Page 1 of 3 1 2 3
Dynomax mufflers VS Flowmasters #1126500
12/03/11 03:09 AM
12/03/11 03:09 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
There was an interesting post recently about the flow ratings of todays top selling mufflers, with a product from Dynomax testing better than the others. One person posted a spec sheet with the ratings, which was quite helpful, except......HOW do you translate flow ratings into a gain/loss comparison in terms of horsepower? I understand that the Dynomax had a far higher rating, somewhere near 99% with the trusty Flowmaster being in the sub 50% range. I'm curious since I have Flowmaster 42451 mufflers in the Charger and have been pleased with the sound, but if there is some power to be gained here..... Any comments?
Re: Dynomax mufflers VS Flowmasters [Re: Kern Dog] #1126501
12/03/11 03:59 AM
12/03/11 03:59 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm not really sure about power, but I think the Dynomax mufflers sounds better than any Flowmaster muffler I've ever heard. imo
Re: Dynomax mufflers VS Flowmasters [Re: Kern Dog] #1126502
12/03/11 04:28 AM
12/03/11 04:28 AM
Idaho, USA
W
White440 Offline
White440  Offline
W
Idaho, USA
I'm a fan of the tone that Flowmaster produces but I can definitely see how a straight (or straighter) flow muffler would have less resistance and inversions then a baffled design which would equate to better top end flow or so I would think.
"Full throttle until you see GOD then brake!" <img src="/ubbthreads/images/graemlins/drive.gif" alt="" /> Life's to short to ride the brakes!
Re: Dynomax mufflers VS Flowmasters [Re: Challenger 1] #1126503
12/03/11 04:30 AM
12/03/11 04:30 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
I have a pair of dynomax muffs on my car and they give it a nice tone at idle and full throttle but quiet in side the cabin. Have never ran flowmasters but have some buddys that do and they sound good. I did start my car up when I 1st put it together and ran it around the block with open headers, it sounded like john force took a ride around the block. It rattled my neighbors windows and people I did not know came out of their houses to take a look. The dynomax units took care of that and never seemed to hurt the performance. I bought mine thru TTI.
Re: Dynomax mufflers VS Flowmasters [Re: SCATPK] #1126504
12/03/11 10:28 AM
12/03/11 10:28 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I hate flow masters, they sound hollow. They have that Mustang sound. I have Dynomax super tubos with 3" exhaust. Being an old fart I added 12" Summit glass packs because I didn't like the drone inside the car when cruising aroung 2000 RPM. My younger friends loved the sound all the way through the RPM range. When I nail it going on the freeway ramp next to Home Depot, I always get at least one comment the next time I go back to the store.
Re: Dynomax mufflers VS Flowmasters [Re: Kern Dog] #1126505
12/03/11 11:58 AM
12/03/11 11:58 AM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
It is an impossible question due to the variables involved, but, a common rule of thumb says we need about 2.2 cfm of exhaust flow per each one hp produced.
This means that Flowmasters may not be a restriction on an engine that is producing 300 hp, but, they might be on one that is making 700.
We also have to remember that if we are running dual pipes that each muffler is only dealing with half the hp and that the entire system must be considered with regard to flow and not just the mufflers.
Many seem to feel that a 2.5" system begins to become a drag on the total power around 500 hp or so. This might be a more pressing problem than which muffler was chosen. There are plenty of charts online showing the flow potential of various pipe diameters.
Personally, I cannot stand the sound of flowmasters so I don't need much more reason to use Ultra Flos or similar.
Steve
Re: Dynomax mufflers VS Flowmasters [Re: Kern Dog] #1126506
12/03/11 02:25 PM
12/03/11 02:25 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I agree with what was said about the level of horsepower you are at.
If everything is laid out and the Dynomax can outflow the Flowmaster, is it worth it to cut your exhaust off (is it falling apart, does it need to be replaced?) and change everything out just to gain maybe 5 hp at WOT?
A little bit of back-pressure is a good thing for everyday part-throttle driving. If it's balls to the wall WOT performance you are after, maybe a set of electric cut-outs would be the way to go instead.
Off-topic, but I have a single Flowmaster on my 360 Magnum and that thing has at least 130,000+ miles on it and the case is still solid with no sign of leaks anywhere. Very happy with the build quality.
Mo' Farts
Moderated by "tbagger".
Re: Dynomax mufflers VS Flowmasters [Re: Grizzly] #1126507
12/03/11 02:32 PM
12/03/11 02:32 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Funny how the little "single" chamber Flowmaster wasn't on that list, just the two and three chambers.
Re: Dynomax mufflers VS Flowmasters [Re: pinkduster] #1126508
12/03/11 03:15 PM
12/03/11 03:15 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Maybe because the single chambers should be compared to "open headers" ???
Re: Dynomax mufflers VS Flowmasters [Re: Pacnorthcuda] #1126509
12/03/11 03:20 PM
12/03/11 03:20 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Easy comparison --
Dynomax:
Flowmaster:
Re: Dynomax mufflers VS Flowmasters [Re: Hotwheelsjr] #1126510
12/03/11 03:57 PM
12/03/11 03:57 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
On a big block the Dynomax Super Turbos always sounded good.
On my 318 small block,I run the Thrush Turbo's
Flowmaster makes your car sound like a Chevelle or a Mustang,IMO.
Like the threads here on wheels and tires,mufflers are a personal choice,so to each their own.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Dynomax mufflers VS Flowmasters [Re: 68Cbarge] #1126511
12/03/11 10:06 PM
12/03/11 10:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Since I race my car thru the mufflers it only made sense to run the Dyno-Max Ultra-Flows since they are straight thru. I like the sound and performance of the Dyno-Max.
