Dana 60 questions
#1138325
12/17/11 11:06 PM
12/17/11 11:06 PM
Posts: 614 Michigan
Get-X
I have this here Dana 60 It is a brand new 8 lug single wheel "D" truck Dana, never ran unit with a 4.10 posi (Trac-Loc). It's going in the Ghetto-X, but I've never tried to use a Trac-Loc with 650+ hp (new bullet too ) and wondered if I should just spool it and forget it or attempt to use the posi? I will beat it like a red headed step-child (no red headed step children were harmed in the writing of this post ) and don't want to have to worry about the rearend. Any input would be greatly appreciated
'65 Belvedere '68 GTX '57 Dodge pickup
Re: Dana 60 questions
[Re: CHAPPER]
#1138328
12/18/11 01:06 AM
12/18/11 01:06 AM
Posts: 694 Michigan
Super Scamp
I have about 100 passes on the same set-up,,,no problems yet....foot braking. I have a brake in my trans, but not using it due to the posi unit.
[Re: Super Scamp]
#1138329
12/18/11 01:08 AM
12/18/11 01:08 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
You only about 200 hp beyond what a trac lock can handle.
[Re: DoctorDiff]
#1138338
12/18/11 07:56 PM
12/18/11 07:56 PM
NTOLERANCE
Madison Wi
Since my 30 spline D60 had a trac loc, and I knew I would be over the power limits.....
I bought a used 16 spline power loc on ebay for $145.
I then bought 30 spline side gears for $40.00
Sold the 30 spline trac loc on ebay for $105.00
I dont make 650hp, but I would be making 400 with the spray. Since I am in the proces of building the rear end, now is the perfect time to upgrade.
I didnt want the trac lock to be the weak link.
