Re: Weird Moroso anti-roll (line lock) kit question
[Re: radar]
#1130032
12/18/11 01:33 AM
12/18/11 01:33 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Does the small hex end of the line lock solenoid fit into the aluminm bracket?
[Re: NTOLERANCE]
#1130033
12/18/11 02:11 AM
12/18/11 02:11 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I was thinking maybe the switch clamped into the bracket and you were suppose drill 2 holes in your shifter to mount it. Also , I have never seen a switch that looked like that, but if it works , OK. , I've got a Hurst thats over 40 years old and never had a problem, just taped it on the shifter with electrical tape, things were more simple back then. I have replaced the tape a few times though.
[Re: NTOLERANCE]
#1130034
12/19/11 09:23 AM
12/19/11 09:23 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
That is what I thought it's intention was.
How is the solenoid mounted?
[Re: radar]
#1130035
12/19/11 11:06 AM
12/19/11 11:06 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Interesting,
That bracket is not for the switch, its for the line lock solenoid. Look at the hex shape at the end of the solenoid, that will fit right in the bracket so you can mount it. Without that bracket tell us how the solenoid will be mounted?
68 Barracuda Formula S 340
[Re: radar]
#1130037
12/19/11 05:37 PM
12/19/11 05:37 PM
Posts: 1,505 TN
SCATPACK 1
TN
Kevin if memory serves me, Never mind. LOL I see you already solved it.
Old Geezer Racing
