Rear Diff Lubircant #1125168
12/01/11 07:24 PM
12/01/11 07:24 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I have a spool in a 8.75 and was wondering what I should put in there for gear Oil. I have a bottle of Lucas High Performance 80W-90 The back of the bottle says excellent for limited slips but will this be ok fo a spool. Also what would the capacity be.
Re: Rear Diff Lubircant [Re: flatiron] #1125169
12/01/11 07:28 PM
12/01/11 07:28 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
With a spool ... just the cheapest stuff you can find. 8 3/4 ? .. run it a bit low ....1.5 quarts.
Re: Rear Diff Lubircant [Re: dOc …] #1125170
12/01/11 07:41 PM
12/01/11 07:41 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Should I worry about what wght it is
Re: Rear Diff Lubircant [Re: flatiron] #1125171
12/02/11 02:43 AM
12/02/11 02:43 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Just about anything is going to be adequate for gears. additives and modifiers are aimed at sure grip (and especially clutch style) units that rely on a specific amount of friction and lubrication as part of how they physically operate.
Re: Rear Diff Lubircant [Re: StealthWedge67] #1125172
12/02/11 04:00 AM
12/02/11 04:00 AM
Florida STAYcation
Florida STAYcation
x 22 .... I would use the LIGHTEST gear-oil I could find ... in a track-only car.
Re: Rear Diff Lubircant [Re: flatiron] #1125173
12/02/11 04:14 AM
12/02/11 04:14 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Check out the Red Line ShockProof gear oils.
http://www.redlineoil.com/product.aspx?pid=44&pcid=4
Re: Rear Diff Lubircant [Re: 451Mopar] #1125174
12/02/11 04:23 AM
12/02/11 04:23 AM
Florida STAYcation
Florida STAYcation
....at 15 beans per quart ...when not really needed ?? .... THIS STUFF (like Amsoil and Royal Purple) ....is just way over-priced gimmicky oil products that are not needed in a properly maintained vehicle.
Re: Rear Diff Lubircant [Re: dOc …] #1125175
12/02/11 01:23 PM
12/02/11 01:23 PM
dogdays Offline
dogdays  Offline
Doc, take your pills, you are sounding cranky. Redline is good stuff. If you can't afford another $30 for lube, maybe you shouldn't be racing!
R. (I admit, I can't afford to be racing.)
Re: Rear Diff Lubircant [Re: flatiron] #1125176
12/02/11 03:30 PM
12/02/11 03:30 PM
Use the best stuff you can afford, especially when drag racing There is a major difference in results
Re: Rear Diff Lubircant [Re: dOc …] #1125177
12/02/11 06:14 PM
12/02/11 06:14 PM
Q
Quicktree Offline
Quicktree  Offline
Q
how much bracket racing have you done? It makes a difference
Re: Rear Diff Lubircant [Re: dOc …] #1125178
12/02/11 08:44 PM
12/02/11 08:44 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I agree !!
Re: Rear Diff Lubircant [Re: VernMotor] #1125179
12/02/11 09:12 PM
12/02/11 09:12 PM
farmingdale ny 11735
blracing Offline
blracing  Offline
richmond gears make there own lube, i've used it for my spool. royal purple also makes a good lube. i use the 74/140 in mine.
Re: Rear Diff Lubircant [Re: dogdays] #1125180
12/02/11 10:00 PM
12/02/11 10:00 PM
Florida STAYcation
Florida STAYcation
YOU sound BROKE-AZZ Double-d ....
You must be spending tooooo much of your money on GIMMICKY snake-oil stuff ...
Re: Rear Diff Lubircant [Re: flatiron] #1125181
12/02/11 10:30 PM
12/02/11 10:30 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
The "climbing" gear oil works great, but it take HP to move it.
Re: Rear Diff Lubircant [Re: dOc …] #1125182
12/03/11 12:25 AM
12/03/11 12:25 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The RedLine ShockProof oil is to protect the gears on hard launches. I'm not sure if the original poster would need the extra protection or not.
I have used the medium weight (yes, the oil is actually blue) in a 2002 Ram 1500 with the 4.7L with no problems and picked up a bit of fuel mileage too.
I use the regular RedLine 75W140 GL-5 in my Ram 3500, and the 75W90 in the Charger and Coronet.
I think the Redline oil costs less than Amsoil or Royal Purple?
A short white paper on the ShockProof oil:
http://www.redlineoil.com/content/files/tech/ShockProof%20Gear%20Oil%20Tech%20Info.pdf
Re: Rear Diff Lubircant [Re: 451Mopar] #1125183
12/03/11 12:56 AM
12/03/11 12:56 AM
IN
ahy Offline
ahy  Offline
IN
The LS additives won't hurt. I don't think the lube will be a limiting factor in an 8.75/spool - other parts will fail before the gears wear out. Personally, I'd get a couple more quarts of what you have and run it.
Re: Rear Diff Lubircant [Re: flatiron] #1125184
12/03/11 12:57 AM
12/03/11 12:57 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i use royal purple 75/90w synthetic. cost a little more, but i think it's worth. why skimp on lube. u wouldn't put some cheap crap in ur tow vehicle would u?? seeya.
Re: Rear Diff Lubircant [Re: rickraw] #1125185
12/03/11 01:07 AM
12/03/11 01:07 AM
Florida STAYcation
Florida STAYcation
YURR tow-vehicle is far more critical for the sure-grip additives and such than a 1/4 mile drag-strip car ..
Re: Rear Diff Lubircant [Re: rickraw] #1125186
12/03/11 09:23 AM
12/03/11 09:23 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Royal Purple here.
Mopar Performance
Re: Rear Diff Lubircant [Re: moparniac] #1125187
12/03/11 09:45 AM
12/03/11 09:45 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
AmsOil in the Dana 60. Abused and OK.
