E Body Dash Speakers...What's the best solution? #113063
08/31/08 04:42 PM
08/31/08 04:42 PM
Tenn.
jrwoodjoe Offline OP
Tenn.
While working on the Challenger 3 Speaker Dash, I can not find an aftermarket speaker that will fit the mounting areas. I do have the correct grilles and mounting hardware. This is not a concours resto but really nice occasional driver and I would rather not cut the dash frame. Can I do it without cutting the dash frame for the small outboard speakers? What is the best solution for this.
Thanks, Joe
65 Barracuda
70 Challenger
Re: E Body Dash Speakers...What's the best solution? [Re: jrwoodjoe] #113064
08/31/08 04:57 PM
08/31/08 04:57 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Pony up!.....and buy a used set,....they aren't that bad,....if I recall, there's 3 different sets out there!,......68-70 B, Cuda' and Challenger, and 71 B have them reconed if necassary,....try Big Money Lewis, a member here, maybe he has a set?
Re: E Body Dash Speakers...What's the best solution? [Re: jrwoodjoe] #113065
08/31/08 08:13 PM
08/31/08 08:13 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Here is company that has lots of different sizes:
http://mcmelectronics.com/search.aspx?C=&K=speakers
Not sure of the right one that fits the dash but if anyone has the right size, this place will.
Craig
Re: E Body Dash Speakers...What's the best solution? [Re: denfireguy] #113066
08/31/08 11:28 PM
08/31/08 11:28 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
Can someone chime on the correct size speakers that go into the dash, and/or a specific selection or choice. I so see the one post above has a vendor, anyone else?
Re: E Body Dash Speakers...What's the best solution? [Re: gomangoRTSE] #113067
09/01/08 01:27 AM
09/01/08 01:27 AM
Alabama
BigMoneyLewis Offline
Alabama
Turnswitch.com is now offering the correct outer speakers for the E body 3 speaker dash (as well as all other mopar replacement speakers).
Greg
Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios
We can restore YOUR radio usually in less than 7 days
Visit our NEW website..
http://www.wardsclassiccarradiorepair.com
gregward@mchsi.com
phone 256-852-0955
gregward@mchsi.com phone 256-852-0955
Re: E Body Dash Speakers...What's the best solution? [Re: BigMoneyLewis] #113068
09/01/08 07:49 AM
09/01/08 07:49 AM
cataclysm80 Offline
cataclysm80  Offline
Do the turnswitch speakers work well with aftermarket CD players, or only with the factory radio?
I cut the dash frame on mine and will be using kicker 3.5 inch round speakers. I did that on my 'cuda and it sounds great.
Tav
Re: E Body Dash Speakers...What's the best solution? [Re: cataclysm80] #113069
09/01/08 08:15 AM
09/01/08 08:15 AM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
I don't know about the E-body three speaker dash but in a B-body the Alpine SPS-080A 3 1/2" speakers drop in without a problem. If it's a stock radio you might want to go the turnswitch route because of the ohm difference.
Re: E Body Dash Speakers...What's the best solution? [Re: Spike] #113070
09/01/08 09:11 AM
09/01/08 09:11 AM
Tenn.
Tenn.
Thanks for the input everyone. The original center speaker is intact. But it is so old it probably would not take too much use. BIGMONEY and Spike, I'll look at the company you suggested for a center speaker replacement. I did see one on the MCM site mentioned that might work for the center replacement also.
My current thoughts are to hook the factory radio up to that speaker so that it works, and then to "hide" a modern tuner and wire it into the front outboard and the rear package tray.
Re: E Body Dash Speakers...What's the best solution? [Re: jrwoodjoe] #113071
09/01/08 10:21 AM
09/01/08 10:21 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
If your wanting to keep it stock, you can have originals reconed. I had quite a few reconed by someone up in Mich. Cost was about 37.00 per, did'nt matter what size. PM me if you want his #
Re: E Body Dash Speakers...What's the best solution? [Re: jrwoodjoe] #113072
09/01/08 12:18 PM
09/01/08 12:18 PM
cataclysm80 Offline
cataclysm80  Offline
That sounds like a pretty good setup, best of both worlds. My center speaker doesn't do much with my aftermarket CD player in the 'cuda anyway.
