Analyze my static compression & leakdown #'s #1126373
12/02/11 09:27 PM
12/02/11 09:27 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
Here are some numbers for a static compression & leakdown test on my 340 T/A engine. Cylinders are bored .030 over, I don't remember the head milling, but I'm supposed to have a compression ration of 10.2:1. The cam is a Comp Cams Hi Energy 268 (218° @.050 / .464"). The engine has 40,000 miles on it's rebuild.
Compression-static
1) 141psi 2) 140psi
3) 145psi 4) 140psi
5) 140psi 6) 142psi
7) 140psi 8) 141psi
Leak Down Test
1) 6% 2) 5%
3) 5% 4) 3%
5) 2% 6) 4%
7) 5% 8) 5%
Thanks!
Re: Analyze my static compression & leakdown #'s [Re: T/A CARe] #1126374
12/02/11 09:30 PM
12/02/11 09:30 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Compression numbers are all real close this is good and leakdown is less than 10% also good. I'd say compression is not 10:1 for only 140 PSI. My 9:1 451 pumps up much more than this.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Analyze my static compression & leakdown #'s [Re: HemiRick] #1126375
12/02/11 09:33 PM
12/02/11 09:33 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
cylinder pressure seems a little low but leakdown is good for the miles. if it drives and runs good i wouldn't touch it.
Re: Analyze my static compression & leakdown #'s [Re: lewtot184] #1126376
12/02/11 09:42 PM
12/02/11 09:42 PM
All good in the 'hood ex as said comp #'s are low. Alot of SCR #'s have not been actually measured/calculated & are lower than people think
Re: Analyze my static compression & leakdown #'s [Re: T/A CARe] #1126377
12/02/11 09:45 PM
12/02/11 09:45 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Everything looks fine, the only thing wrong is the compression ratio. Probably less than 9:1
Re: Analyze my static compression & leakdown #'s [Re: T/A CARe] #1126378
12/03/11 04:33 AM
12/03/11 04:33 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
It looks good! I guess nobody noticed your in Colorado Springs.
Air pressure is only about 12.2 psi?
Doing the dynamic compression calc backward with an intake closing point of 60 abdc, I get 10.25:1 static compression ratio?
If you were at sea-level (14.7psi), cylinder pressures would be about 169 psi.
Re: Analyze my static compression & leakdown #'s [Re: 451Mopar] #1126379
12/03/11 09:57 AM
12/03/11 09:57 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
6000 ft sure does make a difference!
Re: Analyze my static compression & leakdown #'s [Re: 451Mopar] #1126380
12/03/11 11:22 AM
12/03/11 11:22 AM
As double R would say, Ding Ding Ding I do believe we have a winna
Re: Analyze my static compression & leakdown #'s [Re: RapidRobert] #1126381
12/03/11 11:48 AM
12/03/11 11:48 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Yep the 140's is pretty good for up here. Have seen most new factory motors hit the 160's here at 5000'
I'd be happy with his build. Has good consistent numbers. He's at about 6000' over there in CS.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Analyze my static compression & leakdown #'s [Re: moparmarks] #1126382
12/03/11 06:29 PM
12/03/11 06:29 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
Thanks guys! And yup, we're just a tad over 6,000' here.
'Preeshadit!
Re: Analyze my static compression & leakdown #'s [Re: T/A CARe] #1126383
12/03/11 06:40 PM
12/03/11 06:40 PM
'Preeshadit!
Not enough oxygen
Re: Analyze my static compression & leakdown #'s [Re: RapidRobert] #1126384
12/04/11 05:54 PM
12/04/11 05:54 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
'Preeshadit!
Not enough oxygen
