Page 2 of 10 1 2 3 4 9 10
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125295
12/11/11 04:31 PM
12/11/11 04:31 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
The welder is going to show up Mon Morning, so I thought that I would use my engine hoist to raise the frame so it wouldn't be so hard to weld.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125296
12/11/11 04:33 PM
12/11/11 04:33 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Plumbed in the brake lines and installed adel clamps to secure the lines. Also installed the center link, idler arm and pass side tie rod assembly.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125297
12/11/11 04:35 PM
12/11/11 04:35 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Rear brake line
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125298
12/11/11 04:38 PM
12/11/11 04:38 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Friend of mine said that I should highlight the valve covers after I painted them black wrinkle. So I used a sanding block and crocus cloth to remove the paint off of the highlighted Indy Logo.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125299
12/11/11 05:34 PM
12/11/11 05:34 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
WOW! Your frame looks great! I love to see the progress, It gives us inspiration!
Re: Junkyard D150 Progress [Re: 77ProStreet] #1125300
12/11/11 07:44 PM
12/11/11 07:44 PM
scratchnfotraction Offline
100%,he has raised the bar for detail and workmanship.
progress updates
VC are SSWWWWEEEEEEEETTTTT!!!!!!!!
Re: Junkyard D150 Progress [Re: scratchnfotraction] #1125301
12/11/11 08:10 PM
12/11/11 08:10 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Wow!! That really looks good I am going to redo my 4x4 frame next year and hope it looks half as good as yours. Keep up the good work!! That garage looks more like a vehicle bedroom than a garage
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Junkyard D150 Progress [Re: G-Money1320] #1125302
12/11/11 08:13 PM
12/11/11 08:13 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks guys; I spend so much time in the garage that my wife says I might as well move a bed out there.
Anyway I should be able to get the front crossmember welded tomorrow morning then I can press on with the rest of the frontend...
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125303
12/11/11 08:17 PM
12/11/11 08:17 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Also installed the motor mount brackets; will have to decide what mounts to use as the 512 shakes a bit at idle (at least it did in the Coronet I had it in previously)
Diesel Same style rubber mount as slant 6 to 440
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125304
12/12/11 01:31 AM
12/12/11 01:31 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
what brake system are you going to be using? Manual or power? I dont think you are going to get even the small diameter power booster to clear those valve covers.
Are you going to use a relocation kit, or
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Junkyard D150 Progress [Re: hp383] #1125305
12/12/11 12:23 PM
12/12/11 12:23 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
hp383, it'll be manual brakes and I hope the heater box clears the VC or it will be heater delete too
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125306
12/12/11 01:10 PM
12/12/11 01:10 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
If the heater box is an issue, and you want some heat, this item might help.
If you buy just the inside the cabin part, and plumb it into your original heater hose lines. You will have heat, in a nice compact unit.
Heck you may even be able to duct it so the vents work.
http://www.aquahotoffroad.com/Pages/offroadheater.htm
Re: Junkyard D150 Progress [Re: hp383] #1125307
12/12/11 08:35 PM
12/12/11 08:35 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
hp383, thanks for the good info and link on the heater.
Well Owen and his welding truck showed up this morning and he did an outstanding job on welding the bottom of the k member that had been seperated from the factory. Finished painting the front of the frame, installed a resealed PS box, and pass tie rod assembly.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125308
12/12/11 08:37 PM
12/12/11 08:37 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Another pix
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125309
12/12/11 08:44 PM
12/12/11 08:44 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
BTW, does anyone have a parking brake cable bell crank that is not frozen that they want to sell? I heated mine to red hot and pounded like crazy and the bolt maybe moved a 32nd of an inch. If I could just get the bolt and bushings out I was planning on replacing the bushings with roller bearings if I could find a set that diameter. Anyway, let me know if anyone has one that they would be willing to part with. Thanks
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125310
12/13/11 10:45 AM
12/13/11 10:45 AM
TN
'84 D150 Shorty Offline
Pickup Man
Pickup Man
TN
Looks great! Keep up the good work and keep posting pics
Re: Junkyard D150 Progress [Re: 76dodgeboy] #1125311
12/13/11 12:20 PM
12/13/11 12:20 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
As Harry mentioned the 89-93 Diesel motor mounts are a bolt in fit for the /6 and v8 engines.
I used them on my 440 swap in the Ramcharger. They are a tad taller, maybe 3/16 to 1/4 inch. But they have more material, and are very tough. Also they have the locking tabs so if they do fail, the motor wont jump out and head down the road by itself.
Surprisingly the mount on the left is the cheaper Anchor #2710 and it has more material, and is better than the more expensive NAPA mount.
The middle is the stock, factory mount, well torn.
For more info, and a followup on the mounts performance after racing, follow the link:
Anchor #2710 1st gen Diesel motor mount
Re: Junkyard D150 Progress [Re: hp383] #1125312
12/13/11 02:04 PM
12/13/11 02:04 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks guys for the info on the mounts; it's clear that the diesel mounts are the way to go as, like you stated, there is rubber material between the locking tabs. Again, thanks a bunch.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125313
12/13/11 04:15 PM
12/13/11 04:15 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Well, I checked 3 stores that had the Anchor 2710 mounts and all of them were the same; seems like now there is no material bewteen the locking tabs like in the picture. I bought a set anyway as there is almost twice as much material in the diesel mounts versus the stock mounts. Hopefully the increase in height will not affect the mounting of the motor.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125314
12/13/11 04:59 PM
12/13/11 04:59 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
The extra height shouldn't hurt. As i said these are what I have in my 93 Ramchager that I had swapped to a 440.
