wish bone direction #1140311
12/20/11 09:42 PM
12/20/11 09:42 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
does it matter which way it's installed. Pointing forward or back. Is one better than the other. Thks Danny
Re: wish bone direction [Re: plycuda] #1140312
12/20/11 09:44 PM
12/20/11 09:44 PM
ill
dennismopar73 Offline
ill
I was going to put one on my car, it would have pointed to the front
Re: wish bone direction [Re: plycuda] #1140313
12/20/11 09:45 PM
12/20/11 09:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doesnt matter... I have the single point on the diff
Re: wish bone direction [Re: MR_P_BODY] #1140314
12/20/11 09:59 PM
12/20/11 09:59 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
hey dan, the wide spacing or the wide part of the y should be towards the front of the car.the rear could still swing in a arc if you put the single attaching point to the front.
Re: wish bone direction [Re: webemopes] #1140315
12/21/11 02:43 AM
12/21/11 02:43 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
What???
Re: wish bone direction [Re: plycuda] #1140316
12/21/11 10:29 AM
12/21/11 10:29 AM
ky
68roadrunner Offline
ky
either will work. see them both ways.
Re: wish bone direction [Re: 68roadrunner] #1140317
12/21/11 12:31 PM
12/21/11 12:31 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
if you have a steel housing like a 8-3/4 or a 9 inch I would mount a the singe side to the rear houseing . If you run a cast houseing like a dana or a 12 bolt GM . I would weld the singe to the Chassi.
Just my
