Page 1 of 4 1 2 3 4
Building a driver - use carburator or fuel injection ?? #1133350
12/13/11 05:35 PM
12/13/11 05:35 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
I am in process of building a 1970 B Body that I will drive - all over the place I hope ! . . . 360 with about 9.5:1 pistons, 1970 340 type cam, 727 auto and 3.23:1 rear end gears. Question I ask myself, is : should I go the route of fuel injection ?? You can get great products now, that you don't even need a return line ! They learn and then you just get in and turn the key. Granted it is about a $2k touch !!! That could pay for a lot of fuel with a carburator !
However, putting 10-15k miles on the car in a year, the ease of operation with the fuel injection would be appreciated - idle, start when cold, cold drivablity, etc. . . .
What would you guys do ?? I am good with a TQ for the 360, but wonder about upgrading to the EFI . . . .
Mark
Re: Building a driver - use carburator or fuel injection ?? [Re: a12rag] #1133351
12/13/11 05:47 PM
12/13/11 05:47 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd go efi, especially if it's a 4 season car...I wish I would've put EFI on my DD before kids when I could've afforded it....my car is a bit of a PITA in the winter with the electric choke being somewhat finicky and winter blend gas...
I'd probably start with a magnum 360 and use the '96-up JTEC computer with a tuner.
2017 Grand Cherokee Overland
Re: Building a driver - use carburator or fuel injection ?? [Re: a12rag] #1133352
12/13/11 05:48 PM
12/13/11 05:48 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
For as mild of a 360 as you want, you should swap in a 90's magnum 360 and run it off of the stock ECU. You can still rebuild the engine and have the cam reground to be a little more aggressive like the stock 340 cam. Swapping in the stock electronics won't cost you much and ideally suited to an application like this.
Re: Building a driver - use carburator or fuel injection ?? [Re: a12rag] #1133353
12/13/11 05:59 PM
12/13/11 05:59 PM
New Castle, Indiana
STINGRAY Offline
STINGRAY  Offline
New Castle, Indiana
...426 EFI
Re: Building a driver - use carburator or fuel injection ?? [Re: a12rag] #1133354
12/13/11 06:15 PM
12/13/11 06:15 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
I would go the TQ route .....with a 904 trans.
FI still is a PITA, expensive and does not work right all the time.
Re: Building a driver - use carburator or fuel injection ?? [Re: dOc …] #1133355
12/13/11 06:39 PM
12/13/11 06:39 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
What happened to the company that had EFI units that resembled carbs on the outside.
Financial ruin?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Building a driver - use carburator or fuel injection ?? [Re: dOc …] #1133356
12/13/11 06:50 PM
12/13/11 06:50 PM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
Not if he would use the factory ECM and a Magnum engine.That setup is bullet-proof as far as dependability is concerned. He could even use the A-518 O/D transmission for even better economy and drive-ability.
Karma has no menu. You get served what you deserve.
Re: Building a driver - use carburator or fuel injection ?? [Re: SKR8PN] #1133357
12/13/11 06:54 PM
12/13/11 06:54 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
That's what I'd do for a driver. Not the max hp setup, not the hardest/most expensive setup and pretty hard to kill.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Building a driver - use carburator or fuel injection ?? [Re: DaytonaTurbo] #1133358
12/13/11 07:52 PM
12/13/11 07:52 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Injection is so much nicer than a carb, I wish I had injection on my streeters. Sure would be nice when driving in different alititudes and not have to change jets.
Re: Building a driver - use carburator or fuel injection ?? [Re: Challenger 1] #1133359
12/13/11 08:11 PM
12/13/11 08:11 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
I've been batting around the idea of running an early 90s TBI set-up with a Megasquirt system on my 318 Coronet. Depending on what the JY parts cost I could probably have a working system for under $600.
No longer taking $h!t from anyone!
Re: Building a driver - use carburator or fuel injection ?? [Re: DUFFMAN] #1133360
12/13/11 08:14 PM
12/13/11 08:14 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I'll keep my carb I keep it simple.
