Page 2 of 6 1 2 3 4 5 6
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: 70dusterjohn] #1140813
12/21/11 08:54 PM
12/21/11 08:54 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
The only other thing I can suggest is to buy a cheapo diaper and make it fit. I know of one racer that sliced and diced one and it is half back together with velcro holding it up. Tech guy looks from above and sees diaper straps and says OK. Rulebook doesn't say anything about modifying them, or requiring that they work.
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: 70dusterjohn] #1140814
12/21/11 08:57 PM
12/21/11 08:57 PM
ill
dennismopar73 Offline
ill
contact D R E they can even help with custom stuff on diapers,
as for me I will have one , It's one of those rules they shouldn't have to have , but with the speeds getting ever faster, and the use of sythetic oils, we as racers should have been doing this on our own and not have to have it pushed on us! Maybe some of these crashed drag cars and injured racers, never would have happened?
just a thought
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: dennismopar73] #1140815
12/21/11 09:37 PM
12/21/11 09:37 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
This rule i can agree with, i was planning on putting one on my bracket car.
Kevin
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: roadhazard] #1140816
12/21/11 10:03 PM
12/21/11 10:03 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If this is the case, anybody want to buy a iron headed 448 incher?
I have a 225/6 I can just build. Sure would be less hassle
GREG,,,,???..!!!..it looks like a business opportunity to me!!!
Build DIAPERS,,,I'm sure you have a backload inventory of gaskets..get to work,,,expand your business,,make diapers for all of us!! I will let you use my car for a pattern...just come on down..
If you like drag racing, support your local track.
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: 604 Hemi GTX] #1140817
12/21/11 10:15 PM
12/21/11 10:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Kevin
Weather I agree or dis-agree I'm getting REALLY FEED UP
with that useless bunch of money grabbing A$$ holes
telling me what I have to do all the time with my
money... thank GOD I dont need a SFI one where it
needs to be re-certed every year... I guess I wont
attend any NHRA events
FLAME ON guys... I dont care
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: MR_P_BODY] #1140818
12/21/11 10:38 PM
12/21/11 10:38 PM
old westchester
mcat4321 Offline
mcat4321  Offline
old westchester
this topic cracks me up.. in the grand scheme of things with all the other money tied up in your cars, whats another $200 for your protection and the protection of other?...and the time it will save in clean ups. plus synthetic oil is a [Edited by Moparts - Family Friendly Site - Keep it clean] to clean up...its like bitching about having to buy a helmit, why should anyone else care if you bash your skull while crashing? its for the greater good.. heres some help.
Ram Jet Racing will be offering custom and universal engine diapers at a discounted price. These are top quality NHRA approved engine diapers.You can contact Adam at S&M MOTORSPORTS (513-236-2355) to place your orders.
Universal diaper-140.00
Custom diaper- 200.00
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: MR_P_BODY] #1140819
12/21/11 10:41 PM
12/21/11 10:41 PM
Guitar Jones Offline
I'm just going to build a bellypan out of left over stuff I have here.
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: MR_P_BODY] #1140820
12/21/11 10:50 PM
12/21/11 10:50 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
On one hand, there's no such thing as "too many" safety devices....within reason for the car's ET/Speed.
I haven't seen too many oil downs at the bracket level around here in the last couple of years.
That said, the rule making them required for S/ST (an entry level class, by the way...hahahaha) makes S/ST for us a NO GO for this year. If/when they require one for a 10-sec bracket car, we will slow it down to the low-11's...or put it back on the street. That means we're NOT spending $2000 on a Dana, $2500 on a t-brake 727/converter which is money NOT being spent with those vendors. So in our case, everyone loses.
Reason it's deal breaker for us is...NO WAY am I getting a diaper on the Duster with a drag link through the pan and 1 7/8" Hookers that nearly touch the pan in 2 places are in the way of everything.
Therefore, a tube k-member, motor plate, R&P steering and coil overs, new headers and oil pan would be required. At $5000-$6000-PLUS THAT aint happening. OR, MAYBE we could make it work with a motor plate, new oil pan and custom fenderwell headers. That alone is a $1500-$2000 fix. Screw that.
NHRA is doing all they can to reduce car counts even further. This might have been a better idea when there is some economic stability in this country and people are back to work.
Of course to complete my RANT, if it were up to me, S/ST would be limted to 130-or less MPH, with NO electronics, OEM front end and OEM rear frame rails and limited to a max 10.5" wide tire. You know, ENTRY LEVEL. The class has really become Stupid STreet allowing tube frame 150+ mph cars.
