Page 8 of 10 1 2 6 7 8 9 10
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125415
04/22/12 02:47 PM
04/22/12 02:47 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Made a firewall plate out of diamond plate and installed with carraige bolts. Heater box would not fit with the 512 valve covers. Down the road I will install a small vintage air heater unit. Might be a good place to mount my MSD box too.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125416
04/22/12 02:52 PM
04/22/12 02:52 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Used scratch's pattern to make a plate to mount the aluminum master cylinder.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125417
04/22/12 02:55 PM
04/22/12 02:55 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Made up a couple of 1/4" mild steel reinforcement plates for the rear of the firewall. Might be a little overkill though
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125418
04/22/12 05:10 PM
04/22/12 05:10 PM
scratchnfotraction Offline
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125419
04/22/12 07:14 PM
04/22/12 07:14 PM
Lehigh Acres, Florida
rickstershemi Offline
Great Idea
Rickster
Re: Junkyard D150 Progress [Re: rickstershemi] #1125420
04/22/12 08:25 PM
04/22/12 08:25 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Looks like I'm not the only that is using diamond plate. That motor sure looks good rickstershemi. I like the highlights and the dark and the red contrast.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125421
04/22/12 09:30 PM
04/22/12 09:30 PM
Great minds think alike
Rickster
Re: Junkyard D150 Progress [Re: rickstershemi] #1125422
05/22/12 08:22 PM
05/22/12 08:22 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Well got the front clip on; the aftermarket fender will need massaging before paint.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125423
05/22/12 08:24 PM
05/22/12 08:24 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Went with a 26" wide 4 core Champion radiator from one of the board members.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125424
05/22/12 08:26 PM
05/22/12 08:26 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Painted the inner fenderwells and core support black crinkle finish
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125425
05/22/12 08:28 PM
05/22/12 08:28 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Battery tray truned out great after sandbalsting the rust off and painting it
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125426
05/22/12 08:29 PM
05/22/12 08:29 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Lakewood driveshaft loop. Saving up the $$ for a driveshaft and shifter; slowly but surely....
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125427
06/24/12 05:27 PM
06/24/12 05:27 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Found a driver quality grille surround, 2 repro headlight bezels, and used my grille center section.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125428
06/24/12 05:30 PM
06/24/12 05:30 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Most of the engine and body wiring is complete. Everything seems to work, so far.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125429
06/24/12 05:34 PM
06/24/12 05:34 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Truck originally had a 318 with a 4 speed OD transmission. I made a plate out of galvanized that should be stout enough to mount my ratchet shifter to with a steel base plate.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125430
06/24/12 05:36 PM
06/24/12 05:36 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Installed an inexpensive Grant steering wheel with adapter that fits nicely. Truck had cruise control and replaced the turn signal lever with a NOS Volare one that fits perfectly and it was cheap too.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125431
06/24/12 06:35 PM
06/24/12 06:35 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Sweet!
Moparlee
Re: Junkyard D150 Progress [Re: Robbins] #1125432
06/24/12 08:12 PM
06/24/12 08:12 PM
New York
jagrunt551 Offline
jagrunt551  Offline
New York
Looking real nice Great job
Re: Junkyard D150 Progress [Re: jagrunt551] #1125433
06/24/12 08:55 PM
06/24/12 08:55 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks guys; the interior and the engine compartment will be nice, but I still need some body work done on the cab. But it keeps me occupied and out of the rocking chair
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125434
07/24/12 08:53 PM
07/24/12 08:53 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Carpet installed with sill plates; fit was good with no trimming except for under dash.
