Avg 360 block deck height spec #1125217
12/01/11 08:41 PM
12/01/11 08:41 PM
RapidRobert Offline OP
Doing some piston/rod mockups on paper to start out with & was wondering if alot of virgin/unmachined 70's 360 blocks tend to be above or below the nominal 9.6" deck height? Thank you for your time.
Re: Avg 360 block deck height spec [Re: RapidRobert] #1125218
12/01/11 11:45 PM
12/01/11 11:45 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
So far I've yet to see ANY Chrysler block that wasn't taller than spec.Kind of like head CC's almost always greater than spec. I doubt if there's ever been a 10:1 engine that actually was a true 10:1 from the factory.
Re: Avg 360 block deck height spec [Re: 5spdcuda] #1125219
12/01/11 11:54 PM
12/01/11 11:54 PM
Alright, & how much taller have some of the SB's been that have crossed your path
Re: Avg 360 block deck height spec [Re: RapidRobert] #1125220
12/02/11 02:39 AM
12/02/11 02:39 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
The LA blocks tend to be 9.58 and up while the magnum blocks I've seen as low as 9.56. Magnums are (to my knowledge) always lower deck than the LA blocks. Also seen quite a difference side to side. Won't know until you get one and measure it.
Re: Avg 360 block deck height spec [Re: RapidRobert] #1125221
12/02/11 04:05 AM
12/02/11 04:05 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My 360 LA block was about 9.615" at the front and 9.605" at the back of the drivers side, Passenger side was about as uneven, just reversed, 9.605 front, 9.615" rear.
Re: Avg 360 block deck height spec [Re: RapidRobert] #1125222
12/02/11 10:21 AM
12/02/11 10:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Not 360s but I have 5 340 blocks and they range from
9.579 to 9.588 measured at the front of the block...
I have one that was cut to 9.500 which I just built
Re: Avg 360 block deck height spec [Re: MR_P_BODY] #1125223
12/02/11 11:07 AM
12/02/11 11:07 AM
Thanks guys, that's exactly what I needed
Re: Avg 360 block deck height spec [Re: RapidRobert] #1125224
12/02/11 11:37 AM
12/02/11 11:37 AM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
my '73 block was squared and cut and after final machining is 9.5995. Not sure what it started at though!
Re: Avg 360 block deck height spec [Re: Alikazam] #1125225
12/02/11 11:50 AM
12/02/11 11:50 AM
Have some 6.221" rods & trying to get a very rough idea how much machining I'll need to get .035" quench w these particular pistons on hand plus valve notches plus...
Re: Avg 360 block deck height spec [Re: RapidRobert] #1125226
12/02/11 07:09 PM
12/02/11 07:09 PM
dogdays Offline
dogdays  Offline
I have to measure it again but I believe my 86 318 block is taller than 9.600.
R.
