Re: Head Gaskets.....Early Hemi
[Re: TrWaters]
#1138277
12/17/11 10:08 PM
12/17/11 10:08 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
Are steel shim head gaskets obsolete? The old school type....single stamped pieces. If not, what is the limit when using them as far as compression ratios?
They work very well. Spray them with copper coat and rtv water passages, and your good to go. Only limit is finding them and to what bore size. We run them on any hemi that the bore will fit. The max on the 426 is +.060", not sure on the 392's..
[Re: Cab_Burge]
#1138279
12/17/11 10:52 PM
12/17/11 10:52 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
I don't think any of the early Chrysler(don't know about Desoto and Dodges) came with steel shim head gaskest, I had a bunch of them. All of the ones I have seen used a multi layered composite head gsaket, in fact I may have two of them left from master overhaul sets
my 1955 331 hemi had steel shims.
[Re: DJVCuda]
#1138280
12/17/11 10:58 PM
12/17/11 10:58 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
Mine didn't, but it had been tweak some before I got it(the heads had been cut .125 according to the former owner ) None of the 354 or 392, two 300 motors included I had came from the factory with steel shim head gaskets that I saw I only saw around eight of them altogether I have learned a long time ago to never say never about OEM parts, especially on Mopars
[Re: TrWaters]
#1138283
12/18/11 12:45 PM
12/18/11 12:45 PM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
My 57 was never touched and they were steel.Same with the NOS gasket set I bought.They were steel also.Rocky
Chrysler Firepower