Tav
Re: E Body Dash Speakers...What's the best solution? [Re: cataclysm80] #113073
09/01/08 01:17 PM
09/01/08 01:17 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Most GOOD aftermarket speakers will not fit on the driver side because of there bigger magnets that hang down on the switches on the switch panel but you can just put two 3 1/2 speakers in place of the center speaker as there is pleanty of room under there. I used two infinty cappa speakers there on my Challenger from cruchfield as Im going for a more modern sound quality with power amps and cd player. You can use the infinity cappas in the 2 sides but some modification of the dash frame and speaker besel will be required. It was just easier to use the center speaker hole for me....good luck.
Re: E Body Dash Speakers...What's the best solution? [Re: jrwoodjoe] #113074
09/01/08 07:32 PM
09/01/08 07:32 PM
texas
magnum440 Offline
magnum440  Offline
texas
fwiw....i installed a set of tweeters from radio shack 10 yrs ago,,still sound good,,bolted rite in...
Re: E Body Dash Speakers...What's the best solution? [Re: Challenger 1] #113075
09/01/08 09:10 PM
09/01/08 09:10 PM
Tenn.
Tenn.
Thanks for that offer. I do not have the original outboards speakers to send off. My outboard speaker covers came with a newer Pioneer speakers that will not fit. I may send him the center speaker if I keep it in place. Thanks for the offer and I will let you know if I need his info.
I didn't even look at the driver side. Thanks for the heads up and the tip about the 3 1/2s
RS was my first stop and the guy said they had not sold Car speakers in about 10 years. Sounds like you got yours just in time.
Joe
Re: E Body Dash Speakers...What's the best solution? [Re: jrwoodjoe] #113076
09/01/08 11:03 PM
09/01/08 11:03 PM
Upstate NY
Big_John Offline
Big_John  Offline
Upstate NY
These guys have the speakers and have conversions for your existing radio.
http://turnswitch.com/services.htm
Re: E Body Dash Speakers...What's the best solution? [Re: Big_John] #113077
09/01/08 11:43 PM
09/01/08 11:43 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
The new center speakers from turnswitch.com just came out, just released, same specs as stock - cost about $50. I got mine last month after someone here posted that they were finally available. Nice guy there, think about giving him a call, unless you want stock speakers, should call the guy Challenger1 uses.
Re: E Body Dash Speakers...What's the best solution? [Re: THESHAKERPROJECT] #113078
09/02/08 12:13 AM
09/02/08 12:13 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Thats intersting cause I've installed Infinity, Boston Accoustic, Polk Audio & JBL 3.5's in various E bodies & the only thing that hits is the steel dash frame which is pretty easy to notch for clearance & the mod is completely invisible unless you take things apart...
Re: E Body Dash Speakers...What's the best solution? [Re: 1_WILD_RT] #113079
09/02/08 12:57 PM
09/02/08 12:57 PM
cataclysm80 Offline
cataclysm80  Offline
add Kicker to that list.
Tav
Re: E Body Dash Speakers...What's the best solution? [Re: cataclysm80] #113080
09/02/08 04:32 PM
09/02/08 04:32 PM
NORTHERN VA
NORTHERN VA
Some will work if the magnet does not hang down to far but you better check it with the switches in place. On my Challenger it was so easy just to put both in the center speaker hole were there was a ton of clearance.
Re: E Body Dash Speakers...What's the best solution? [Re: THESHAKERPROJECT] #113081
09/02/08 05:58 PM
09/02/08 05:58 PM
cataclysm80 Offline
cataclysm80  Offline
I met a guy that put an 8 inch subwoofer under his center dash 4x10 opening. Only works on non AC cars though, the center AC vent ducting gets in the way. (ducting could probably be modified though) It sounded good, and you couldn't tell it was in there just by looking, but he said he had to make REAL sure everything was tight and stayed that way so the dash didn't rattle.
Tav
Re: E Body Dash Speakers...What's the best solution? [Re: cataclysm80] #113082
09/02/08 08:48 PM
09/02/08 08:48 PM
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
That's why I liked the Alpine speakers I posted, the magnet does not hang down low. There is not much room in a B-body three speaker dash and out of all the speakers I tried the Alpines and a set from Radio Shack were the only ones to fit with no magnet interference.
