What carb ??? #1134763
12/15/11 06:29 PM
12/15/11 06:29 PM
ohio
bigblockrik Offline OP
ohio
I have a 451 indy sr heads solid roller,I have a 850 demon.What about a 1050 dominator.Its a street and strip car.Thanks
Re: What carb ??? [Re: bigblockrik] #1134764
12/15/11 06:31 PM
12/15/11 06:31 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
How's it run w/ that? How aggressive is the motor? 1050should work pretty good I'd think.
Coming soon!!!!
Re: What carb ??? [Re: bigblockrik] #1134765
12/15/11 06:31 PM
12/15/11 06:31 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... What about a 1050 dominator...
What about it?
How's the Demon 850 run?
How fast is the car now?
How fast do you expect go?
Re: What carb ??? [Re: bigblockrik] #1134766
12/16/11 12:49 AM
12/16/11 12:49 AM
If you max the tune up on both carbs the 1050 should be 1/10 to 2/10 faster and probally 1 to 2 MPH faster Mine is a street and strip car pump gas car that runs in the low tens and one high nine so far Edited I have several 1050 Dominators, three early 9375 non HP and two later 9375HP. One of the early 9375 was converted to annular boosters, it runs the fastest on the car I'm working on the part throttle cruise AFR now,it was really risch to begin with I have been leaning the part throttle fuel feed and idle fuel feed( a little bit at a time) to lean it down according to the wide ban AFR meter,it has been a challenge I'm at around 12.3 to 12.8 (it started at 11.3 )now and shooting for 14.2 or leaner at 2000 to 2500 RPM cruising at real light throttle
Re: What carb ??? [Re: bigblockrik] #1134767
12/16/11 12:54 AM
12/16/11 12:54 AM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
I think the dominator is deffinetely best for race only but I wouldnt want to run mine on the street much
Re: What carb ??? [Re: bigblockrik] #1134768
12/17/11 01:22 AM
12/17/11 01:22 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
When I went from an 850 demon to a 1050 dommy and picked up 2 tenths and 2 mph and I drive mine on the street and now that I have a wide band, it`s WAY better.
Re: What carb ??? [Re: Thumperdart] #1134769
12/19/11 11:44 PM
12/19/11 11:44 PM
ohio
ohio
Whould you buy a holley or one from another supplier.I am still setting the car up and trying to have the right carb to plumb and hook everything up.Thanks for all the input Happy holidays to all !!
Re: What carb ??? [Re: bigblockrik] #1134770
12/20/11 03:19 PM
12/20/11 03:19 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I run a Dominator on my 446 with Indy SR`s and a solid roller. I think it works just fine
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: What carb ??? [Re: bigblockrik] #1134771
12/20/11 03:45 PM
12/20/11 03:45 PM
I have heard of a lot of guys that buoght "custom made" Dominators that didn't work as well as a new stock out of the box Holley Dominator Me TOO What application, trans brake or foot brake and what size motor and trans type, rear gear ratio and tire hieght?
