Page 2 of 3 1 2 3
Re: 71 Dart Drum brake problems [Re: joedust451] #1126271
12/03/11 01:44 AM
12/03/11 01:44 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The car stops poorly all ready and you want me to make the rear brakes work worse. No thanks. I'll stick with fixing the problem in the fornt.
Your not going to get the car to act like it has disc brakes, drum brakes alway stop poorly, plus your asking for opinions because you don't know what the problem is, i'm only trying to help as i've had this problem before on other drum brake cars, i'm not telling you to loosen the crap out of them, all it takes is backing them off a bit thats all or tighten up the fronts, its not rocket sience, just trial & error, but you do what you want.
My 69 383 GTS has 4 whl drum , I've never had the fronts lock only the rear.
People are so used to driving new cars they forget how bad the old brake systems really were .
Want to rule out the distribution block, take it out of the equation, tee the front lines to master cylinder line and do the same to the rear.
Re: 71 Dart Drum brake problems [Re: JohnRR] #1126272
12/03/11 09:55 AM
12/03/11 09:55 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
That's a good idea.
FWIW, my fronts lock up no problem. Not after they're hot, but cold, yes. Of course, I just changed the shoes and drums. Before that, they were scary...
Re: 71 Dart Drum brake problems [Re: HemiRick] #1126273
12/03/11 04:32 PM
12/03/11 04:32 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Well it's not anything clogging the lines or brake valve as I had them off the car and apart and they are clean and clear....We have ordered a master cylinder as its the last thing it could be and its only $15. It'll be here Tues.
If it's the master it'll be the 1st time I've seen a master fail this way in 35 yrs of fixin cars.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 71 Dart Drum brake problems [Re: bobs66440] #1126274
12/03/11 04:43 PM
12/03/11 04:43 PM
I had exactly the same issue with my '70 Mustang (disc front brakes, but using this to make a point). No matter what I did, I couldn't get that car to lock the fronts. EVERYTHING was new. I even got very expensive cold stopper pads from Ca. In the end I went to AutoZone and got a set of $18 pads. Bang! Fixed. It may be as simple as brake shoe compound or having the drums turned.
Last night I got to thinking & was wondering if that is it. Not enough friction on tthe shoes
Re: 71 Dart Drum brake problems [Re: RapidRobert] #1126275
12/03/11 05:35 PM
12/03/11 05:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The rears lock up because they have less weight on them. If you brake hard that shifts even more weight to the front as the rear lifts and the nose dives.
Re: 71 Dart Drum brake problems [Re: stumpy] #1126276
12/03/11 07:23 PM
12/03/11 07:23 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I don't think any of my old Mopars that I currently own, or any that I owned in the past would lock up the front before the rear. I think the A-bodies are worse for locking up the rears too quickly.
Re: 71 Dart Drum brake problems [Re: HemiRick] #1126277
12/03/11 07:43 PM
12/03/11 07:43 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
The brakes are all freshly adjusted by me and are just off the drums.
Supposed to have light contact. Just off the drum in itself will cause the drum to lock up when it suddenly hits the drum. The rears are supposed to lock up first. So you can still steer. Once lock up accurs you should let off. Pump the brakes when in a panic stop situation. Anti lock brakes came about because people panic and lock em up. This leaves no control of the vehicle.
I have mechanical Aptitude.
I can screw up anything.
Re: 71 Dart Drum brake problems [Re: RapidRobert] #1126278
12/03/11 07:44 PM
12/03/11 07:44 PM
bobs66440 Offline
bobs66440  Offline
My guess is that's what it is. I really don't think it's the master cylinder. The OP hasn't answered yet if the drums were turned. If they are glazed, it could cause this, even with new shoes.
Re: 71 Dart Drum brake problems [Re: bobs66440] #1126279
12/03/11 08:23 PM
12/03/11 08:23 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
No the drums have not been turned, they appear to be normal in all respects. They have brand new Autozone brake shoes in them. If the master doesnt help well try turning the drums next.
