Help identify these Hemi Heads..... *PICS* #1138894
12/18/11 06:21 PM
12/18/11 06:21 PM
NY
B1duster Offline OP
B1duster  Offline OP
NY
Can anyone tell me exactly what these are ? I know they are stage v custom, but thats all. The inside diameter of the intake seat measures 1.990 and the exhaust seat is 1.590. What would the valve sizes be, standard or bigger ? Are the exhaust ports raised or in the standard location ? Thanks
Re: Help identify these Hemi Heads..... *PICS* [Re: B1duster] #1138895
12/18/11 07:18 PM
12/18/11 07:18 PM
NY
B1duster Offline OP
B1duster  Offline OP
NY
Ok Im guessing standard valves. Does the exhaust look raised or standard ? Thanks
Re: Help identify these Hemi Heads..... *PICS* [Re: B1duster] #1138896
12/18/11 07:57 PM
12/18/11 07:57 PM
Contact Stage V and ask them Make sure to have the casting numbers and port dimension ready to give them They look like the standard replacement 426 Street Hemi heads to me, but its been a while since I put the last set I worked on and put on a motor
Re: Help identify these Hemi Heads..... *PICS* [Re: B1duster] #1138897
12/18/11 08:00 PM
12/18/11 08:00 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Raised. Really with the unfinished work, you can raise them a little more or lower them if u need to. I am assuming there is enough metal around them to go either way. Have u thought of calling Stage V and discussing with them
Old Geezer Racing
Re: Help identify these Hemi Heads..... *PICS* [Re: Cab_Burge] #1138898
12/18/11 08:04 PM
12/18/11 08:04 PM
NY
B1duster Offline OP
B1duster  Offline OP
NY
Thanks, but I think these are a different casting. The replacements dont have the dualplug option. I tried Stage V, no email response, and no one answering the phone. Thanks again
Re: Help identify these Hemi Heads..... *PICS* [Re: B1duster] #1138899
12/18/11 09:35 PM
12/18/11 09:35 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
look like the one of the valves is rotated angle? Look like lots of room between the seats on those....
Stock replacement heads have standard lay out's i know...
Re: Help identify these Hemi Heads..... *PICS* [Re: Bob_Coomer] #1138900
12/18/11 10:41 PM
12/18/11 10:41 PM
NY
B1duster Offline OP
B1duster  Offline OP
NY
Ok, I read that on the custom head they move the exh 2 degrees for larger valves, but the seats dont seem to be oversized
Re: Help identify these Hemi Heads..... *PICS* [Re: B1duster] #1138901
12/18/11 11:51 PM
12/18/11 11:51 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I know they rolled the valves to help valve to valve clearance with large cams.. It was a problem with stock valve heads and large roller cams with narrow centers.
Re: Help identify these Hemi Heads..... *PICS* [Re: B1duster] #1138902
12/19/11 06:35 AM
12/19/11 06:35 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
the method of mesurement may be misleading .
if they are fresh heads the seats may not be done yet.
measure another head with a valve of known size. wedge or hemi. then see how those numbers work out in regard to what you have on the Hemi head
home of the
Sox and Martin Hemi Duster
Re: Help identify these Hemi Heads..... *PICS* [Re: HEMIFRED] #1138903
12/19/11 11:10 AM
12/19/11 11:10 AM
s e mich
ro23car Offline
ro23car  Offline
s e mich
i think what you have is the next step up from the replacement head,with would be the raised port head.
Re: Help identify these Hemi Heads..... *PICS* [Re: ro23car] #1138904
12/19/11 02:02 PM
12/19/11 02:02 PM
NY
B1duster Offline OP
B1duster  Offline OP
NY
Ok I just found this ...
STAGE V CUSTOM HEADS
Price: $2,350.00
Quantity:
Brief DescriptionDetailed DescriptionSpecifications#S-426
(CLICK ON IMAGE) If you are building a high output motor based on an original or aftermarket 426 HEMI type block, these heads are for you. They have larger than stock intake ports and are capable of supporting as much power as you can build around them. In fact these heads hold the speed record at Bonneville for a wheel driven vehicle at 433 mph. Optional raised exhaust ports offer exceptional gains in breathing. Intake valve can 2.250 to 2.400 and exhaust can be from 1.900 to 2.000. Cumbustion chamber 168
It seems they have 3 different castings, the replacement, the custom -these, and the millenium. Im pretty sure the custom is what I have. ....My question is would the Custom head come with different seats depending on intended valve size or is it the same seat for 2.25 to 2.40 ? ? ? Thank you very much for your time guys
Re: Help identify these Hemi Heads..... *PICS* [Re: B1duster] #1138905
12/19/11 03:36 PM
12/19/11 03:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is the outside diameter of the set in the head in the picture ?
Re: Help identify these Hemi Heads..... *PICS* [Re: JohnRR] #1138906
12/19/11 04:07 PM
12/19/11 04:07 PM
NY
B1duster Offline OP
B1duster  Offline OP
NY
about 2.25
Re: Help identify these Hemi Heads..... *PICS* [Re: B1duster] #1138907
12/19/11 04:58 PM
12/19/11 04:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
about 2.25
You won't get a 2.40 on that so I think you have your answer.
Re: Help identify these Hemi Heads..... *PICS* [Re: B1duster] #1138908
12/19/11 06:38 PM
12/19/11 06:38 PM
The set of Stage V heads I had looked a lot like yours, the smallere exhaust ports, drill and machined for the future use of dual plugs and so on They where purchsed by the original owner to use on a seroius SS/AA car, he forgot to cll NHRA before buying them to see if they where on the approved replacemnt head list, they weren't So my customer bought them at a good price and we used them on his blown street Hemi project Stage V is really hard to get contact with, there way to busy, I guess, to take care of new business
Re: Help identify these Hemi Heads..... *PICS* [Re: B1duster] #1138909
12/19/11 06:49 PM
12/19/11 06:49 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Here are pics of replacement heads.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Help identify these Hemi Heads..... *PICS* [Re: Hemi Allstate] #1138910
12/19/11 06:51 PM
12/19/11 06:51 PM
Mt. Eden Ky.
Mt. Eden Ky.
2nd
1996 Ram 1500 Sport
1968 road runner
Re: Help identify these Hemi Heads..... *PICS* [Re: Hemi Allstate] #1138911
12/19/11 06:54 PM
12/19/11 06:54 PM
Mt. Eden Ky.
Mt. Eden Ky.
Intake side
1996 Ram 1500 Sport
1968 road runner
Re: Help identify these Hemi Heads..... *PICS* [Re: Hemi Allstate] #1138912
12/19/11 06:58 PM
12/19/11 06:58 PM
Mt. Eden Ky.
Mt. Eden Ky.
1996 Ram 1500 Sport
1968 road runner
Re: Help identify these Hemi Heads..... *PICS* [Re: Hemi Allstate] #1138913
12/20/11 03:25 AM
12/20/11 03:25 AM
NY
B1duster Offline OP
B1duster  Offline OP
NY
Thanks guys, I spoke to a stage v dealer today and was told the heads are machined, seats installed as per order. So it looks like these were ordered with standard valves. So should I get them cnc'd and assembled or get the new Indy 426 Hipo ??? Will be going on a 588 - street strip car show cruizer,.... with an 8-71.
