Re: How do you "use" feeler gauges
[Re: Quicktree]
#1134609
12/16/11 04:18 PM
12/16/11 04:18 PM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Doc if you have to ask that question you better stick to fiberglass where you can get close and not worry about it
Hay 'Cain-Fan ... just asking the question ... ... because I got a set of used pistons on eBay that the guy claimed 005 RGC ....and the only way he could have gotten that spec was to have JAMMED the feeler in there.
[Re: dOc !]
#1134616
12/16/11 05:04 PM
12/16/11 05:04 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
GET OUT yurr reading-glasses SLEDGE ....
How I started this post ....RGC ....ring groove clearance ..
I thought you meant Ring Gap Clearance...
The problem here is that one has to think like Doc--and that....well...lets just say its a challenge...
[Re: moparniac]
#1134619
12/16/11 05:18 PM
12/16/11 05:18 PM
dOc !
Florida STAYcation
...and ring-gap-clearance ? .. ok THEN - HOW ELSE is that done .. other than with a feeler-guage ?
eyecrometer
..... aka -Sledgehammer- ISH ? ..
[Re: dOc !]
#1134620
12/16/11 05:26 PM
12/16/11 05:26 PM
Pacnorthcuda
Well PACman ...... IF you tried READING instead of ....it might beeez clearer
WIth a fEEler gAUge oF courSE! baZINGa docAmundO!!!
that hurt...
[Re: Pacnorthcuda]
#1134621
12/16/11 05:34 PM
12/16/11 05:34 PM
dOc !
Florida STAYcation
that hurt...
dAmN pAcMAN ... you are finally NOT uNcorrect ... that must have HURT !
and (Doc mooning @ the lefty-coast)
[Re: pittsburghracer]
#1134623
12/16/11 05:41 PM
12/16/11 05:41 PM
dOc !
Florida STAYcation
Are you sure you didn't start your weekend early?
Why can't I use 1/8 rings on my 5/64 pistons or how much pressure do you apply when using a file?
EVERYday is a weekend ferr me ...
R those yurr Q's ? ... START yerr own topic ...
#1134624
12/16/11 05:43 PM
12/16/11 05:43 PM
Quicktree
PITTS of-da' Burger ...I said RGC ...
You scare me Doc. You really scare me. Asking how a feelers gauge should feel and the trying to measures a round abject with a flat tool. But like the blond girl at Wallmart was over heard saying. "WHATEVER"
[Re: dOc !]
#1134626
12/16/11 05:56 PM
12/16/11 05:56 PM
Quicktree
Qt ..... I have always wondered .... what does your "handle" mean .... 009 "red" ? .. GO 'Cains !
...and I suggest that you READ Pitts-of-the-Burger's newest post.
again if you need to ask you probably need to check out fishing or an old folks home. Quicktree was a term used by racers before cross-talk and the new starting systems.back when the starting line guy had control of when the lights came down. if you pissed him off he would hit the switch as soon as you turned on the bottom bulb not even giving you enough time to set the trans brake. we called that a Quicktree but you should know that being around drag racing for 70 years
