six way seat #1127678
12/04/11 11:24 PM
12/04/11 11:24 PM
texas
magnum440 Offline OP
texas
hello ,,i noticed seat rockin back and forth like the seat loose,,but it seems like its the rivets on the front of sixway assembly,,they have play...any tips on a fix,,thanks in advance.
Re: six way seat [Re: magnum440] #1127679
12/05/11 09:27 AM
12/05/11 09:27 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
when i made my passenger side six way i flipped those brackets to make it.
the rivets are shoulder type rivets. now the part that gets rolled over is starting to loosen. just grind off the rivet head, put the rivet back in the proper place and re-weld the rivet area you just ground off.
perception is 90% of reality
Re: six way seat [Re: Mr T2U] #1127680
12/06/11 03:04 PM
12/06/11 03:04 PM
texas
texas
thanks for response...passenger six way seat thats interesting,, id rather replace the rivets if possible,,plus once i drill rivet the hole may be oval shaped shaped also so might need a bushing or larger diameter rivet possibly,,,are these rivets available? or any other rivet that will hold up.
Re: six way seat [Re: magnum440] #1127681
12/06/11 08:14 PM
12/06/11 08:14 PM
Mr T2U Offline
Mr T2U  Offline
i didn't drill out my rivets. i ground the small head of the rivet and used a hammer and punch to drive out the rivet. when i replaced them i welded the small end to the bracket.
i don't think new rivets are available. you might find a shoulder bolt to fit. or maybe use a regular bolt with a bushing.
Re: six way seat [Re: Mr T2U] #1127682
12/07/11 02:23 PM
12/07/11 02:23 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Sorry for being O/T, but didn't someone mod a six-way seat to fit the passenger side?
Re: six way seat [Re: 2fast4yourBrain] #1127683
12/07/11 03:20 PM
12/07/11 03:20 PM
texas
texas
yeh mrt2u did ,,im just tryin to repair the loose front rivets on mine to stop it from rocking back and forth...bolts wont work ,it has to have rivets so i dont want to drill them out and not be able to find any,,if not i might just do what mr t2u did...