I can tell you we have the Flow Master 40's on my sons Dart and it picks up 2 tenths when uncapped. Ron
Re: Dynomax mufflers VS Flowmasters [Re: 383man] #1126512
12/03/11 10:12 PM
12/03/11 10:12 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Dynomax following the QTP's and TTI's.
Re: Dynomax mufflers VS Flowmasters [Re: Kern Dog] #1126513
12/03/11 10:38 PM
12/03/11 10:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You need to understand that exhaust when HOT has a
large volume(area)... most SB can use a 3 1/2" collector
but as you go down stream the exhaust cools and reduces
in volume(area) and the cooler the exhaust is the
easier it is to control the sound... the farther back
you put the muffler the better off you are... if you
notice that the new Hemi cars the mufflers are at
the back bumper.. we did that for power, sound and
the reduction of back pressure
Re: Dynomax mufflers VS Flowmasters [Re: pinkduster] #1126514
12/04/11 03:14 AM
12/04/11 03:14 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Here's what the single chamber FM looks like on the inside - looks like the exhaust instantly hits a wall upon arrival into the muffler. This causes a huge backlash, which is NOT good. I'd rather run a longer one! We tested 2 & 3 chamber, & Delta Flow FM's when I worked at Dynomax. The 2.5" AND 3" of these series FM's had flow rates of right around 350 sCFM. This translates into 318 loss-free HP with a dual exhaust setup. The Super Turbo 17748 (2.5" x 20" Hemi Super Turbo) has a flow rate of 415 sCFM, which = 378 loss-free HP dual exhaust. A straight-through stainless 2.5" Ultra Flow (#17289 offset/center) has a flow rate of 955 sCFM, which allows 868 loss-free HP on dual exhaust. This is the best flowing 2.5" x 20" oval, offset/center muffler on the market, bar none. The deflector setups inside the Flowmaster mufflers are horrible for flow - they totally kill the flow velocity of the exhaust. Buy them for sound, but not performance.
BTW, a Dynomax 3" x 20" offset/center oval Super Turbo #17769 flows 551 sCFM, which provides 500 loss-free HP on a dual exhaust. A 3" Welded Ultra Flow (20" body, offset/center) #17233 flows 1800 sCFM thus providing 1636 loss-free HP. You can decide from here!
Re: Dynomax mufflers VS Flowmasters [Re: MR_P_BODY] #1126515
12/04/11 03:22 AM
12/04/11 03:22 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
long story short I wanted a pair of mufflers for my '68 road runner a few years back and thought that I would do a set of Flowmasters at first but someone that ran F.A.S.T told me to go with the Dynomax Ultra-Flows so I did and they worked great and sounded even better.....although I was kind of curious how the imfamous Flowmasters would have sounded..........fast forward to getting the '69 GTX and it having a new exhaust system that was already on there by the previous owner with Flowmasters.........I CAN'T STAND THEM!!!!, my wife CAN'T STAND THEM!!!!....anyone want a pair of Blowmasters???? I'll take a pair of Dynomax Ultra Flows over anything now....and I think they are of the same straight through design with a perforated core and (glass wool) packing as the original factory mufflers if I'm not mistaken, so no wonder why they sound like the car was supposed to sound
Re: Dynomax mufflers VS Flowmasters [Re: Sunroofcuda] #1126516
12/04/11 03:31 AM
12/04/11 03:31 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
No wonder the GTX feels like the exhaust has a cork in it compared to the stainless Ultra-Flows.....that's it the Slowmasters are coming off in the Spring...
MikeR
Re: Dynomax mufflers VS Flowmasters [Re: A12] #1126517
12/04/11 04:18 AM
12/04/11 04:18 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Used to work @ NAPA, and kind of got the straight from the Walker Rep.
Then was @ MATS a few years ago, and they stated clearly that Dynomax is the only true "zero loss" muffler.(Not sure which exact ones, probably the ultra flows)
Re: Dynomax mufflers VS Flowmasters [Re: Sunroofcuda] #1126518
12/04/11 01:51 PM
12/04/11 01:51 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Yeah, that's what the center in / dual out looks like, but what about the center in / center out? My car had the huge three chambers on it when I bought it. I recently switched to the little single chambers for two reasons. #1, I wanted to see if I'd pick up at the track, and #2, I wanted the car to be as loud and obnoxious as possible, but not run cut-outs. I picked up .02 and 1 mph at the track and yes, the car is crazy loud and 100% totally obnoxious. Simply out of curiosity, I think I'm going to buy a set of these hopefullyflows that everybody here is in love with and see if they actually make any difference at the track without any other changes to the car. Now THAT would be a real world test.
Re: Dynomax mufflers VS Flowmasters [Re: pinkduster] #1126519
12/04/11 03:34 PM
12/04/11 03:34 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
After an exhaustive image search on Google and Bing, I have determined that the image posted by sunroofcuda is NOT a Flowmaster muffler. It is a Flowsound muffler. I was unanble to find a cut away image of a center in / center out Flowmaster race muffler. However, I did find this image of a single chamber Flowmaster. So I assume the center in / center out would be similar.
Regardless, I'll try some Ultra Flows next season. My exhaust is set up so I can easily change from my little single chambers and dumps, to the three chambers and dumps or tailpipes. I'll just add a third option to the mix. And I'd be happy if it would pick some ET.
Page 1 of 3 1 2 3
