Re: How do you "use" feeler gauges
[Re: BloFish]
#1134595
12/15/11 04:13 PM
12/15/11 04:13 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Well... they're called "feeler" gauges, not "jam-it" gauges; I figure if you're forcing it in at all that you're not getting an accurate measurement.
That's what she... Oh never mind
.... what ...like a 3/8 stem ...with 006 clearance ? ..
[Re: BloFish]
#1134600
12/15/11 06:20 PM
12/15/11 06:20 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
That's the inside mic... Prefer an interference fit!
[Re: Cab_Burge]
#1134601
12/15/11 08:15 PM
12/15/11 08:15 PM
Posts: 8,936 Holly/MI
Dean_Kuzluzski
Holly/MI
I've used the "go, no-go" technique for many years. Usually a .002 difference as mentioned.
[Re: Cab_Burge]
#1134602
12/16/11 12:23 AM
12/16/11 12:23 AM
Posts: 6,847 Missouri
StrokerPost
Missouri
Use a slightly larger gauge as a no-go and the size you want as a "go".
I use the recommendations of a old Mopar engine guru, if it slides in easy it is to loose,he said it should almost cut your finger to make it slide in. I now use the go no go procedure, if a .016 will go in hard and a .017 won't go in no matter how hard I press on it I'm there at .016
Yup, if it fits, thats what it is. I used to set mine by the "run it down till snug and set it" routine, (for rockers) then found if I put a bit of pressure on the next larger feeler it would go in too. I like to set it so that I get a loud "snap" when I remove the feeler, but still just be able to put it back in. That 1 or 2 thou difference though, in most cars, will make little or no difference in performance so I dont get in a twist over it. Just my
[Re: Cab_Burge]
#1134603
12/16/11 12:48 PM
12/16/11 12:48 PM
dartman366
Mt. Vernon, Ohio
thats how I was taught to do it.
[Re: Quicktree]
#1134605
12/16/11 01:59 PM
12/16/11 01:59 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
Just a slight drag on the gauge. Jamming it or forcing it is not an accurate measurement. Do you clamp a micrometer like a pair of vise grips?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1134606
12/16/11 02:01 PM
12/16/11 02:01 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
[Re: Quicktree]
#1134609
12/16/11 04:18 PM
12/16/11 04:18 PM
dOc !
Florida STAYcation
Doc if you have to ask that question you better stick to fiberglass where you can get close and not worry about it
Hay 'Cain-Fan ... just asking the question ... ... because I got a set of used pistons on eBay that the guy claimed 005 RGC ....and the only way he could have gotten that spec was to have JAMMED the feeler in there.
[Re: dOc !]
#1134616
12/16/11 05:04 PM
12/16/11 05:04 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
GET OUT yurr reading-glasses SLEDGE ....
How I started this post ....RGC ....ring groove clearance ..
I thought you meant Ring Gap Clearance...
The problem here is that one has to think like Doc--and that....well...lets just say its a challenge...
[Re: moparniac]
#1134619
12/16/11 05:18 PM
12/16/11 05:18 PM
dOc !
Florida STAYcation
...and ring-gap-clearance ? .. ok THEN - HOW ELSE is that done .. other than with a feeler-guage ?
eyecrometer
..... aka -Sledgehammer- ISH ? ..
[Re: dOc !]
#1134620
12/16/11 05:26 PM
12/16/11 05:26 PM
Pacnorthcuda
Well PACman ...... IF you tried READING instead of ....it might beeez clearer
WIth a fEEler gAUge oF courSE! baZINGa docAmundO!!!
that hurt...
[Re: Pacnorthcuda]
#1134621
12/16/11 05:34 PM
12/16/11 05:34 PM
dOc !
Florida STAYcation
that hurt...
dAmN pAcMAN ... you are finally NOT uNcorrect ... that must have HURT !
and (Doc mooning @ the lefty-coast)
[Re: pittsburghracer]
#1134623
12/16/11 05:41 PM
12/16/11 05:41 PM
dOc !
