replacement valve springs #1138347
12/17/11 11:44 PM
12/17/11 11:44 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
on my 580" with 572-13 heads, all of my inner springs broke. some into 3-4 pieces. i have the jessel set up. i only have about 500 miles on them as this is a street car.
the springs i use now are k motion 1000h,s. is there a better spring? i have heard that the k motion springs would break eventually. it is a solid roller with 1.7 rockers. the cam specs:
.800"/.750" 282/290 @.050.
the k motion 1000h specs:
1.625"
265# @2.00"
790# @1.250"
i would need something close to the same specs. i will be changing them with the heads still on. this is a street car, so reliabilty is the main concern. thanks...
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: replacement valve springs [Re: Old School] #1138348
12/17/11 11:53 PM
12/17/11 11:53 PM
Get-X Offline
Get-X  Offline
Put some Pacs on it and forget it. I just don't understand why people still use those K1000's? So many failures on so many different engines should have done their sales in long ago. It sucks you had to waste money on them at all
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: replacement valve springs [Re: Get-X] #1138349
12/18/11 12:05 AM
12/18/11 12:05 AM
Virginia Beach, VA
O
O
Virginia Beach, VA
should i use a circle track {endurance) spring? where is the best place to get them? i guess they would help me with my applacation?
Re: replacement valve springs [Re: Old School] #1138350
12/18/11 12:10 AM
12/18/11 12:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Google Pac springs... you wont be disappointed ... just
talk to them
Re: replacement valve springs [Re: MR_P_BODY] #1138351
12/18/11 12:55 AM
12/18/11 12:55 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Pacaloy...
1224 is what you need... I have run them on a similar wedge with similar specs, and a 572 hemi also.... Springs pressure is what you need, and they are 1.625 too.... They are twice the spring those old K motion's are.
Isky sells them reboxed too...
Re: replacement valve springs [Re: Old School] #1138352
12/18/11 01:35 AM
12/18/11 01:35 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I am a PAC WD and stock many of them, I might be at the shop tommorrow, if so I'll take a look...
RIP Monte Smith
Re: replacement valve springs [Re: Bob_Coomer] #1138353
12/18/11 01:43 AM
12/18/11 01:43 AM
Virginia Beach, VA
O
O
Virginia Beach, VA
Pacaloy...
i see that they offer 2 styles. a 1200 and a 1300 series. should i go for the 1300 series?
Re: replacement valve springs [Re: CompWedgeEngines] #1138354
12/18/11 01:45 AM
12/18/11 01:45 AM
Virginia Beach, VA
O
O
Virginia Beach, VA
see if you have part no. 1224 or 1324. would i be able to use my same retainers?
Re: replacement valve springs [Re: Old School] #1138355
12/18/11 05:00 AM
12/18/11 05:00 AM
Cab_Burge Online work
Cab_Burge  Online Work
Do you know how close you where to coil bind? It looks like they wanted .750 lift max with those specs Give them a call to make sure I just check some 1.550 PACS that I bought for a project, around twenty dyno pulls and warming the motor up several times, no loss of pressure at all 290 lbs. on the seat and close to 800 lbs opened at .700 lift That is .060 from coil bind I didn't check all the valve lifts at the retainers when I assemble that motor, I only checked the passenger side with these springs so I'm going to check the dirvers side as soon as I put that head back on. I had a leaky(6to7%) exhaust valve on the after dyno leak down test It turned out that it had a slight bit of rust on that valve seat, I removed it with scotchbrite and it sealed right up Lucky me I had to haul the motor 50 miles to the dyno in the back of my pickup and back in very humid, cold weather. I used paper towels and duct tape to seal the exhaust up but stuff happens any ways BTW, I'm impressed with those PAC springs
Re: replacement valve springs [Re: Cab_Burge] #1138356
12/18/11 02:38 PM
12/18/11 02:38 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
cab, those springs are good to .850" lift. they coilbind at 1.090. i'm not even close. i think i just need a better quality spring. i will call pac on monday and see what they say.
Re: replacement valve springs [Re: Old School] #1138357
12/19/11 06:04 PM
12/19/11 06:04 PM
Syracuse,NY
Syracuse,NY
Brian,
Check your email please.
Thank you
Todd
RIP Monte Smith
Re: replacement valve springs [Re: Old School] #1138358
12/19/11 06:15 PM
12/19/11 06:15 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... only have about 500 miles on them as this is a street car... it is a solid roller with 1.7 rockers... .800"/.750"... this is a street car, so reliabilty is the main concern.
Anyone besides me think there's a bit of an oxymoron in that description?
Re: replacement valve springs [Re: BradH] #1138359
12/19/11 06:24 PM
12/19/11 06:24 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I did think that was a pretty hefty cam for a street car. Guess it depends on the definition of a street car...
Re: replacement valve springs [Re: CompWedgeEngines] #1138360
12/19/11 07:08 PM
12/19/11 07:08 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
Brian,
Thank you
Todd
todd my computer crashed. i cant check email,s yet.
Re: replacement valve springs [Re: Old School] #1138361
12/19/11 07:08 PM
12/19/11 07:08 PM
Syracuse,NY
Syracuse,NY
Ill PM.
RIP Monte Smith
Re: replacement valve springs [Re: Dodgeguy101] #1138362
12/19/11 07:14 PM
12/19/11 07:14 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
that cam is not heafty for a 580 cubic inch motor. it idles at 900 rpm,s. it can be lugged in traffic, stop and go and in 100 degree heat without any problems. the only thing that sucks is, $ 8.00 gal race gas, and changing valve springs every year. other than those two things, it,s an awesome street car....
Re: replacement valve springs [Re: CompWedgeEngines] #1138363
12/19/11 07:19 PM
12/19/11 07:19 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
Ill PM.
todd i'm looking for pac 1224 springs and pac retainers # r 404. thanks for your help..
Re: replacement valve springs [Re: Old School] #1138364
12/19/11 10:27 PM
12/19/11 10:27 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I wasn't knocking it, just a bigger number than you normally associate with a street cam. That large a motor, sure probably does a great job. Have fun with it.
Re: replacement valve springs [Re: BradH] #1138365
12/20/11 05:40 AM
12/20/11 05:40 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
IMO I think the 1.7 rockers are doing more damage than good.
