Re: Stage VI heads?
[Re: BloFish]
#1138486
12/18/11 02:19 PM
12/18/11 02:19 PM
I just bought a set from FHO, used for one dyno session only. Their prices on the web site are $2500 a pair for bare castings and $2500 for all the machining. Tim Banning told me the heads can go $10,000, and I was lucky and got a smoken deal.
Re: Stage VI heads?
[Re: hemi-itis]
#1138489
12/18/11 02:33 PM
12/18/11 02:33 PM
They are referring to the wedge heads. ![](/ubbthreads/images/graemlins/wiink.gif)
http://www.moparmusclemagazine.com/techa...alve_specs.html
Sorry, still asleep.
Re: Stage VI heads?
[Re: ]
#1138490
12/18/11 02:37 PM
12/18/11 02:37 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
No,it's YOUR Hemi-itis that has takin' control of your brain ![](/ubbthreads/images/graemlins/laugh2.gif)
Re: Stage VI heads?
[Re: hemi-itis]
#1138491
12/18/11 02:56 PM
12/18/11 02:56 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
i was gonna say I bought my 440 complete w/ ported stage VI heads and solid roller cam for 3k...
Re: Stage VI heads?
[Re: Mopar_Ray]
#1138494
12/18/11 04:18 PM
12/18/11 04:18 PM
Posts: 1,402 State of Corruption
camdog440
State of Corruption
from mopartsracing.com... it says EACH ![](/ubbthreads/images/graemlins/shock.gif) I'd call to be sure. CNC-Ported Stage VI Aluminum Cylinder Heads These unique CNC-ported heads feature special machining for longer valves, allowing for a deeper port in the critical short turn area. With port profiles developed by Chapman Racing, these exclusive heads feature state-of-the-art design for maximum flow over the entire lift curve. Available in two versions: standard port window with a 260 cc intake port, or Max Wedge with a 286 cc intake port. Both set the standard in Big Block fl ow efficiency for their respective port size. P4876383 requires the use of Rocker Shaft Stands (P5007742), 5.40" length, and 11/32" diameter valves. P4876386 CNC-Ported Stage VI Aluminum Cylinder Head 2.25" Intake, 1.81" Exhaust (Max Wedge) 2420.00 each ![](/ubbthreads/images/graemlins/shock.gif) P4876383 CNC-Ported Stage VI Aluminum Cylinder Head 2.18" Intake, 1.81" Exhaust 2420.00 each ![](/ubbthreads/images/graemlins/shock.gif)
Re: Stage VI heads?
[Re: Mopar_Ray]
#1138495
12/18/11 06:29 PM
12/18/11 06:29 PM
Posts: 75,134 A Banana Republic near you.
JohnRR
Yes, I'm talking abouut wedge heads. The CNC ported heads that Mopar performance is currently offering. So thats for a set of heads?
If the description says EACH then the price is EACH and that is not surprising coming from MP. I remember when the Chapman CNC heads came out, they were very close to $2500 each ... BARE
Re: Stage VI heads?
[Re: camdog440]
#1138497
12/18/11 08:38 PM
12/18/11 08:38 PM
hemi-itis
Couldn't you get into a set of B1's at that kind of $$$ ? [/quote
Does not pay to get them new from ma mopar,not for that kinda money.Lotsa choices in getting head for that $$$$$$ Find a used set of CNC'd chapman's for a good price hopefully with T&D's rockers and they perform well ![](/ubbthreads/images/graemlins/thumbs.gif)
http://www.moparmusclemagazine.com/techa...st_numbers.html
This chart will get you scratchin your,,,,,,,,,HEAD ![](/ubbthreads/images/graemlins/grin.gif) http://users.erols.com/srweiss/tablehdc.htm#Chrysler_Big_Block
Re: Stage VI heads?
[Re: tboomer]
#1138499
12/19/11 10:46 AM
12/19/11 10:46 AM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Discontinued, ns1, gone, see ya, adios, sayonara, etc etc
Rich H.
Esse Quam Videri
