Re: 5.7 hemi swap won't start?
[Re: xpsyclonex2002]
#1137285
01/12/12 07:43 PM
01/12/12 07:43 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
For an 05 Truck only one of those codes come up? What is the p# of the PCM??? It sounds like you have a wiring issue if supplying battery power to the fuel pump increases fuel psi from 10 to 55psi. I would double the wiring connections you had to make. BTW A street and performance harness is most likely not built by s&p. You might want to try hotwireauto. The Squires most likely built the harness. Just my ![](/ubbthreads/images/graemlins/Twocents.gif) If you want PM me your cell, and I will trouble shoot over the phone. Justin ![](/ubbthreads/images/graemlins/thumbs.gif)
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
#1137287
01/12/12 09:14 PM
01/12/12 09:14 PM
wldtm
Dayton, Ohio
that dropped my confidence a little bit now. ![](/ubbthreads/images/graemlins/frown.gif) part#???
PM for details
