Page 2 of 4 1 2 3 4
Re: Building a driver - use carburator or fuel injection ?? [Re: GoodysGotaCuda] #1133370
12/14/11 03:28 AM
12/14/11 03:28 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I would go the TQ route .....with a 904 trans.
FI still is a PITA, expensive and does not work right all the time.
Not if he would use the factory ECM and a Magnum engine.That setup is bullet-proof as far as dependability is concerned. He could even use the A-518 O/D transmission for even better economy and drive-ability.
That's what I'd do for a driver. Not the max hp setup, not the hardest/most expensive setup and pretty hard to kill.
I agree. Then I'd hunt for used bolt on hipo parts from the Dakota guys. Cam, R/T heads, E-brock heads, etc.
Re: Building a driver - use carburator or fuel injection ?? [Re: a12rag] #1133371
12/14/11 09:14 AM
12/14/11 09:14 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
My daughter daily drives a truck with a carburetor. People act like carbs are voodoo magic nowadays...funny how things change because that's how FI used to be viewed.
Re: Building a driver - use carburator or fuel injection ?? [Re: dustergirl340] #1133372
12/14/11 12:28 PM
12/14/11 12:28 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
I am all good with my TQ's. I have had one on my 74 Duster360 since I got the car way back when. Have rebuilt it a couple of times (over 100k miles since restoring the car in 84 !!)and it runs great ! I also changed the Lean Burn on my 77 New Yorker 440 to standard electronic ignition, and about a 75 non-lean burn TQ. That car RAN SOOOOO good ! You set the choke with one pump, turn the key, and GO. It had NO hesitation when cold, and after about 2minutes was off the choke and running great ! . . . I always figure if you follow the factory steps for rebuilding a TQ, then it works great ! Course the above cars are all stock, so that makes it easy.
I already have the rebuilt 360, so, I am going with that - I know a 90's magnum 360 with the factory TBI would be cool, but have this engine now, so am going with it.
The car is not going to be a 4season machine. However, I do love to drive long distances to carshows, and the early/late year shows run into cold weather leaving from up north here. I am ok with carb, or EFI - specially the new style that do all the hard work for you ! Specially something like the Professional Products unit that has it all in the "carb" style body, and not needing a return line.
Guess it will all depend on whether or not I have been a good employee and see some bonus $$$ this year ! If so, I think I will pull the pin on the EFI. If not, then rebuild one of the many TQ's I have.
Thanks for the input . . . always a great discussion.
Cheers
Mark
Re: Building a driver - use carburator or fuel injection ?? [Re: dustergirl340] #1133373
12/14/11 02:20 PM
12/14/11 02:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Carbs aren't magic at all... Carbs are a semi controlled fuel leak... Carbs are great as long as the person driving the vehicle understands it's a carb & not fuel injection.... Back in the eighties & early nineties I'd get people in the shop with a carb complaining, they drive a fuel injected vehicle 75% or the time but this old truck needs to work... "Well on a cool morning leaving the ranch, at the second stoplight making a left the ol' truck wants to die... She'll start right up & she's fine after that but..." Yeah, Right... So if I add a bit of tension to the choke to help it through that lean area it will be to fat & I'll hear about that too....
Or the "I took the car up to Tahoe this weekend & it didn't run very well... " No [Edited by Moparts - Family Friendly Site - Keep it clean]? We live at sea level & you took a carbed vehicle up to 7000 ft & it didn't run the same.. What a revelation...
So Yeah if you understand a carbs limits & your OK with that than no problem & I realize the OP would, but my point being EFI when it's right does take care of allot of things a carb can't deal with....
Re: Building a driver - use carburator or fuel injection ?? [Re: a12rag] #1133374
12/14/11 03:06 PM
12/14/11 03:06 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if it's not a year round, get you to work every day driver, then I'd just rebuild a T-quad and put it on....
if I were going for an aftermarket EFI, I'd probably look at the FAST EZ-EFI. only thing about it and the PP copy of it are that they are fuel only, and a lot of the drivability improvements OEM EFI systems have are due to the computer being able to manipulate the timing curve in ways you just can't do mechanically.
