Re: electrical help please
[Re: Tadams]
#1140202
12/21/11 06:01 PM
12/21/11 06:01 PM
Posts: 5,450 So Cal
Sinitro
So Cal
The red wire shows 12.5 volts and the black wire shows the same. so the problem comes after that point. Its strange that when this happens I have no lights or anything else. The ignition switch is dead, but I will find it. I think I have another wiring harness if I had to change that I could. Not one of those projects I wanted to do, but if it would solve this than maybe I should. There is no power at the fuse box, I think you had ask me earlier.
Having 12V @ the amp guage means little as those lines are always hot, even when the ignition is OFF.. Go to the middle bulkhead connector and check the fusible link for continuity..
Post back your results..
Just my $0.02...
