP
Long Island, NY
I am trying to help a friend source a correct oil pan for his AAR. Would anyone have any pics or a description of it? I tried searching the archives but had no luck. Thx
Re: Need help IDing Original 340 T/A Oil Pan [Re: Jstern] #1142463
12/23/11 02:58 PM
12/23/11 02:58 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
They were no different than any other same vintage 340 pan. The only number I've seen on confirmed originals were stamped with a large "294" in the bottom sump. I've seen similar vintage pans that looked identical but had 394 stamped into the same area, also likely correct but I haven't seen an unmolested original to confirm it. There are a lot of small block pans made that are the same shape and size, both new and used, but the style with the stamped in 294/394 numbers are not reproduced, used market only.
Re: Need help IDing Original 340 T/A Oil Pan [Re: ScottSmith_Harms] #1142464
12/23/11 03:28 PM
12/23/11 03:28 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yep - 294 pan
Re: Need help IDing Original 340 T/A Oil Pan [Re: Morty426] #1142465
12/23/11 03:33 PM
12/23/11 03:33 PM
Salinas, California
1970Cuda Offline
super street
1970Cuda  Offline
super street
Salinas, California
The 294 pan is 70-72 318 and 340's. Good luck finding a clean undented pan.
Re: Need help IDing Original 340 T/A Oil Pan [Re: 1970Cuda] #1142466
12/23/11 04:11 PM
12/23/11 04:11 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I'm pretty sure I have one
Re: Need help IDing Original 340 T/A Oil Pan [Re: Morty426] #1142467
12/24/11 03:42 AM
12/24/11 03:42 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
294, not to hard to find