Re: Building a driver - use carburator or fuel injection ?? [Re: moparpollack] #1133361
12/13/11 08:47 PM
12/13/11 08:47 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
Re: Building a driver - use carburator or fuel injection ?? [Re: meepmeep70] #1133362
12/13/11 08:50 PM
12/13/11 08:50 PM
Florida STAYcation
Florida STAYcation
x 33 .... are all of youz guyz members of the 'Squad ?
Re: Building a driver - use carburator or fuel injection ?? [Re: dOc …] #1133363
12/13/11 08:57 PM
12/13/11 08:57 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
not sure what squad means,but if you mean tripes then yes,i'm a big fan of old school
Re: Building a driver - use carburator or fuel injection ?? [Re: meepmeep70] #1133364
12/13/11 11:29 PM
12/13/11 11:29 PM
Rug_Trucker Offline
Rug_Trucker  Offline
The "Thermosquad!" Doc Glass is the general in charge!!
Someone modified the cover pic of the David Emanual Carter carb guide for us back in 2002???
Re: Building a driver - use carburator or fuel injection ?? [Re: Rug_Trucker] #1133365
12/13/11 11:46 PM
12/13/11 11:46 PM
my own world
theraif Offline
theraif  Offline
my own world
Iam not good with TQ all ways run Holley's but this MSD unit looks real good
http://www.atomicefi.com/
Re: Building a driver - use carburator or fuel injection ?? [Re: theraif] #1133366
12/13/11 11:51 PM
12/13/11 11:51 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Im part of the Thermosquad and proud of it! They run so well, it may as well be EFI
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Building a driver - use carburator or fuel injection ?? [Re: 69L78Nova] #1133367
12/14/11 02:20 AM
12/14/11 02:20 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
You can use a 92 Dakota wiring harness to wire the fuel unit on a Magnum 5.9 3 wires to connect. There's a thread in the tech archive I think. A member here named Scott [NFury8] has done this swap with a 2 pin 518 in a 69 W series CrewCab. Autometer sells a speed sensor that allows using the mechanical speedo. I'd use a Magnum engine either way
Re: Building a driver - use carburator or fuel injection ?? [Re: BulletBob] #1133368
12/14/11 02:28 AM
12/14/11 02:28 AM
Round Rock,Tx
N
Nirvana Offline
Nirvana  Offline
N
Round Rock,Tx
If you have the money,and you are not good with tuning carbs,then yes go EFI.
Me personally,I like to work on my cars for fun,and carb tuning is one of my favorite things to do. It cool to see the diff from changing one little thing. You pretty much only have to mess with a carb(once tuned right initially) if you are changing elevation and/or weather change,and at that it is usually just a jet change.If you get a wideband a/f gauge it makes fine tuning a carb very simple.
87 D100 225 4 speed.
Re: Building a driver - use carburator or fuel injection ?? [Re: Nirvana] #1133369
12/14/11 02:48 AM
12/14/11 02:48 AM
Portland Oregon
69Dartman Offline
69Dartman  Offline
Portland Oregon
IF I want to run a carb I use a ThermpQuad, easy to tweak and they just work when right, especially if you go with the 9800 aftermarket ones with the electric choke setup. The one on my Dart has sat for 4 years and I started it finally after a few years of setting. The accelerator pump was stuck but with some WD 40 and a few pumps of the rod it was AOK again and started running great, even on that old gas in the tank, even did a quick burnout in the driveway after everything was up to temp and working smooth again.
If I wanted max drivabilty and MPG I'd definitely go EFI, but like said many after market setups are way too spendy and you have to modify stuff to make it work. Some of the stock stuff and the later 360 factory stuff can can probably be done cheap and mega squirt and others might be a option if you want to go low bucks and aren't afraid to make things and do it yourself.
Simple, go TQ, more complex but maybe worth it EFI.
Life's a little bit better when you hit a Camaro.
Page 1 of 4 1 2 3 4
