Dana 60 questions #1138325
12/17/11 11:06 PM
12/17/11 11:06 PM
Get-X Offline OP
Get-X  Offline OP
I have this here Dana 60
It is a brand new 8 lug single wheel "D" truck Dana, never ran unit with a 4.10 posi (Trac-Loc). It's going in the Ghetto-X, but I've never tried to use a Trac-Loc with 650+ hp (new bullet too ) and wondered if I should just spool it and forget it or attempt to use the posi? I will beat it like a red headed step-child (no red headed step children were harmed in the writing of this post ) and don't want to have to worry about the rearend.
Any input would be greatly appreciated
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Dana 60 questions [Re: Get-X] #1138326
12/17/11 11:14 PM
12/17/11 11:14 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i tore up a posi with the same hp. go with the spool. it'll be ok on the street. seeya.
Re: Dana 60 questions [Re: rickraw] #1138327
12/17/11 11:43 PM
12/17/11 11:43 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I have about 100 passes on the same set-up,,,no problems yet....foot braking. I have a brake in my trans, but not using it due to the posi unit..
If you like drag racing, support your local track.
Re: Dana 60 questions [Re: CHAPPER] #1138328
12/18/11 01:06 AM
12/18/11 01:06 AM
Super Scamp Offline
Super Scamp  Offline
Re: Dana 60 questions [Re: Super Scamp] #1138329
12/18/11 01:08 AM
12/18/11 01:08 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
You only about 200 hp beyond what a trac lock can handle.
Re: Dana 60 questions [Re: NTOLERANCE] #1138330
12/18/11 02:20 AM
12/18/11 02:20 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
It might last for a while, but that question mark will always be there. It won't be a matter of "if", but "when".
Brian Dunnigan
Re: Dana 60 questions [Re: Get-X] #1138331
12/18/11 03:45 AM
12/18/11 03:45 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I don't recommend running 650 hp through a 30 spline Track-Lock.
Re: Dana 60 questions [Re: DoctorDiff] #1138332
12/18/11 04:30 AM
12/18/11 04:30 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
What about a power loc?
Re: Dana 60 questions [Re: astjp2] #1138333
12/18/11 05:09 AM
12/18/11 05:09 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A 35 spline Power-Lock is much stronger.
Re: Dana 60 questions [Re: DoctorDiff] #1138334
12/18/11 11:38 AM
12/18/11 11:38 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Mine is a 35 spline application. I'm not sure if it is Trac-loc or Power-Lock,,,what are the differences for identification??
Re: Dana 60 questions [Re: CHAPPER] #1138335
12/18/11 12:40 PM
12/18/11 12:40 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
here google is your friend:
power lock
track lok:
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Dana 60 questions [Re: bigtimeauto] #1138336
12/18/11 03:04 PM
12/18/11 03:04 PM
Get-X Offline OP
Get-X  Offline OP
Cass, do you know what the last year the power-loc was used? I'll just have to pop the cover and take a peek to be sure. I just assumed it was too late to have a power-loc?
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Dana 60 questions [Re: Get-X] #1138337
12/18/11 04:56 PM
12/18/11 04:56 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
As far as I know, the factory started installing Track-Locks in 1971 truck rears.
Re: Dana 60 questions [Re: DoctorDiff] #1138338
12/18/11 07:56 PM
12/18/11 07:56 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Since my 30 spline D60 had a trac loc, and I knew I would be over the power limits.....
I bought a used 16 spline power loc on ebay for $145.
I then bought 30 spline side gears for $40.00
Sold the 30 spline trac loc on ebay for $105.00
I dont make 650hp, but I would be making 400 with the spray. Since I am in the proces of building the rear end, now is the perfect time to upgrade.
I didnt want the trac lock to be the weak link.
Re: Dana 60 questions [Re: NTOLERANCE] #1138339
12/18/11 08:25 PM
12/18/11 08:25 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
My dana with a spool was in the car when I bought it over 25 years ago.I am much higher than 650 hp Over 60k miles on it,3 engines and several engine rebuilds.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Dana 60 questions [Re: rickraw] #1138340
12/19/11 01:23 PM
12/19/11 01:23 PM
organ
maximum entropy Offline
organ