2017 Grand Cherokee Overland
Re: Building a driver - use carburator or fuel injection ?? [Re: Rug_Trucker] #1133375
12/14/11 03:18 PM
12/14/11 03:18 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
The "Thermosquad!" Doc Glass is the general in charge!!
Re: Building a driver - use carburator or fuel injection ?? [Re: dOc !] #1133376
12/14/11 04:58 PM
12/14/11 04:58 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
Fixed....
Re: Building a driver - use carburator or fuel injection ?? [Re: a12rag] #1133377
12/14/11 06:57 PM
12/14/11 06:57 PM
albemarle, NC
dusterbd13 Offline
dusterbd13  Offline
albemarle, NC
having driven tons of both daily, and modified tons of both fuel systems, i have my preferences.
my duster is currently a well tuned carb setup. only carb left in the fleet.
its going MPFI, with computer controlled timing and a GM ECM. looking forward to doing injection again.
reason im going efi is for better throttle response, mre fine tunability, and all the benifits previosly talked about in the thread.
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: Building a driver - use carburator or fuel injection ?? [Re: a12rag] #1133378
12/15/11 06:16 AM
12/15/11 06:16 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
a12rag, why is the idea of adding a return fuel line such a big deal to you? I mean if it is, I don't think plumbing in fuel injectors and wiring the whole thing together is something you want to do. Adding a return fuel line is the least of my concerns with going to efi.
Sounds to me like you'd be happier with a themoquad. I ran one for many years and daily drove the car and it performed well. The trick is to start with a pre-smogger thermoquad instead of one with all the emissions jetting and ports.
Re: Building a driver - use carburator or fuel injection ?? [Re: a12rag] #1133379
12/15/11 06:38 AM
12/15/11 06:38 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If the driving will mostly be near the same altitude, a carb with electric choke will work good and is inexpensive. If you plan to drive cross country at various altitudes, the FI will self adjust for the different altitudes.
Return line should not be an issue, it helps keep the fuel pump and lines cool.
The Professional Products ProJection III is pretty affordable TBI unit (about $1,500), and MSD is going to release their Atomic EFI in a months or two for around $2,000.
The Edelbrock Pro-Flow XT is a neat TPI type system, but costs around $4,000 (although it comes with a new manifold, and distrubitor.)
Re: Building a driver - use carburator or fuel injection ?? [Re: a12rag] #1133380
12/15/11 08:12 AM
12/15/11 08:12 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am in process of building a 1970 B Body that I will drive - all over the place I hope ! . . . 360 with about 9.5:1 pistons, 1970 340 type cam, 727 auto and 3.23:1 rear end gears. Question I ask myself, is : should I go the route of fuel injection ?? You can get great products now, that you don't even need a return line ! They learn and then you just get in and turn the key. Granted it is about a $2k touch !!! That could pay for a lot of fuel with a carburator !
However, putting 10-15k miles on the car in a year, the ease of operation with the fuel injection would be appreciated - idle, start when cold, cold drivablity, etc. . . .
What would you guys do ?? I am good with a TQ for the 360, but wonder about upgrading to the EFI . . . .
Mark
I put over 2000miles on mine this summer. EFI makes it daily driver reliable..
Re: Building a driver - use carburator or fuel injection ?? [Re: 451Mopar] #1133381
12/15/11 10:47 AM
12/15/11 10:47 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Electric choke ? ...I say that a std OEM choke-well piece is fine .. used with an alum intake.
Re: Building a driver - use carburator or fuel injection ?? [Re: dOc !] #1133382
12/15/11 02:21 PM
12/15/11 02:21 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Many reasons not to use standard choke.
#1 - it does not fit all intake/carb combinations, and negates the use of a spacer (unless you modify the choke rod.)
#2 - OEM choke will respond slow (if at all) unless using mainfolds with heat valve, along with heads and manifold with heat crossover. For performance the heat crossover is usually blocked, headers used, and I think the air-gap type intakes don't even have a crossover?
Overall, I'd go FI if it is in the budget.