Take care,
Rick
Re: 71 Dart Drum brake problems [Re: HemiRick] #1126280
12/03/11 10:25 PM
12/03/11 10:25 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Something just occured to me that points that the MC may be the problem. 1st thing I did this morning was a test. I opened a rear bleeder valve and stepped hard on the brake pedal, thinking that if the piston in the brake valve was stuck in on the front side that this might push it back. It had no effect but the brake warning light did NOT come on either.
I think the brake warning light didn't come on because the front brake side of the master is not making proper pressure. I found another master and should have one tomm. instead of Tues.
Take care,
Rick
Re: 71 Dart Drum brake problems [Re: HemiRick] #1126281
12/04/11 01:29 AM
12/04/11 01:29 AM
bobs66440 Offline
bobs66440  Offline
You know, thinking about it, I'm not really sure how well those things work anyway. I mean, in theory, just bleeding the brakes should make it cut the pressure one way or the other. If it worked the way they say, you wouldn't be able to bleed the brakes! Every time you cracked open a bleeder, the flow would stop.
Re: 71 Dart Drum brake problems [Re: bobs66440] #1126282
12/04/11 01:53 AM
12/04/11 01:53 AM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
The valve is not designed to restrict flow in any way shape or form and theres no way it can even if it mal functions. Its only function is to turn on the light.
Take care,
Rick
Re: 71 Dart Drum brake problems [Re: HemiRick] #1126283
12/04/11 02:08 AM
12/04/11 02:08 AM
Rick when is that M/C going to get here
Re: 71 Dart Drum brake problems [Re: HemiRick] #1126284
12/04/11 07:48 AM
12/04/11 07:48 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Are the brakelines connected correctly coming from the MC;
Rear port for the front brakes and the front port to the rear brakes?
Re: 71 Dart Drum brake problems [Re: HemiRick] #1126285
12/04/11 01:34 PM
12/04/11 01:34 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
OK I'll bring this up again. The rear brakes should lock up 1st but not at light or normal conditions.
The O.P. said;
This will do exactly what is happening. The wheels will lock up right away because of the sudden contact.
Remember drums are a self-energizing system.
Just off the drum is wrong. There must be a slight contact.
Am I wrong or is this procedure wrong? Also new shoes on shinny old drums is not a good idea get 'em turned it doesn't cost that much.
What kind of master are you getting for $15.oo? Just a little curious about this.
Re: 71 Dart Drum brake problems [Re: bboogieart] #1126286
12/04/11 01:38 PM
12/04/11 01:38 PM
bobs66440 Offline
bobs66440  Offline
I've always run mine with a little bit of drag.
I agree
Reman master cylinders at AutoZone are very cheap. I think I paid $23 for mine.
Re: 71 Dart Drum brake problems [Re: bobs66440] #1126287
12/04/11 02:39 PM
12/04/11 02:39 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
Something about cheap brake parts and Autozone doesn't sound good. Come on, buy some good parts, not cheap Auto Zone. I seen many pads wear out in less than a year for them.
This is one area I won't skimp on, brakes!
If the rear brakes lock up first you are going to spin! Peroid. Unless you get off the brakes.
Sounds like a bad O ring in the Master cyl to me.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: 71 Dart Drum brake problems [Re: express] #1126288
12/04/11 05:24 PM
12/04/11 05:24 PM
bobs66440 Offline
bobs66440  Offline
I can't speak for their brake pads, other than theirs were the only ones that worked properly in my Mustang. I bought "expensive" ones and they were crap.
Regarding their master cylinders, they are reman factory ones, the same as anywhere else. I have one in my car for almost 2 years and it's working perfectly.I got brake drums for my pickup from NAPA because they are supposed to have better products and they came in warped. Then they screwed them up trying to turn them.
Just because you pay a lot of money, doesn't mean you are guaranteed a better product.
Re: 71 Dart Drum brake problems [Re: express] #1126289
12/04/11 05:25 PM
12/04/11 05:25 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
there have been several articles in different mopar magazines over the years about the propensity of Abody cars to lock up the rear brakes----and if i remember right it was the distribution block problem---bob
Re: 71 Dart Drum brake problems [Re: express] #1126290
12/04/11 10:13 PM
12/04/11 10:13 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
the az MC is usally a A-1 cardone part, same as napa,advanced and oreiliys...
Page 2 of 3 1 2 3
