Re: SAWMILL HEMI [Re: 19swinger70] #1138233
12/20/11 09:40 AM
12/20/11 09:40 AM
Richmond, Indiana
19swinger70 Offline OP
Richmond, Indiana
Mike,
You were correct in saying that the dimpled valve covers do not indicate an adjustable valvetrain. I learn something new everyday!
I removed a V-cover and see a fairly clean situation. No layers of thick sludge or any broken components. The hour meter on the sawmill rig shows 1237 hrs.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: SAWMILL HEMI [Re: 19swinger70] #1138234
12/20/11 12:06 PM
12/20/11 12:06 PM
AZ
Mike P Offline
Mike P  Offline
AZ
Bummer, I was really hoping you would end up with adjustables.
I'm using adjustable pushrods on both of my first gen Hemi's. The one only has a few hours on the test stand, but the 354 in my 57 Plymouth has been going with them for 5 years and 15,000 miles on them with no problems.
If you decide to rebuild your 354 just a word of caution about the Hot Hemi heads HV oil pump. I have heard that there may be some problems with them.
http://www.hotrodders.com/forum/hot-heads-oil-pump-failures-203640.html
Don't get me wrong, I've had good luck with the parts I have bought form Bob at hot heads, but that post was kind of worrysome (I'm running stock replacement pumps in mine so it's not an issue for me).
I'd also recommend Tex Smiths Hemi book if you don't already have a copy.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: SAWMILL HEMI [Re: Mike P] #1138235
12/20/11 02:09 PM
12/20/11 02:09 PM
Richmond, Indiana
Richmond, Indiana
I recently purchased the Tex book. it is a good one. I will keep the Hot Heads thing in mind.
55 Plymouth Project
Re: SAWMILL HEMI [Re: 19swinger70] #1138236
12/20/11 02:20 PM
12/20/11 02:20 PM
Jacksonville Florida
elitecustombody Offline
That's pretty cool find.
Re: SAWMILL HEMI [Re: 19swinger70] #1138237
12/20/11 10:38 PM
12/20/11 10:38 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Back when I worked in factory maintenance, an hour of use on an hour meter was considered the same as 30 miles for fork lifts. I'd say you have a pretty low miles motor there. Gene
Re: SAWMILL HEMI [Re: poorboy] #1138238
12/21/11 04:37 PM
12/21/11 04:37 PM
Buckeye Lake
56_Royal_Lancer Offline
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Very cool. So what are your plans now for my old 315?
Re: SAWMILL HEMI [Re: 56_Royal_Lancer] #1138239
12/21/11 06:22 PM
12/21/11 06:22 PM
Richmond, Indiana
Richmond, Indiana
I am not sure about the 315 - it isnt hurting me to keep it around for a potential future project. Or, I might use it as trading bait at some point. It is nice that it is complete from carb to pan, unmolested, and I know a little bit of its history.
I might still try to locate some Hemi heads for it.
In the end, I couldnt pass up the 354!
55 Plymouth Project
Re: SAWMILL HEMI [Re: 19swinger70] #1138240
12/21/11 09:38 PM
12/21/11 09:38 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
I have yet to see a Chrysler Industrial engine that actually had adjustable rockers.
Re: SAWMILL HEMI [Re: 19swinger70] #1138241
12/22/11 08:01 PM
12/22/11 08:01 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
That had to be one awesome sounding sawmill with a straight pipe Hemi!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
