Re: What the He** is this intake
[Re: rickstershemi]
#1139151
12/19/11 12:41 PM
12/19/11 12:41 PM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
Poly, From your post it sounds like a single 4 manifold, although Rickster's description sounds otherwise. Picture would help, but if its a single Max-Wedge port, it's probably an early NASCAR manifold, there were two styles that I'm aware of, both were cast with an integral valley pan, the last one was cast with an open area between the runners and valley to keep the heat off the carb and raise the runners more in line with a hi-rise 427 Ferd Nascar head. The earlier version had flatter runners. I had one of each back in the day, my dad ran a Stg III in a late model modified, they were great manifolds at the time, not sure how they would compare today with what is now available, but still wish I had hung on to them...
[Re: poly]
#1139155
12/20/11 12:38 AM
12/20/11 12:38 AM
Posts: 65 OMAHA
poly
OMAHA
ok,,,,,,if I imangine some flange area added to mine it could be very close, but mine is a different # and says revision B on it right below the number
[Re: 23T Hemmee]
#1139157
12/20/11 12:54 PM
12/20/11 12:54 PM
Posts: 65 OMAHA
poly
OMAHA
Cool,,, thank you, I would still like to see a pic of a stock one, as I had stated earlier it appears that some one has done some hacking on this one, I am assuming that it originally had a square bore flange on it, mine is opened up so as to appear as one big opening with part of the division barier removed so as is not a true dual plane anymore,,,,,hopefully they have not totally ruined it's flow
[Re: Jeremiah]
#1139159
12/21/11 12:41 AM
12/21/11 12:41 AM
Posts: 65 OMAHA
poly
OMAHA
