Re: 340 oil filter adapter
[Re: RoadRunnerJD]
#1129272
12/07/11 03:59 AM
12/07/11 03:59 AM
RapidRobert
50. thin washer under bolt head, thick cork inside on bolt
[Re: RoadRunnerJD]
#1129276
12/07/11 11:41 AM
12/07/11 11:41 AM
RapidRobert
With your exhaust etc all hooked up lightly snug the bolt then clock it at the point where it clears everything the best & gives best access to get at the filter as you wont be moving it around next time you ch the filter. Not sure but I think some adapters may have a ridge or boss that will interfere w the block at a certain clocking but no prob just mock it up dry w no gaskets/find the best position then go togther. Make sure the block circular recess is squeaky clean and the circular gasket can slip out of position: Hold the adapter/gasket high and tight against the block then lightly snug the bolt then clock it/then 50 lbs. EDIT there is no exact index mark or point. Get the best clearance (to the frame/eng) & you're set
