Re: posi trak
[Re: vratman 69]
#1128423
12/05/11 10:35 PM
12/05/11 10:35 PM
RapidRobert
No posi's here just an occaisional sure grip. Car in neutral, jack 1 wheel just off the ground & bear hug it & if it turns forward easily it is not a sure grip. If it turns a bit with alot of grunt then it is a sure grip & confirms you are in neutral & roughly confirms how tight the sure grip clutches are
Re: posi trak
[Re: RapidRobert]
#1128427
12/06/11 01:22 AM
12/06/11 01:22 AM
DaytonaTurbo
Manitoba, Canada
Yup. That or if you have the car up on the hoist and in neutral, with a suregrip both tires will spin the same way when you turn one tire by hand. With an open diff, one will spin backwards.
