Re: FLUID DAMPER COATING???
[Re: Labratt]
#1139841
12/20/11 11:59 AM
12/20/11 11:59 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
powder coat it..... I cant see why it would have more heat that the valve covers or intake....actually less IMO
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Labratt]
#1139842
12/20/11 12:02 PM
12/20/11 12:02 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
i just used crylon/rustolium rattle can after cleaning good/prep.
[Re: Labratt]
#1139844
12/20/11 12:24 PM
12/20/11 12:24 PM
Posts: 8,862 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I don't believe it can be powder coated,because of the heat factor!
I don't know what make yours is but some are tig welded together with the fluid in them so I can't see the heat affecting them.
If you do powder coat it make damn sure you tape off the bore 'cause you'll never get the powder off afterwards.
[Re: Labratt]
#1139845
12/20/11 12:28 PM
12/20/11 12:28 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I sanded mine down real good and used some rattle can black engine paint.
[Re: Labratt]
#1139847
12/20/11 12:51 PM
12/20/11 12:51 PM
Clanton
northern,Ohio,USA
you can flame over the rattle can paint with a burns o matic torch quickly and help hardin the paint.
[Re: Labratt]
#1139848
12/20/11 01:07 PM
12/20/11 01:07 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I've got a fluid damper on my 440 that needs to be re-finished...paints peeling off. Would an epoxy paint be a good choice? What have you guys used for durable...long-lasting results?I don't believe it can be powder coated,because of the heat factor! Thanks in advance!
its all in how you prep the suface,painting is painting.i painted mine with single stage urethane 7 years ago,still looks good.SURFACE PREP!