Also, sorry about posting about the Edelbrock XT, that is a big block system.
Re: Building a driver - use carburator or fuel injection ?? [Re: 451Mopar] #1133383
12/15/11 02:42 PM
12/15/11 02:42 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
MANY reasons 451 ? .. but you only really mention TWO ...
.... and I have a feeling that the OP will have an app that does not apply to what you are suggesting.
Re: Building a driver - use carburator or fuel injection ?? [Re: dOc !] #1133384
12/15/11 07:09 PM
12/15/11 07:09 PM
BDW Online content
BDW  Online Content
Would FI eliminate the "steaky" fuel smell? I can't get my daughter or wife to go for a ride in the old clunker because they complain their clothes smell like gas afterwards.
I'm a cheap SOB, but it might be worth the extra $$$ if I could eliminate the smell of gas for 2-3hrs in the garage after getting home.
Re: Building a driver - use carburator or fuel injection ?? [Re: BDW] #1133385
12/15/11 07:56 PM
12/15/11 07:56 PM
IN
ahy Offline
ahy  Offline
IN
I would go FI... tolerent to different blends of gas, altitude and temperature. Thats the biggie. Another mile per gallon or so is a nice bonus.
I think the stock style 90's FI is now tunable. You can probably find somebody to help with a custom tune on a Magnum based engine if you step up the power a bit. FAST EZ EFI would be a good choice also.
On the fuel smell, if its coming from gas boiling or evaporating out of the carb, FI would stop it. If its caused by venting, maybe not. Vapors from the vent don't usually make a big stink so likley FI would fix it.
Re: Building a driver - use carburator or fuel injection ?? [Re: BDW] #1133386
12/15/11 07:59 PM
12/15/11 07:59 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
MUST BEEZ Berri Crab equipped !! ...
Re: Building a driver - use carburator or fuel injection ?? [Re: dOc !] #1133387
12/15/11 08:16 PM
12/15/11 08:16 PM
BDW Online content
BDW  Online Content
Mine is definitely a boiling problem. Car wouldn't even start after sitting. Added an insulator carb spacer and it cured that problem.
It's an Edlebrock carb, car starts and runs great.
But the STINK is aweful!
Re: Building a driver - use carburator or fuel injection ?? [Re: ahy] #1133388
12/15/11 09:11 PM
12/15/11 09:11 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you vent the fuel tank with a return style system you'll have fuel vapors..... If you do a closed system venting into a carcoal canister with a controlled purge there won't be a vapor issue.. Thats how I'm setting up my wagon
BTW Sorry Doc my Thermoquad percolated fuel same as my other Carters & Holleys.... Drive a car for a couple hours to get it good & hot then park it in a closed garage.. You'll be smelling fuel... Especially with the garbage fuel these days..Not so with a late model car...
Re: Building a driver - use carburator or fuel injection ?? [Re: 1_WILD_RT] #1133389
12/15/11 09:37 PM
12/15/11 09:37 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
As you know I have been to Tahoe and even higher altitudes. My car feels like it's missing 100 HP in Tahoe from when I'm at home at 800 ft. Even though I jet it way down and even give it more timing. It's a PITA changing jets and needlies every time we go to Tahoe or Reno to visit family.
And like what was said about exhaust smell, it's pretty bad in a challenger with stock style exhaust through the valance and the wind blowing the wrong way at a light or something. That's why I run AC almost all the time so the wife don't complain about the exhaust smell because the windows are up. FI would be great for that.
I used to run straight 110 leaded race gas and everyone noticed the smell and it was not too bad smelling. Then I started really driving my cars and couldn't afford race gas. Premium gas smells pretty bad by it's self. So last summer I dumped some grape scent into my gas tank and it smelled like grape for while. lol
I have return fuel lines on both my challengers and they don't smell like raw gas when I park them inside a garage after driving them. Now I do run stock style air cleaners that keep down the sound, smell and evaporation rate of the fuel bowl I believe. I vent both gas tanks back to the valve covers.
Come spring my exhaust will smell like cherry and vannila.
Page 2 of 4 1 2 3 4
