STEERING SHAFT TO STEERING BOX ALIGNMENT? #1130477
12/09/11 02:09 PM
12/09/11 02:09 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Just swapped out a power steering box for a manual unit. I purchased the needed adapter,as well. With the box mounted,shouldn't BOTH shafts be in alignment? Mine is off,as seen in this picture! Thanks!
Re: STEERING SHAFT TO STEERING BOX ALIGNMENT? [Re: Labratt] #1130478
12/09/11 02:22 PM
12/09/11 02:22 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Randy,
I think if you loosen up the steering column at the firewall there should be enough play in it to line it up.
Give it a try, let me know if that works.
Gary
Re: STEERING SHAFT TO STEERING BOX ALIGNMENT? [Re: Mr340] #1130479
12/09/11 02:25 PM
12/09/11 02:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy,
Gary
Yeah you can move the toe plate some but the coupler
takes up some also... move the toe plate first
Re: STEERING SHAFT TO STEERING BOX ALIGNMENT? [Re: Labratt] #1130480
12/09/11 02:44 PM
12/09/11 02:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also... your torque converter is done so you can
pick that up any time
Re: STEERING SHAFT TO STEERING BOX ALIGNMENT? [Re: MR_P_BODY] #1130481
12/09/11 04:19 PM
12/09/11 04:19 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Gary,Mike! Gary,I won't be messing with it until Monday..it's at the painter's house. Mike,not sure when I can head out your way..I'll give ya a heads-up when I do! I know Jeff wants me to pick up my heads..and manifold,which he milled to compensate for the .055-.060 cut on the heads..on Saturday. Thanks for taking the time to fix that tooth..Dr.P-Body!
