Re: ATTN MSHRED
[Re: n20mstr]
#1138560
12/18/11 09:21 PM
12/18/11 09:21 PM
Posts: 3,414 Toronto
mshred
Toronto
Heres the Radiator you looking for kid, If you look around you can find them cheaper, but this pretty much bolts right up to your rad support and it weighs only 9 - 10 lbs Upper hose i use is for a late 90's gm truck with a big block and lower hose i use (for big block guys) is for 86-89 mustang gt http://www.autopartswarehouse.com/sku/Ma...tings+Clearance
LOL thanks for getting back to me Tony! Nice of you to post the info up here too for everyone to see
If I can figure out a way to make the outlets work with my smallblock this could be a great way to go. Thanks!
Re: ATTN MSHRED
[Re: n20mstr]
#1138563
12/19/11 11:35 AM
12/19/11 11:35 AM
Posts: 793 Utah
topbrent
Utah
Thats the rad i have run in my car for the last 12 years, i have to replace it becasue the top tank has a crack that even repaired is coming back (plastic tank) I figure the wheelstands have stressed it. Works Great for a big block and the hoses i listed are like factory fit. In the summer on the street my car runs about 190 with this rad. The nice part it has two bolts per side and it sits nice against the rad support. Mark the 4 holes and drill. thats it bolts right in. AND the best part its prob half the weight of the alum rads out there...Perfect for a limited street use car and race car...CHEAP too...LOL
Any pics of your installed setup?
When you say limited street, could you expound on this a bit?
Could it cool a basic big block street/strip car, or it asking a bit much of the design?
Re: ATTN MSHRED
[Re: topbrent]
#1138564
12/19/11 12:20 PM
12/19/11 12:20 PM
Posts: 4,673 On the parachute mount
n20mstr
I SAy "limited" street use because thats all i used it for, My car has a 5 gal cell and i have not driven it in traffic , 50+ miles etc. Now i have driven around town etc and car shows in 90+ heat. Keeps my big block coll about 190ish and all i have is the old school elec w/p drive on a stock water pump and a 16" elec fan. Would it work in a daily driver? im not 100% sure. BUT it is very light, cheap , fits good.
....BAD A$$ STREET CAR.....
Re: ATTN MSHRED
[Re: Ari440]
#1138567
12/19/11 09:54 PM
12/19/11 09:54 PM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
im using a 1995 nissan maxima radiater and electric fans
What does it look like... is it a down flow??? Does it install like a stock rad??
Re: ATTN MSHRED
[Re: Ari440]
#1138569
12/19/11 10:17 PM
12/19/11 10:17 PM
10.90 Racer
super street
super street
Ont. Canada
heres a pic
need the four brackets to hold it up ,two on top two on bottem
got the setup from a junkyard
Thanks looks god
How much weight do you think you saved??
Re: ATTN MSHRED
[Re: Ari440]
#1138571
12/19/11 10:37 PM
12/19/11 10:37 PM
10.90 Racer
super street
super street
Ont. Canada
dont know exact weigth saving but alot ligther then the jegs uneversal alum radiater I had before
So considerably much lighter than my stock rad...........
Re: ATTN MSHRED
[Re: mshred]
#1138574
12/20/11 01:58 AM
12/20/11 01:58 AM
Posts: 5,618 long island NY
Ari440
long island NY
Ari, do you street drive the duster at all? What kinda temps does it see?
local street driving ,using a stock waterpump setup with a 4 inch underdriven bottem pulley and no thermostat
*180 - *200
1.39 9.85 - 137 mph
Re: ATTN MSHRED
[Re: Ari440]
#1138575
12/20/11 12:38 PM
12/20/11 12:38 PM
mshred
Toronto
*180 - *200
pretty good! I think I need to take a trip to the scrap yard and see what I can find in aluminum lightweight factory rads that may have the hose inlets on correct side for an SB....just not sure how I can get a hose from the passenger side of the motor to go all the way to the driver side inlet on the rad lol
