Re: The best method for one person to bleed brakes? [Re: QuickDodge] #113117
08/31/08 10:01 PM
08/31/08 10:01 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Speed Bleeders (or another brands equivilent):
Ride eternal, shiny and chrome
Re: The best method for one person to bleed brakes? #113118
08/31/08 10:07 PM
08/31/08 10:07 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Just get the one man bleeder cup, I think mine is Lisle tool brand available at a lot of auto stores. It's simple and really works, I have used mine dozens of times. Gravity doesnt always work with the small diameter of the line you can get an airlock. Never used a suction pump but dont waist your money.Trust me on this one, I have owned almost 100 cars so far and the one man bleeder cups are easy to use really do work.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: The best method for one person to bleed brakes? [Re: mopargem] #113119
09/01/08 05:44 PM
09/01/08 05:44 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
I had to chuckle a little bit reading the above posts, not just the ones about making the wife pump the brakes way too many times, but also about the mity vac and the one-man tube with the check valve.
A couple of years ago when I was still helping my buddy at his shop, I tried the mity-vac...always slipped off the bleeder just as vacuum was built.
Recently I was trying to bleed my A100 brakes at home, went to the parts store and happily bought the tube+check valve tool. It stayed on for two pumps and always flew off afterwards. Quite "enjoyable".
So, as usual, YMMV, but for me the helper pumping the pedal is the chosen method. I don't mind being the pedal pusher.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: The best method for one person to bleed brakes? [Re: kick_the_reverb] #113120
09/01/08 06:09 PM
09/01/08 06:09 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Another vote for "wings440" ' s method.
The "mity Vac" black fittings are universal, alright, they universally FIT NO CAR I HAVE EVER TRIED to used them on !!!
I will use clear plastic tubing that more closely approximates the correct dimensions of the bleeder valve(s).
Thanks for nothing , "Mity Crock" !!! May you sink into bankruptcy...
Re: The best method for one person to bleed brakes? [Re: minivan] #113121
09/01/08 10:31 PM
09/01/08 10:31 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Take the cap off the master and open all the bleeders. Let them bleed with gravity until no air comes from the bleeder then close it. Keep the MS filled.
Simplest best way I have found also....
I have done this many times and it worked every time. I did both my sons Dart and my 63 like this by myself. But you have to make sure you get all the air and the MC does not get to low and suck in air. Ron
Re: The best method for one person to bleed brakes? [Re: 383man] #113122
09/02/08 08:21 PM
09/02/08 08:21 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I finally installed a usable Prop valve today, and gravity bled mine. The pedal seems fine, and the brakes are working. No volunteers, no wife, and the cat doesn't listen well, so I had to try this. May try the tube in the bottle trick next, I already had the tube which actually seems to stay on. I used rubber vacuum line.
Re: The best method for one person to bleed brakes? [Re: 4BBodies] #113123
09/03/08 09:44 AM
09/03/08 09:44 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Mityvac to get everything flowing then I gravity bleed a little bit more.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: The best method for one person to bleed brakes? [Re: justinp61] #113124
09/03/08 12:24 PM
09/03/08 12:24 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
There is also a pet [Edited by Moparts - Keep it clean] in line to break the vacuum when needed.
Ha, Ha. Apparently we need to be careful when typing 'petcock'.
As for the other, they make decisions for us, and some of them have names, but they are **not** pets!
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: The best method for one person to bleed brakes? [Re: Fury Fan] #113125
09/03/08 02:56 PM
09/03/08 02:56 PM
whosever wife you end up useing instruct her not to push the pedal past it's normal travel which moves the neoprene cups past their normal wear area & can hasten their demise. If she is instructionally impaired(& most are) put a block of wood under the pedal.
Re: The best method for one person to bleed brakes? [Re: RapidRobert] #113126
09/03/08 08:12 PM
09/03/08 08:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Or put the "wood" to her?
Re: The best method for one person to bleed brakes? [Re: DirectSubjection] #113127
09/03/08 08:47 PM
09/03/08 08:47 PM
Concord California
E
Evil_Ways Offline
Evil_Ways  Offline
E
Concord California
I agree, I used these on my Challenger, very simple to do!