Florida STAYcation
Are you sure you didn't start your weekend early?
Why can't I use 1/8 rings on my 5/64 pistons or how much pressure do you apply when using a file?
EVERYday is a weekend ferr me ...
R those yurr Q's ? ... START yerr own topic ...
#1134624
12/16/11 05:43 PM
12/16/11 05:43 PM
Quicktree
PITTS of-da' Burger ...I said RGC ...
You scare me Doc. You really scare me. Asking how a feelers gauge should feel and the trying to measures a round abject with a flat tool. But like the blond girl at Wallmart was over heard saying. "WHATEVER"
[Re: dOc !]
#1134626
12/16/11 05:56 PM
12/16/11 05:56 PM
Quicktree
Qt ..... I have always wondered .... what does your "handle" mean .... 009 "red" ? .. GO 'Cains !
...and I suggest that you READ Pitts-of-the-Burger's newest post.
again if you need to ask you probably need to check out fishing or an old folks home. Quicktree was a term used by racers before cross-talk and the new starting systems.back when the starting line guy had control of when the lights came down. if you pissed him off he would hit the switch as soon as you turned on the bottom bulb not even giving you enough time to set the trans brake. we called that a Quicktree but you should know that being around drag racing for 70 years
[Re: tboomer]
#1134629
12/16/11 06:15 PM
12/16/11 06:15 PM
Quicktree
Please keep this thread on topic...or it goes away...
[Re: Quicktree]
#1134630
12/16/11 06:21 PM
12/16/11 06:21 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
I like to use feeler gauges as nice spring stock when I build tattoo machines... Izzat on topic? When I set valve clearances like others said, light drag. I will admit to curling feelers sideways to fit into round clearances in a pinch and even tack welded some in as shims in various applications.
[Re: radar]
#1134631
12/16/11 06:47 PM
12/16/11 06:47 PM
Posts: 1,532 off the grid
340B5
off the grid
Very Slight drag, just like those C-clamp thingies w/the numbers on them.
Yeah, it's got a smallblock.
[Re: 340B5]
#1134633
12/16/11 07:06 PM
12/16/11 07:06 PM
dOc !
Florida STAYcation
Very Slight drag, just like those C-clamp thingies w/the nunbers on them.
GOOD POINT ...and lots of those thingies have a small knob on them to take that guess-work away from that.
And to PO ..... getting any SNOW down in WPB ?
To TEDster ... I think that if any goes off-topic ...THEY should uNappear ... maybe on-vacation up-to the NORTHpole ..
[Re: emarine01]
#1134636
12/17/11 12:11 AM
12/17/11 12:11 AM
Quicktree
Hey Sledgie.... When did ya get into the nail polish thing
no kidding thats just gay always thought something was wrong with the boy.
[Re: Quicktree]
#1134637
12/19/11 12:43 AM
12/19/11 12:43 AM
dOc !
Florida STAYcation
StReEt CaR!
His spelling is slightly wacky too ...
[Re: dOc !]
#1134638
12/19/11 01:15 AM
12/19/11 01:15 AM
quick77rt
Parts Problem
Parts Problem
what kind of "pressure" do you use in the insertion of that feeler into the slot..... I didnt know this was the sports section, but I say hes ready coach Its gonna be a long winter. I use them in the manner which they were made for, Doc your a real freak. Id be asking the quality of the set one is using...ive some old old sets that are so nice to use and made well, look at the made in china sets at autozone....I hope there quality is better then there other products. A better thread would be 100 uses for a feeler gauge.
[Re: dOc !]
#1134639
12/19/11 02:02 AM
12/19/11 02:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Its pretty simple to me... I beat them in with a hammer and pull them back out with a come-along... what so hard about that... takes awhile to do all of the valves but I get them done right.... but what does that matter, I'm retired and on my CHEAP pension .... no I just use a fair drag to it... not alot... to me its a feel... maybe thats why they're called feeler gauges
