Fastest stock smogger 360 combos
#113745
09/01/08 09:09 PM
09/01/08 09:09 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
I was inspired by the smogger 440 thread to ask what some times (et, mph) have been seen with a stock smogger 360. Please give combinations(cam, induction, exhaust, estimated compression, vehicle weight, ect.)
I'll start by saying I saw a duster run very high 12's and the guy told me it was a stock low compresion (8:1) long block with a 509 MP cam and 4.10 gears. I think it had open headers.
Re: Fastest stock smogger 360 combos
[Re: Rapid340]
#113746
09/02/08 01:09 AM
09/02/08 01:09 AM
Posts: 1,996 s. e. pa.
calrobb2000
s. e. pa.
hi my son has a 360 duster auto that has a unknowen mild cam and pumps 125 lb comperesion with ld340 / 750 vac headers 3 in ex AND 2.76 gears ! 14.2 on reg gas so far !
[Re: calrobb2000]
#113747
09/02/08 02:40 AM
09/02/08 02:40 AM
Posts: 653 Fort Worth, TX
Dago Red
Fort Worth, TX
1977 Plymouth Volare wagon 3350# with driver, 8:1 dish piston motor, 3500 Dymamic w/ manual valve body, 4.56's on 9" tires. .484 Purple Shaft, 1 5/8 headers w/ mufflers, stone stock 587 smogger heads. Best is 13.21 @ 101. Stock eliminator guys are getting low 11's out of their stuff (Jerry Bennett, the Wann's, etc)
If You Can't Be Good, At Least Be Colorful
[Re: Dago Red]
#113748
09/02/08 03:11 AM
09/02/08 03:11 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
In 1991, 360 stock short block, MP 292 cama, untouched 1.88/1.60" high swirl heads, performer intake, 3310 Holley, MP electronic ginition with orange box, 1 5/8" primary headers, 2.5" dual pipes with H. TF 727 with shift kit, 10" TCI converter, 8 3/4" with 3.23 ratio and sure grip, 205/75/14 tires. Car was a Plymouth Valiant 1973, 3400 lbs and run 13.26/107 mph.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#113750
09/02/08 08:13 AM
09/02/08 08:13 AM
Rapid340
oberlin, Ohio
I saw a 4 door abody runs similar times at norwalk (late 90's or early 2000's)with a trap speed of 108 mph. The guy said it was a junk 360 with new MP swirl port heads that he spent a few hours on with a die grinder. The car had closed exhaust if I remember correctly.
[Re: Rapid340]
#113752
09/02/08 11:27 AM
09/02/08 11:27 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
My old Mirada at 3700+ lbs ran the best of a 12.01 at 109 and change.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#113753
09/02/08 11:57 AM
09/02/08 11:57 AM
Rapid340
oberlin, Ohio
What combination?
[Re: sixpackbee]
#113755
09/02/08 12:12 PM
09/02/08 12:12 PM
I have a 360 with the stock smog heads, he275hl cam, eddy performer rpm, 1 5/8 headers, about 10 to 10.5:1 comp., 4-speed, 3.91 gears, in a 65 barracuda and ran a 13.6 at 101 on the wal-mart special tires...
[Re: AndyF]
#113757
09/02/08 01:13 PM
09/02/08 01:13 PM
Rapid340
oberlin, Ohio
Mazzolini runs 10's with a smogger 318. Low compression pistons, cast iron heads, Qjet carb, etc.
Probly just running a summit cam too.
Just to clarify, I am not asking about super stockers with no expense spared. Just low dollar motors that run better than expexted.
Although it interesting how some of those cars run.
[Re: Rapid340]
#113763
09/02/08 05:03 PM
09/02/08 05:03 PM
Dago Red
Fort Worth, TX
Rapid, can we assume perhaps, you're trying to find the best bang for your money? If you are quite happy with a somewhat less popular body, like a late Valiant/Dart/Scamp etc you'll be money ahead. Some folks just have to have a Demon or 2nd gen Barracuda, and they tend to be a bit more pricey. I have $4700 in my Volare wagon, including the cost of the car. I've raced it ten years and the 360 smogger I built for it still has good compression and oil pressure.
[Re: AndyF]
#113764
09/02/08 05:12 PM
09/02/08 05:12 PM
Dago Red
Fort Worth, TX
Andy's right, while Mazz may have a few bucks in his Sebring, that is one screaming son-of-a-gun.
And, finally, while I don't want to hijack this thread, there has been surge in early A-body 273 combos for Stock and Super Stock being built, and its got the 283 Chevy guys as nervious as a kitty in a room full of rocking chairs. I've read where a 273 Valiant has been in the 11's !!