Thanks for listening, I'm done!
Merry Christmas!
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: cudadoug] #1140821
12/21/11 10:53 PM
12/21/11 10:53 PM
old westchester
mcat4321 Offline
mcat4321  Offline
old westchester
Merry Christmas!
just build a belly pan.... problem solved
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: mcat4321] #1140822
12/21/11 11:07 PM
12/21/11 11:07 PM
cudadoug Offline
cudadoug  Offline
Belly pan?
The belly pan must extend
from framerail to framerail and extend forward of the harmonic
balancer and to the rear of the engine block and must incorporate a
minimum 2-inch-high lip on all sides unless specified in Class
Requirements. Minimum number of slots or holes in the walls to
clear frame, steering, or lines permitted. A nonflammable, oil-
absorbent liner mandatory inside of retention device.
Funny you say that. I was under the car for 2 hours with cardboard and scissors when I heard about it last year. NO GO with an OEM k-member!
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: WadeMetzinger] #1140823
12/21/11 11:20 PM
12/21/11 11:20 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I'm sure all these people that are too lazy to drain their antifreeze before they go to the track will be all over installing diapers.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: Evil Spirit] #1140824
12/21/11 11:36 PM
12/21/11 11:36 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
well it looks like getting ride of my ride may have been a good thing NHRA is getting worst by the day.
I have been looking at a bike to get back to going fast on the cheap and it keeps looking better and better.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: MR_P_BODY] #1140825
12/21/11 11:36 PM
12/21/11 11:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Kevin
I her ya Mike and agree.............when they ask me how fast my car goes I`m gonna tell em it went 11.20`s last time out and that I just freshoned it up and am hopeing for 11.00 flat.
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: Thumperdart] #1140826
12/21/11 11:40 PM
12/21/11 11:40 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
summit diaper 139.00 jegs 80.00 with shipping on sale prices r in racer program pricing!!!!!!not sfi approved nhra only
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: pattyboy 572] #1140827
12/22/11 12:50 AM
12/22/11 12:50 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
whats gunna happen first time someone throws a rod through a diaper and oils down the trak,KEVLAR?
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: bonefish] #1140828
12/22/11 01:31 AM
12/22/11 01:31 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
If you go on yellow Bullet and search you find some good threads on the belly pans. AND you be surprised the NHRA seems to accept a lot less than you read in the rule book about a belly pan. Also on here if you look in the Silverfish progress/chassis build thread there is a pic of a pretty nice belly pan, also Bigtime bob has one on his car. Hey look this really is a Pain but if you kick a rod or whatever, you prob be very happy you or the guy in the other lane had one.
....BAD A$$ STREET CAR.....
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: n20mstr] #1140829
12/22/11 05:43 AM
12/22/11 05:43 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I was hoping for a street car like my 63 I dont have to use one. I mean I only race a few times a year mostly at T & T's as I enjoy running the car every now and then. But I drive it on the street 99% of the time so I hope they dont make me put one on now that I have hit the high 10's. I will do what I have to so I can still race it a few times a year but I wont put one on my 63 unless I have too. Ron
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: 383man] #1140830
12/22/11 10:27 AM
12/22/11 10:27 AM
ill
ill
Why is everyone making this out to be a big deal?
#1 saves down time
#2 save your car
#3 save your guys car next to you
#4 some tracks have been awarding you if you run one anyways
#5 it is a smart thing to have, like it or not.
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: WadeMetzinger] #1140831
12/22/11 11:02 AM
12/22/11 11:02 AM
oh
julian2007 Offline
julian2007  Offline
oh
I know they are a pain in the butt,but the gain in safety out weighs the pain in the but factor.A good friend of mine broke a rod going threw the traps put two holes in the block you could put your fist threw at 150mph.No oil on the track and didn't wreck,saved a two hour cleanup,his car and maybe his life.Its a great Idea guys think about how many times you sat waiting on a clean up I bet you could cut that time by 75% or maybe a containment tray
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: julian2007] #1140832
12/22/11 11:15 AM
12/22/11 11:15 AM
tboomer Offline
tboomer  Offline
Even if it is an option for a slow pooch like mine...It isn't that bad of an idea. I can live with it. I have seen mid 11 second cars puke thier guts out on the track. So yeah...I will go ahead and get one..
