Battery Disconnect Switch .... Help!
#1133836
12/14/11 01:56 AM
12/14/11 01:56 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Moving battery to the trunk. I'm not very versed in electrical. I see disconnect switches anywhere from 20 amp to 250 amp. What do I need and why? Street strip car, stock 1967 electrical system.
Re: Battery Disconnect Switch .... Help!
[Re: StealthWedge67]
#1133837
12/14/11 02:24 AM
12/14/11 02:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
250 amp... the starter itself will draw near 100 thats short time but you have alot of other stuff drawing all the time... also see if its constant duty 250
#1133839
12/14/11 12:08 PM
12/14/11 12:08 PM
Triple Threat
Renton Washington
Bigger is better. Mine was meant for a industrial application with multiple batteries, I don't know what its rated at but its a lot.
[Re: Triple Threat]
#1133840
12/14/11 12:39 PM
12/14/11 12:39 PM
StealthWedge67
Puyallup, WA
okay, I placed my order with Summit. I went with 1-guage cable, and the summit 250-amp waterproof switch.
My MSD is fed directly off the starter relay. If I'm thinking this through correctly, when you hit the disconnect switch at the back of the car with my ignition wired like this, it should shut the car down, correct?
#1133842
12/14/11 05:25 PM
12/14/11 05:25 PM
MR_P_BODY
UNLESS you have the alt out put wire is attached to that same lug on the relay, then the ignition will still be hot... if your alt wire goes to the battery side of the master it will kill the engine
[Re: MR_P_BODY]
#1133843
12/17/11 10:35 PM
12/17/11 10:35 PM
StealthWedge67
Puyallup, WA
I haven't made any of the changes yet, but today I yanked the positive cable while the car was running, and it kept running. Sooooo, how do I rewire the alternator, Mike?
#1133844
12/18/11 12:24 AM
12/18/11 12:24 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
The small red wire from the MSD needs to be downstream from the cut off switch. That is the trigger or on/off wire for the box. The big red wire that goes to the battery can be on either side of the cut off switch, preferably directly on the battery post. I prefer a trunk mounted ford style solenoid and not running starter draw through the cut off switch. Here are some diagrams.
[Re: RobX4406]
#1133845
12/18/11 12:42 AM
12/18/11 12:42 AM
StealthWedge67
Puyallup, WA
I've got it now. I'm just going to bring the alternator wire to the battery side of the disconnect switch (2nd diagram above).
Thanks-
#1133846
12/18/11 12:57 AM
12/18/11 12:57 AM
MR_P_BODY
Thanks-
You'll be set then
