What the He** is this intake #1139149
12/19/11 09:10 AM
12/19/11 09:10 AM
OMAHA
poly Offline OP
poly  Offline OP
OMAHA
I have a max wedge intake #2465165, I can not find squat for information on this manifold, anyone know anything about them as far as performance goes???
I am figureing on using it on my current 440/max wedge build with a 750 Demon on it,,,,, any thoughts
Re: What the He** is this intake [Re: poly] #1139150
12/19/11 09:29 AM
12/19/11 09:29 AM
Lehigh Acres, Florida
rickstershemi Offline
426 2x4 64 Max Wedge / Aluminum 2465165
Rickster
Re: What the He** is this intake [Re: rickstershemi] #1139151
12/19/11 12:41 PM
12/19/11 12:41 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Poly,
From your post it sounds like a single 4 manifold, although Rickster's description sounds otherwise. Picture would help, but if its a single Max-Wedge port, it's probably an early NASCAR manifold, there were two styles that I'm aware of, both were cast with an integral valley pan, the last one was cast with an open area between the runners and valley to keep the heat off the carb and raise the runners more in line with a hi-rise 427 Ferd Nascar head. The earlier version had flatter runners. I had one of each back in the day, my dad ran a Stg III in a late model modified, they were great manifolds at the time, not sure how they would compare today with what is now available, but still wish I had hung on to them...
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: What the He** is this intake [Re: 23T Hemmee] #1139152
12/20/11 12:04 AM
12/20/11 12:04 AM
OMAHA
poly Offline OP
poly  Offline OP
OMAHA
It is a single four, it was originally a dual plane, but someone has cut alot of the divider out of it, my other car is an automatic with crossram, was hoping that the one I am building B-body 440 maxwedge heads 4-speed car will be a little more street friendly with the single 4
Re: What the He** is this intake [Re: poly] #1139153
12/20/11 12:17 AM
12/20/11 12:17 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Are you sure it isn't like the one in this thread?
https://board.moparts.org/ubbthreads/show...amp;Search=true
What carb flange does it have?
Re: What the He** is this intake [Re: Jeremiah] #1139154
12/20/11 12:35 AM
12/20/11 12:35 AM
OMAHA
poly Offline OP
poly  Offline OP
OMAHA
Not sure on the flange, I beleive that someone has opened up the flange area, but no it is not like that one, this has valley pan made on it, and an air gap betwen plenums and valley
Re: What the He** is this intake [Re: poly] #1139155
12/20/11 12:38 AM
12/20/11 12:38 AM
OMAHA
poly Offline OP
poly  Offline OP
OMAHA
ok,,,,,,if I imangine some flange area added to mine it could be very close, but mine is a different # and says revision B on it right below the number
Re: What the He** is this intake [Re: poly] #1139156
12/20/11 03:14 AM
12/20/11 03:14 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
It sounds like you've got the one I described above. The picture is of the earlier flat runner design, considering what was available at the time, either manifolds were good but the one you're describing had longer, more direct runners than the earlier version. Either way, you've got a pretty rare piece that should be way more street friendly than the cross ram.....enjoy....
Ronny
John 14:6
Re: What the He** is this intake [Re: 23T Hemmee] #1139157
12/20/11 12:54 PM
12/20/11 12:54 PM
OMAHA
poly Offline OP
poly  Offline OP
OMAHA
Cool,,, thank you, I would still like to see a pic of a stock one, as I had stated earlier it appears that some one has done some hacking on this one, I am assuming that it originally had a square bore flange on it, mine is opened up so as to appear as one big opening with part of the division barier removed so as is not a true dual plane anymore,,,,,hopefully they have not totally ruined it's flow
Re: What the He** is this intake [Re: poly] #1139158
12/20/11 01:15 PM
12/20/11 01:15 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Good Morning,
I located an article that shows some pics of that particular later style (better IMO) manifold with the built in valley tray. It is over 7MB so I would have to email it to you. Also, I will stop in and see if that '63 Hotrod is still hanging around and snap some pictures of it. IIRC it had some engineering diagrams from Dragmaster.
PM me your email and I can send you what I have.
Re: What the He** is this intake [Re: Jeremiah] #1139159
12/21/11 12:41 AM
12/21/11 12:41 AM
OMAHA
poly Offline OP
poly  Offline OP
OMAHA
Ok,,,,will do
