Re: small block vs. big block weight?
[Re: domingo]
#1135153
12/16/11 02:30 PM
12/16/11 02:30 PM
Posts: 12,406 Kalispell Mt.
HotRodDave
Kalispell Mt.
Don't know the total but I got tired of hearing the BS about how close in weight the blocks are and through a 400 block on a scale just now and the bare block and caps weighs 220# while a 360 roller block with caps is 165# on the same scale.
[Re: HotRodDave]
#1135154
12/16/11 02:35 PM
12/16/11 02:35 PM
HotRodDave
Kalispell Mt.
And in case you are wondering a 596 head (assembled) weighs 50# and a 516 head (assembled) weighs 48#
[Re: dogdays]
#1135159
12/16/11 02:56 PM
12/16/11 02:56 PM
Posts: 21,808 Kirkland, Washington
Pacnorthcuda
I think you're misremembering the point, Dave, that an RB bare block weighs about the same as a B bare block.
I can't remember anyone here on this board trying to say that a 440 weighs as much as a 360. Now if the 360 is factory stock and the 440 has as many aluminum parts on it and lightweight reciprocating assembly, then they're probably close...but stock-to-stock the 440 weighs more than 100# more according to all the published data.
R.
Thats my thoughts too---Take a 440 and use AL heads/intake/waterpump housing and you're talking SB weight. Not sure if a lighter recip weight is going to help that much in the overall weight (maybe) but it can't hurt!
[Re: Pacnorthcuda]
#1135160
12/16/11 03:49 PM
12/16/11 03:49 PM
HotRodDave
Kalispell Mt.
How can you even think it is fair to compare a BB with a bunch of $$$ tied up in aluminum stuff but saddle the SB with all the factory iron. If you want to make it fair then give the SB aluminum heads also. Also just weighed cranks, 400 cast crank (the lightest BB crank) 63# 360 crank (heaviest SB crank) 57# 6# rotateing weight is a lot more important to going fast than 6# static weight BTW
[Re: HotRodDave]
#1135161
12/16/11 03:53 PM
12/16/11 03:53 PM
HotRodDave
Kalispell Mt.
69 440 HP block, no main caps and .060 over is 215# add all that metal back on and it will definately be more than the 400 by at least 10# and have a heavier crank.
[Re: HotRodDave]
#1135162
12/16/11 04:08 PM
12/16/11 04:08 PM
Pacnorthcuda
The comparison is strictly WEIGHT (Not $$$), Obviously a SB with AL goodies would be lighter yet----duh.
Yes Rotating weight is more important---NEWSFLASH--RECIPROCATING weight is even More important than rotating. But only the static weight of the assembly is germane to the issue at hand.
[Re: domingo]
#1135163
12/16/11 04:14 PM
12/16/11 04:14 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
How much would a stock block 340 with w2 iron heads and aluminum intake weigh
vs.
a stock block 440 with aluminum heads and aluminum intake?
I haven't weighed any of my stuff, but I would guess they aren't far off of each other. My W2's feel pretty heavy!
I think my combo would probably weigh close to the same as a big block with iron heads, but I am using a tall deck R3 now.
-Kenny
[Re: domingo]
#1135164
12/16/11 04:20 PM
12/16/11 04:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
vs.
Rule of thumb is 100# different as said for stock to stock... with a stock SB at 500#... take off about 15# for the intake thats about 485#.. a 440 stock is about 600# so take off about 35# for heads and another 15# for the intake, you have about 550#... just all rough weights... if you were to change the W-2 heads you can knock off 40# more
[Re: domingo]
#1135168
12/16/11 06:14 PM
12/16/11 06:14 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
vs.
no idea what they weigh but I know which one will make the most power.
[Re: fishy340]
#1135169
12/16/11 06:16 PM
12/16/11 06:16 PM
Mr.Yuck
Brookeville, Md
100lbs give or take 5 lbs! As far as handeling goes thats a huge difference..ps plus the w2 headed 340 will make more power...
thanks I needed a good laugh
[Re: domingo]
#1135170
12/16/11 07:13 PM
12/16/11 07:13 PM
HotRodDave
Kalispell Mt.
If by "all the aluminum goodies" you mean water pump and housing also then there is gonna be less than 20# differance and the advantage may actually go to the BB because the weight will be slightly lower, either way it will be very slightly different. As for witch one makes more power it will depend on more than just saying aluminum BB heads VS W2, a stage V is aluminum but so is a stealth and a good W2 can make more HP than a stock stealth head so we would need to know more about the two combos.
[Re: Mr.Yuck]
#1135171
12/16/11 07:53 PM
12/16/11 07:53 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
vs.
well we know its not your 440-6 from your ET
